3.0 CRD 2009 GC cutting out - JeepForum.com
post #1 of 7 Old 11-19-2013, 03:04 PM Thread Starter
SeanRG
2009 WK
OK,
my CRD has developed this really annoying issue where it cuts out/stalls.
It does'nt do it when idling, never has - only once drive (normally reverse, although could be coincidental) is engaged, and oddly hasn't done it once on first start in the morning (when coldest), only after it has been stood outside the office for 7/8 hours. Again could be coincidence, but also seems to be when dark so lights on etc.
Dealer has explained it sounds like fuel filter, so that was replaced yesterday but problem has carried on today. No faults registering on diagnostic checks either.
Idea's please?
thanks Sean
SeanRG is offline
post #2 of 7 Old 11-19-2013, 03:37 PM
suzieque
2008 WK
I think that you are experiencing a periodic fault with your crankshaft position sensor (cps) pretty common issue with the crd. I carry a spare cps now.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 7 Old 11-20-2013, 07:20 AM Thread Starter
SeanRG
2009 WK
Hi, is the same as the crankshaft position sensor?
thanks Sean
SeanRG is offline
post #4 of 7 Old 11-20-2013, 07:55 AM Thread Starter
SeanRG
2009 WK
hi again,
I've been reading up on various reports regarding the crank position sensor, most seem to include non starting - which is something mine thankfully always does (so far).
SeanRG is offline
post #5 of 7 Old 11-20-2013, 02:42 PM
suzieque
2008 WK
thanks Sean
Yup ,corrected, my bad.
suzieque is offline
post #6 of 7 Old 11-20-2013, 03:58 PM
Robert J. yates
Check the glow plug harness... I had the same exact issue with the truck stalling out ocassionally but always starting. Luckily I had a service manager who familiar with these engines and he traced to a chafed wire that was grounding out the entire glow plug system which stalled the truck.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #7 of 7 Old 11-21-2013, 05:33 AM Thread Starter
SeanRG
2009 WK
thanks Robert, will do
SeanRG is offline
