265-65-18s - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 265-65-18s
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueXHD Heavy-Duty Hood Latches for JK and TJ available at OcoStainless Steel Door Hinge Pins
Unread 06-12-2014, 02:32 PM   #1
joe989
2008 WK
265-65-18s
I gotta buy new tires for my jeep, and I would like to know if anyone runs 265-65-18s without a lift on an 08?
joe989 is offline   Reply With Quote
Unread 06-12-2014, 04:29 PM   #2
caulk04
2008 WK
Not going to happen.
I have 255 60 18 and they'll clear with no mods but another inch in height and a bit more width isn't going to make it.
Spacers and pw mod at least.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote
Unread 06-12-2014, 06:23 PM   #3
joe989
2008 WK
stock it is then..
Unread 06-12-2014, 07:39 PM   #4
oldsmoke
2009 WK
I have been running 255 70 18 Bridgestones for 6 months now. Gives my rig an awesome big wheel look and way more ground clearance than stock. They do rub a bit at full lock and under some turning and terrain combos but it is not a serious problem and there has been no damage to either the tires or the Jeep. I did hammer over the sharp steel edge of the inside fender on the front so it would not nibble at the tires.
The 265 65 18's might fit but it will be very tight. You would have to mount one up on a front wheel and try it.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline   Reply With Quote
Unread 06-12-2014, 08:30 PM   #5
joe989
2008 WK
yeah but you have a leveling kit on your jeep? 255/70/18 is bigger than 265/65/18. at least in height anyways.
Unread 06-12-2014, 10:25 PM   #6
paroxysym
2007 WK
I'm running stock JK sahara rims and tires with a JBA spacer and Bilsteins in the front with no problems.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote
Unread 06-13-2014, 04:02 PM   #7
oldsmoke
2009 WK
Yes, the 255 70's are taller and narrower than the 265 65's. I wanted maximum ground clearance so I went with a taller rather than wider tire. Because the 255's are narrower I was able to go up to a 70 profile for the extra tire diameter I was after. The 255's are still wide enough for good flotation and I get extra ground clearance for offroading and awesome profile.
I'm not sure but I think I had the tires on before I did the lift and the fit was about the same.
Unread 06-15-2014, 06:28 PM   #8
oldsmoke
2009 WK
My Jeep with 255 70 18's and 2" lift on stock wheels
Unread 06-16-2014, 01:12 AM   #9
ccsicecoke
2006 WK
265 60 r18 is the max. i'm running goodyear all-terrain adventure w kevlar at that size. no rubbing at full lock but extremely close to the bolt. i might just add front leveling spacers for peace of mind
ccsicecoke is offline   Reply With Quote
Unread 06-17-2014, 05:17 AM   #10
paroxysym
2007 WK
i think with a 1" spacer youll be ok in the front... i mean its roughly the same size as a 265/70r17.. like i said im running 255/70r18, which is a 32x10 and i am running a 1/4" spacer in the front and rear just for the hell of it- they rit regardless...and im at stock height
OEM+
