255 75 17 - will they fit without a lift? - JeepForum.com
post #1 of 14 Old 02-12-2013, 11:50 AM Thread Starter
SilverStreaker
I have a brand new set of 255 75 17's that I took off my Wrangler and would really like to put them on my Cherokee. I've read the faqs and I know it says 255 65 17's but has anyone tried successfully the larger size? I have no issue puting a 2" bb on it but my wife may have some objections. Lol
Thanks!
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #2 of 14 Old 02-12-2013, 01:55 PM
fingaz
2009 WK
Let me know if this works. I am planning on putting larger tires on my stock WK.
2009 3.7L Laredo Black | Two-Toned Leather | RER Nav/DVD/BA System | Viper alarm | HID's in the lows and fogs | Westin Brush Guard | Tinted Tails | Custom Blue LED Interior/Rear Hatch Lights | Rough Country 1.5" Spacers | General Grabber 255/70r17 -- Island Beach State Park 4x4 Mobile Sportsfishing Permit In -- To Do: Install Uniden CB, Rock lights
fingaz is offline
post #3 of 14 Old 02-12-2013, 03:55 PM
ovrsoo
2005 WK
I have 255/75/17 winter tires on my stok WK
ovrsoo is offline
post #4 of 14 Old 02-12-2013, 04:23 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Look before you post:
http://www.jeepforum.com/forum/f67/w...hread-1246013/
Omelet is offline
post #5 of 14 Old 02-13-2013, 10:25 AM Thread Starter
SilverStreaker
Sure will, I'll post back what I decide to do.
Thanks. Do you have any issues with rubbing at full turn? Her jeep never see's the trails so I'm not worried about flexing too much.
Originally Posted by Omelet View Post
Thanks but I did briefly look in that thread and found the only ones with this size tire are using spacers and lifts. Also, the op of that thread said to refer questions to the WK forum, which is what I have done.
post #6 of 14 Old 02-13-2013, 10:41 AM
lsuber
2005 WK
I'm going to be in need of tires soon myself and am considering upsized ones on my non-lifted WK. I have not checked or tested any tires, mind you, but my time spent reading around suggests that 255-65-17's will likely fit, and sometimes a 255-70-17 will fit, depending on the specific tire. The tread thickness and sidewalls are slightly different from tire to tire, so at that max size it totally depends on the tire. Looks like a Bridgestone Dueler A/T series in the largest size will fit, but some others do not. I've personally not seen any postings of a 255-75-17 fitting on a non-lifted WK, but that's not to say its impossible.
2005 WK Grand Cherokee, Rocky Mountain Edition, 4.7L V8 4x4 QTII
2006 XK Commander, 4.7L V8, 4x4 QTII
lsuber is offline
post #7 of 14 Old 02-13-2013, 06:25 PM
AJeepZJ
2006 WK
Yiu should be parepared to lift this vehicke for that tire size. It will be very challenging if not impossible to equip 255/75/17 on a stock WK. It would probably rub in the back during full compression. And the front would rub the sway bars if it wasn't already rubbing upper ball joints.
All Gear, No Skill.
AJeepZJ is offline
post #8 of 14 Old 02-13-2013, 06:54 PM Thread Starter
SilverStreaker
Thanks for the info. Do you think I need spacers as well or just a 2" lift like the rough country one?
post #9 of 14 Old 02-13-2013, 06:59 PM
mykdee311
2005 WK
^ agree, not sure how these ppl have 255/75r17 on a completely stock wk. mine rubbed after the lift & spacers until i folded the pinch weld.
05 WK Limited, QDII, Hemi, Superchip, OME HD Lift, JBA UCA & disconnects, 4xGuard (Belly, Sliders, Rear Sliders, Diff), 255/75R17 on Moab's w/ 1.5" Spacer, Thule M.O.A.B. Basket
03 3500 Cummins, 79 Mustang 2.5T Stroker, 63 F250 428 4x4
mykdee311 is offline
post #10 of 14 Old 02-13-2013, 07:35 PM
jjt250
2007 WK
If 255/75/17s rub the balljoint on a stock WK, they will rub on a lifted one too. Regardless, Moab rims will not clear the calipers unless you have at least a 1/4 inch spacer or a 2005-2006.5 WK. I'm just assuming you're using Moab rims because you said they're coming from your JK.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #11 of 14 Old 02-14-2013, 04:54 AM Thread Starter
SilverStreaker
No, it's just the tires from my Wrangler not the rims.
post #12 of 14 Old 05-14-2016, 06:06 AM
Crixus
2005 WK
Lmao. Wrecked.
Anyway, anybody have any updates on fitting this size on a stocker? I was gonna go 255/70 but if I can go 255/75 then I will
Crixus is offline
post #13 of 14 Old 05-15-2016, 12:32 AM
derpboss
Originally Posted by Crixus View Post
Lmao. Wrecked.
assuming you're using the WK rims with the 255's you'll need to trim the upper ball joint stud. and the wheels will rub at full lock. but yes, you can use them on a stock GC, going over bumps sucks though.
derpboss is offline
post #14 of 14 Old 05-15-2016, 03:15 PM
Crixus
2005 WK
I'm not trying to do any trimming anywhere especially the ball joint stud. I've heard horror stories.Guess I'll go with 255/70/17s. Thanks feller.
Crixus is offline
