225/75/17s on 2005 WK? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 225/75/17s on 2005 WK?
Oconee Off-Road Now Offering BDS Suspension Products...RUGGED RIDGE 8500# WINCH--$274.00 w/FREE SHIPPING!!!Bestop offer!
Unread 01-11-2010, 07:50 PM   #1
PHC
2005 WK
I have a stock 2005 limited with the 5.7 and dont want to make any modifications. I need a tire that is heavily puncture resistant and am having a hard time finding tires that both fit and meet that requirement. Seems like the 225/75/17s, load range E might fit the bill. Anyone know if they will fit?
PHC is offline   Reply With Quote
Unread 01-11-2010, 07:58 PM   #2
konarider94
2005 WK
why so narrow? is that size even recommended for the stock wheel? factory is a 235 or 245
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline   Reply With Quote
Unread 01-12-2010, 10:10 AM   #3
PHC
2005 WK
Thanks konarider - I'd be happy to stick with stock size, but I can't find any heavy duty tires in 245/65/17 or 235/65/17 (10-ply rated, load range E, etc). I'm ok with the skinny tire as it actually helps for sidewall punctures, which is the main issue where I am off-road. Light duty tires at best are flat by morning, or at worst get shredded in the field. Plus they are only 0.4" narrower than my current 235's.
I was looking at the GY Silent Armour LT225/75R17 specifies and approved rim width of 6"-7.5", so I think I'd be ok on the 17x7.5s
Any advice on heavy duty tires in the stock range would be helpful, or if anyone knows if the 225/75/17s will fit
Thanks!
Unread 01-12-2010, 10:26 AM   #4
konarider94
2005 WK
they will fit. i run 245/75-17 and the 225/75-17's will be narrower and shorter than those. i have the goodyear silent armors and they are very good.
edit: the bridgestone dueler revo 2 has some LT tires coming out this year. some of the sizes include 245/75-17 and 245/70-17 load range E. They will be expensive though.
Unread 01-12-2010, 10:48 AM   #5
PHC
2005 WK
konarider I like the tires you are running I just didn't think they would fit. You've had no fit issues with yours, and you didn't have to make any modifications?
Unread 01-12-2010, 11:02 AM   #6
konarider94
2005 WK
mine fit fine, i havent wheeled it yet so the suspension hasnt been really flexed but i have been driving on them for a while without any issues. i am still kind of considering a 2" lift but im doing fine without one
i didnt do anything other than the tires, no bolt cutting, no spacers, no pinch weld, no lift, and stock rims
Unread 01-12-2010, 11:12 AM   #7
PHC
2005 WK
Thanks, and thanks for the heads up on the Revos too - that could be a good option also
  • 2005 Wk - WK Grand Cherokee & XK Commander Forum (0 replies)
  • 2005 Fsm - WK Grand Cherokee & XK Commander Forum (5 replies)
  • 2005 Gc Ltd - ZJ Grand Cherokee Forum (4 replies)
  • 2005 WK vs. LR3 - ZJ Grand Cherokee Forum (1 replies)
  • 2005 Jgc - WJ Grand Cherokee Forum (0 replies)
