2010 Grand Cherokee WK - JK Wheels (will they fit) - Page 3 - JeepForum.com
post #31 of 39 Old 06-19-2013, 02:28 AM
Valpacer
2007 WK
I dont know if i can answer that for the US wheels, down here there is no difference. As far as i know the machined face ones are the Rubicons, and the painted ones are the normal wrangler ones.
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #32 of 39 Old 06-19-2013, 04:27 AM
ryann04
2008 WK
I can vouch. I am running MOABS off a 2012 wrangler take offs. They fit on my 2008 JGC with .25" spacers and no lift. The only reason the .25" spacers are needed is for the rim coming into contact with the caliper bracket. You can shave this down with a file, 1/8", and you will be good to go! I have tried stuffing the tires and they don't rub, 100% clearance, no scraping.
Hope this helps someone out there, I know it's been answered 100 times before.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #33 of 39 Old 06-19-2013, 11:58 AM
LincolnTyler
2007 WK
Thank's for the reply! I'm an over-thinker and after noticing the difference was hoping I didn't end up with a heavier set or something. So I figured I'd ask. I appreciate your help. I think once I have an opportunity to weigh the wheel without a tire I'll post up what the weight comes out as and maybe there will be something to compare against. Here's hoping they shave some lbs!!
|2007 3.7l | Light Khaki/Sandstone | 2" RC | JK take off's | 265/70/17 DuraTrac's | Expanded Sheet Metal Grill Mod | Pinch Weld | EBC Rotors | Hawk Ceramics | Bilstein 5100 rears | Khaki Club #66 | Cabin Air Filter | Stickers...
LincolnTyler is offline
post #34 of 39 Old 10-15-2013, 07:11 AM
carangelover
2007 WK
I have a 2007 Grand cherokee with no lift and the rubi wheels on with a 1/4" in spacer to clear the brake caliper. They are running a 255/75/17 with no issues that I can see. It clears the uca bolt but do you guys think I will have rubbing issues? There is about 3/4" inch to inch of room between the tire and the bottom of the uca bolt. I was thinking of getting the spidertraxx 1.25" spacers.
***Edit
I orders the spidertrax 1.5" spacers I noticed some rubbing near the UCA arm bolt and for piece of mind lol.
carangelover is offline
post #35 of 39 Old 10-16-2013, 11:02 AM
OttawaJeepClub
Originally Posted by Valpacer View Post
Factory JK 17" wheel (Moab)
  • has a 43.8mm offset
  • will contact the front calipers (wont fit)
  • A 1/4" (6mm) spacer will allow this wheel to fit with a 265/70 and not hit the bolt.
  • A bolt on spacer will also work.
  • Pinch weld mod not required (unless bolt on spacer used)
The JK MOAB's I got from a 2012 were 44.45 Offset, and they didn't rub on my 2010 WK caliper bracket.
OttawaJeepClub is offline
post #36 of 39 Old 10-16-2013, 11:45 AM
R4TCHET
2005 WK
They will fit with a 2" lift, they might rub the caliper they did on my 05 so I went to advance auto a got a set of 1/4" spacers for the front for $20. If you do end up needing spacers then I would suggest getting some bolt on ones. Anywhere between 1"-1.5" should do. I personally have 1.25" spacer and I'm looking into switching to 1" spacers because my 275s just barely touch the fender at full stuff and the fender lip rolled in the back. I think there is a company named bora that makes quality spacers like spidertraxx which I would suggest for anything smaller than 1.25" Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #37 of 39 Old 01-05-2015, 10:15 PM
msoukup84
2005 WK
Any thought been given to these Quadratec Moabs?
http://www.quadratec.com/products/92615_211X_PG.htm
17x8.5" Size with 4.7" Backspacing
If you have the 17" Jeep Brand JK Moab wheels:
Machined Cast-Aluminum - Size 17 x 7.5
Backspacing .......... 6.25"
Bolt Pattern .......... 5 x 5
If I'm thinking correctly, these Quadratec wheels would stick out 2.55" more? 1.55" due to backspacing and 1" due to rim width?
msoukup84 is offline
post #38 of 39 Old 01-09-2015, 01:51 PM
luckyse7ens
2010 XK Commander
Looks right to me.
Black WK Club #152
luckyse7ens is offline
post #39 of 39 Old 01-09-2015, 07:58 PM
Tango.
2008 WK
Like Valpacer said ... you'll need 1/4" spacer "with the same tires" for the JK or Moab wheels.
There are (2) Moab wheels a 17" and the 20". They are the same offset as the JK wheels which I run on mine. I put the black 1.5" spacers, but the 0.25" will work fine. 10th anniversary Rubi's.
Life is hard-John Wayne
Tango. is offline
jk , wheels , wk
