2010 Grand Cherokee WK - JK Wheels (will they fit) - Page 2 - JeepForum.com
 1Likes
post #16 of 39 Old 01-14-2013, 09:32 AM Thread Starter
specialized11
2010 WK
spacers
having difficulty finding just 1/4" spacers? any suggestions?
specialized11 is offline
post #17 of 39 Old 01-14-2013, 10:10 AM
blizzboy283
2005 WK
Are you lifting at all? Might as well just do it the proper way and pick up some spidertraxx.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #18 of 39 Old 01-14-2013, 12:08 PM Thread Starter
specialized11
2010 WK
yes already lifted with the RC 2"... Moab wheels im getting this week, smallest spidertrax I can find is 1.25 so I guess I'll do those...
post #19 of 39 Old 01-14-2013, 12:09 PM Thread Starter
specialized11
2010 WK
hopefully wont have to do the pinch weld mod with 265/70/17 nitto terra grapplers?
post #20 of 39 Old 01-15-2013, 02:41 AM
Valpacer
2007 WK
You will need to do Pinchweld. Very easy to do though.
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #21 of 39 Old 01-15-2013, 10:31 PM Thread Starter
specialized11
2010 WK
im determined to clear the bolt... what about 255/70/17 general grabber at2.... that's a 31.1" tire... or will I still need the spacer for the jk wheels?
I'm dying to find a way around the spacers... any help would be appreciated...
post #22 of 39 Old 01-15-2013, 11:59 PM
trax95008
2006 XK Commander
The spacer is needed for the rim to clear the brake caliper. Tire size is irrelevant in this case. If you want to avoid spacers, you might have to pick a different rim
trax95008 is offline
post #23 of 39 Old 01-16-2013, 01:39 AM
Valpacer
2007 WK
Commander rims have the same offset as the jk 17's, and clear the bolt and caliper. 1/4" spacers are usually only around $10 a set.
Valpacer is offline
post #24 of 39 Old 01-16-2013, 10:42 AM
trax95008
2006 XK Commander
I'm pretty sure the XK's are the same as WK's. the Moab wheel wouldn't clear my caliper. It's the Sahara wheel that has a different offset. It does clear the caliper
post #25 of 39 Old 01-16-2013, 04:03 PM Thread Starter
specialized11
2010 WK
so I just ordered my 265/70/17 general grabber at2's.... I have decided to go ahead and pick up the moabs but probably won't have them mounted right away... I'll stick with stock for now until I can decide about spacers...
so 2" RC lift with 265/70/17 general grabber at2's stock wheels... am I good?
post #26 of 39 Old 01-16-2013, 04:34 PM
sk1er18
2007 XK Commander
Most XK wheels are 43.8mm offset and most WK wheels are 50.8mm.
-Matt
sk1er18 is offline
post #27 of 39 Old 01-17-2013, 03:44 AM
Valpacer
2007 WK
Just to nail this down for you. But remember I dont see every type of wheel as they are not all released down here in Australia, but this covers its pretty well.
Factory wheel for WK
  • has a 50.8mm offset
  • a 265/70 will not fit without hitting the bolt
  • A 1/4" (6mm)spacer will allow this to clear the bolt.
  • You can cut the bolt and it will clear but removing the upper BJ and reinstalling can become troublesome, and tyre will rub the swaybar. I dont recommend cutting the bolt but thats only my opinion.
  • Pinch weld mod not required
Factory wheel for XK
  • has a 43.8mm offset
  • a 265/70 will fit without hitting the bolt
Factory JK 17" wheel (Moab)
  • will contact the front calipers (wont fit)
  • A 1/4" (6mm) spacer will allow this wheel to fit with a 265/70 and not hit the bolt.
  • A bolt on spacer will also work.
  • Pinch weld mod not required (unless bolt on spacer used)
Aftermarket Wheel
  • Usually a +25mm or less offset (+15mm, +10mm, 0, -10mm though these are usually called JK wheels, same stud pattern)
  • Any offset from +40mm to -10mm will clear the bolt, and sit the tyre further out of the body.
  • Will clear the Caliper
  • Will clear the bolt with a 265/70
  • Pinch Weld mod required.
Bolt on Wheel Spacer
  • Usually 1, 1.25 or 1.5"
  • All factory wheels with 265/70 will clear the bolt and caliper
  • Buy the hub centric better quality brands (eg Spidertrax etc)
  • Torque them to the specs and check regulary
  • Pinch weld mod required
Dave
Raffish likes this.
Valpacer is offline
post #28 of 39 Old 01-17-2013, 08:58 AM Thread Starter
specialized11
2010 WK
awesome, thanks valpacer...
post #29 of 39 Old 01-17-2013, 02:09 PM Thread Starter
specialized11
2010 WK
got the tires mounted but had to cut the bolt... no biggie until something happens and i need that bolt.. lol
anyway in the nick of time too, i live in virginia and it just so happens to be coming one heck of a snow storm... 10-13 inches...
i will hopefully get some good pics to show everyone...
post #30 of 39 Old 06-18-2013, 06:56 PM
LincolnTyler
2007 WK
has a 43.8mm offset
Hey Valpacer, seems like you are a knowledgeable person to ask regarding wheels. Are there two different types of JK take off's? It seems from reading different threads and builds that some JK take off's have a powder coat finish look to them and a pair that I recently picked up have more of a brushed looked to them. Just curious if I ended up with Moab's or a regular set of take off's (heavier than Moab's), or if they are all Moab's, just different finishes.
Thanks in advance. I've attached an image of the wheels I recently picked up. Not the best pic, wheels are at home, I'm at the office.
|2007 3.7l | Light Khaki/Sandstone | 2" RC | JK take off's | 265/70/17 DuraTrac's | Expanded Sheet Metal Grill Mod | Pinch Weld | EBC Rotors | Hawk Ceramics | Bilstein 5100 rears | Khaki Club #66 | Cabin Air Filter | Stickers...
LincolnTyler is offline
jk , wheels , wk
