2010 Grand Cherokee Laredo Trailer Plug - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2010 Grand Cherokee Laredo Trailer Plug
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-04-2015, 08:42 AM   #1
skip49
Have no power at Trailer Plug, followed harness from plug forward and all is clean and undamaged by appearance where I can see it. Tested fuses and relays and even swapped them around with same rated fuses and relays from systems that operate correctly, and they worked correctly. Even tested fuse in harness right next to fuse boxes and that was good per test. All other lights on jeep are working, only problem is at plug. Is there a fuse, breaker, super secret switch, handshake or magic phrase I do not know about to get power to factory trail plug so I can tow my trailer and not have to stop and socialize with every law officer I pass by.
skip49 is offline   Reply With Quote Quick reply to this message
Unread 08-04-2015, 02:25 PM   #2
ryankokesh
You checked the blinker fluid, right?
ryankokesh is online now   Reply With Quote Quick reply to this message
Unread 08-04-2015, 08:46 PM   #3
modernblueWK
I think you have to take it into have the trailer wiring activated if you did not have the towing package factory installed.
2008 WK 4.7 V8 RC Lift, WK MLL's, G2 Diff Cover, 4XGuard front guard, Steel Armadillo Belly Skid, Superchips, Magnaflow 13742, General Grabber AT2 245/70-17.
Blue WK club #4 Build/Adventure Thread
modernblueWK is offline   Reply With Quote Quick reply to this message
