2009 Grand Cherokee won't start // ETC Light On // New Battery Didn't Work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2009 Grand Cherokee won't start // ETC Light On // New Battery Didn't Work
Count Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!Steering and more from Ruffstuff!
Unread 11-30-2014, 09:17 PM   #1
kaiserp
Hey all,
I came out of the grocery store today to find my 2009 Jeep Grand Cherokee Laredo 4x4 completely unable to start.
- All lights and accessories are working perfectly when turned on
- When i turn to start the engine, it clicks and shuts everything off, I get the lightning bolt ETC light, as well as the oil pressure check engine light. they both stay solid for about 3 seconds, then everything returns to normal on the dash.
- The engine never turns over or makes any sound, it seems completely electronic.
- I read some forums that suggested the battery cell is likely dead, and only has enough power to trigger everything but the starter.
- I went to O'Reilly and dropped $180 on a brand new battery. They put it in for me, and still nothing. (and they won't accept a return, jerks)
Now my car has been towed home and is completely out of commission. Any help is so appreciated.
kaiserp is offline   Reply With Quote Quick reply to this message
Unread 11-30-2014, 09:58 PM   #2
Chirpz
Chirpz's Avatar
2007 WK
Which engine? Do you have a code reader, if so what codes.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline   Reply With Quote Quick reply to this message
Unread 12-01-2014, 01:03 AM   #3
modernblueWK
I posted in your other thread. WIN (tipm) module for the ignition.
2008 WK 4.7 245/70-17 Grabber AT2 Magnflow G2 MLL's RC Lift 4xguard Steel Armadillo
Blue WK club #4
modernblueWK is offline   Reply With Quote Quick reply to this message
Unread 12-01-2014, 09:37 AM   #4
tom19511
2006 WK
Yellow connection on starter. Pain in the a** to fix. But many have found this the problem
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2014, 09:39 AM   #5
tom19511
2006 WK
see above
Tom19511
Unread 12-03-2014, 07:51 AM   #6
kaiserp
Thanks guys, I didn't realize I posted two threads. Must have been an accident. i appreciate the help. I threw her in the shop, I figured I was doing more harm than good under the hood.
Unread 12-03-2014, 08:17 AM   #7
GregK340
2007 WK
be sure and let us know the final outcome, as it will probably help someone else down the road.
GregK340 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2014, 04:37 PM   #8
kaiserp
Just got off the phone with the shop. He said there was some bad wiring to the starter motor, and it fried the starter motor. So they had to replace the starter motor and fix the wiring. Cost me around $500. Oh well...
