2008 wk 3.0l crd help! - JeepForum.com
 2Likes
  • 1 Post By moonvan
  • 1 Post By roll_diesel
post #1 of 9 Old 05-07-2017, 10:55 AM Thread Starter
roll_diesel
After blowing intercooler boot off a second time my jeep cranks but won't fire and I have the dreaded lightning bolt displayed on dash. Unhooked battery - no help. Code reader says P2009 which I can't find anywhere and wont clear. Any ideas out there?
Sent from my SM-G900W8 using Tapatalk
roll_diesel is offline
post #2 of 9 Old 05-07-2017, 12:04 PM
board350
Junior Member
2007 WK
Just guessing but sounds like an over boost situation. Don't know why it wouldn't fire though?
Sent from my XT1096 using Tapatalk
2007 WK Limited, 3.0L Merc CRD, QDII, OME HD Lift, GDE "HOT" Tune, CBE pipe, Mineral Gray Metallic
board350 is offline
post #3 of 9 Old 05-07-2017, 12:30 PM
board350
Junior Member
2007 WK
Try Google searching the code with CRD Mercedes in the search. I find a lot more info for other vehicles that have the same engine. Like the following: http://www.benzworld.org/forums/w211...009-p2015.html
Sounds like it could be contaminated fuel or water-in-fuel sensor gone bad. Have no idea if the blown intercooler tube is related or not.
board350 is offline
post #4 of 9 Old 05-07-2017, 01:26 PM Thread Starter
roll_diesel
Checked codes with a different reader and have P0243, P0489 and P2009.
post #5 of 9 Old 05-08-2017, 08:00 AM
moonvan
2008 WK
P0243 OBD-II Trouble Code: Turbocharger Wastegate Solenoid A Malfunction
P0489 OBD-II Trouble Code: Exhaust Gas Recirculation A Control Circuit Low
P2009 OBD-II Trouble Code: Intake Manifold Runner Control Circuit Low Bank 1
roll_diesel likes this.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #6 of 9 Old 05-08-2017, 08:08 AM Thread Starter
roll_diesel
Any expertise on how too reset or troubleshoot these?
post #7 of 9 Old 05-08-2017, 09:38 PM Thread Starter
roll_diesel
Not sure why but fuse #27 blew when my boot came off my homemade resonator delete pipe. Problem solved!
caddydaddy likes this.
post #8 of 9 Old 05-09-2017, 08:14 AM
caddydaddy
2007 WK
A code scanner can reset the codes so you can then see if they return. I use a BlueDriver scanner.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
195,000+ miles!
caddydaddy is offline
post #9 of 9 Old 05-09-2017, 07:48 PM
Tango.
2008 WK
What is with all this drama?
"2008 wk 3.0l crd help! "
Sounds like stuck some where in the middle of no where and need help like EPRIB condition.
Maybe think you should re-title it need help P2009 code?
Call wolf too many time thing ...
Just saying.
Life is hard-John Wayne
Tango. is offline
