2008 jeep grand diesel injector replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2008 jeep grand diesel injector replacement
Halloween Savings to die for!Offset Tie Rod Kit From RuffStuff!Ruffstuff Axle Simple Swap Kit!
Unread 10-10-2014, 09:07 AM   #1
diesel88
2008 WK
Hi I have an 08 diesel grand and last year I had the middle on driver side injector crap out. It was covered under warranty and was replaced and the one in front was cleaned and O rings replaced. Just over a year now and no warranty the same 2 are melted and need to be replaced. Any advice would be appreciated.
diesel88 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 11:46 AM   #2
furiousbudy
2008 WK
first, trow your foam covers away. Then soak the mess with degreaser, and pressure wash it. Go to ebay order the strech bolt and o-ring, might want the miller tool to remove the injector. Can try to look on Sprinter forums, they had couple spriters with the same problems. Had the same problem with mine, but i d'ont have the foam cover, so i did see it before the crap came out.
2008 Grand Cherokee CRD Limited 163,000KM
furiousbudy is offline   Reply With Quote Quick reply to this message
Unread 10-10-2014, 01:02 PM   #3
TangoTango
2008 WK
If the same (2) are melted they probably torqued them wrong OR didn't clean the injector cylinder correctly. The o-rings blew out and need to be replaced again. It has probably been bad for a while.
If you're going to do them yourself.. like he said above.
TangoTango is offline   Reply With Quote Quick reply to this message
