2008 Jeep Commander Rear Differential assembly - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2008 Jeep Commander Rear Differential assembly
Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete
Unread 02-09-2015, 05:22 PM   #1
gpeters84
Hi everyone, allow me to introduce myself. My name is Greg, 31 years old, have owned Dodges all my life. I am a Automotive Technician/mechanic. Anyways, a friend of mine bought a 2008 Jeep Commander last week. Long story short, rear end is locked up gets towed to a shop, rear end is fried, gets it towed to me and asks me to fix it. I see no identifying tags on this thing. 10 bolts in the cover. It's a 2008 sport model, I believe full time awd and has a 3.7 6 cylinder. Any other way to identify this thing?
gpeters84 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 08:07 PM   #2
yzjwk
2005 WK
I'm fairly certain you'll find that diff is a chrysler 8.25 (part # C213R) with a 3.07 axle ratio . Just to be sure , you can go here and click on equipment listing under "your vehicle" then enter your vin (in all capitals) under equipment listing and you will get an instant build sheet for the jeep .http://www.jeep.com/webselfservice/j...527R%2527%2529
Good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 02-09-2015, 08:29 PM   #3
gpeters84
Thanks! now my next question is are there any other models that use this rearend? Trying to get this fella up and running pretty quick, he mentioned getting a whole rearend from a jy
Unread 02-09-2015, 08:59 PM   #4
yzjwk
2005 WK
If you have the 3.07 gears then i'm pretty sure your options are limited to the 2005-2010 v6 awd ( quadra-trac 1) Grand cherokee WK or Commander XK models. definitly all the v8 models use different gears and I think the 2wd models use a different diff all together.
90 YJ Islander 4.2L
2010 MK Patriot
