2008 Grand ARB bumper will they work together - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2008 Grand ARB bumper will they work together
15 x 8 Black D-Window Steel Wheels Set of 4ZONE 4.25" combo lift for TJ available at Rockridge4wROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 09-28-2014, 07:26 PM   #1
dan1488
2008 Grand ARB bumper will they work together(Pics added)
I recently purchased a 2008 Grand Cherokee and want to put an ARB bumper on it. I seen they don't exactly say they fit my year. Is all I need to do modify the grill or change it for a 2007 and it will fit? The gaps under the headlights do not bother me. Just want to be reassured before I order one. Thanks.
dan1488 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 10:08 PM   #2
TurboDiesel
2008 WK
sounds about right
[B]-]All Blacked Out[-[/B]
2008 Jeep Grand Cherokee 3.0 CRD
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
15" kicker solo baric L7 w/ Alpine m1000 amp
aftermarket headlights w/5000k HIDs
Red interior LEDs and Red license plate LED
Tinted tails
5% tint over the rear windows
more to come....
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 09:42 PM   #3
dan1488
Looks like I will be ordering one this week. Thanks
Unread 09-30-2014, 07:24 PM   #4
TangoTango
2008 WK
Did they say it will fit? I have an 08 and was looking at it.
Does it need a modification to fit right?
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 03:52 PM   #5
ryann04
2008 WK
c'mon guys! Search...
http://www.jeepsunlimited.com/forums...-S-build/page4
ryann04 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 05:18 PM   #6
TangoTango
2008 WK
That is the similar to what a few others have done and gone with the hidden winch mount and then cut back the ARB bumper by 2" or 3" inches since they didn't need the winch mount in the ARB.
What I want is the winch in the ARB bumper.. and I have serch around a bit, but haven't found what modifications are needed to fit the stock ARB on the 2008 WK.
In that above example it looks like the mount points are the same and it fits? The mounts were only shortened to pull the bump in the 2 or 3" for the winch elimination mod....or am I missing something?
Unread 10-01-2014, 08:56 PM   #7
BAH101
2008 WK
Originally Posted by TangoTango
That is the similar to what a few others have done and gone with the hidden winch mount and then cut back the ARB bumper by 2" or 3" inches since they didn't need the winch mount in the ARB. What I want is the winch in the ARB bumper.. and I have serch around a bit, but haven't found what modifications are needed to fit the stock ARB on the 2008 WK. In that above example it looks like the mount points are the same and it fits? The mounts were only shortened to pull the bump in the 2 or 3" for the winch elimination mod....or am I missing something?
From what I have read, you will need to trim the top rear of the ARB to fit the 08 grill. Other than the fillets under the lights, this is all that is required.
The others mentioned did extensive modding to bring in the ARB closer to the body to have less overhang.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 10:03 PM   #8
ggrassmid
Wonder if the ARB can be trimmed sorter and still have the hidden winch on a CRD with a 3" intercooler?
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 10:54 PM   #9
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
2010 WK
Check out my build thread, I think it'll answer most of your questions about modifying an ARB. But in short, the normal WK ARB bull bar WILL work on a '08-10 with no additional modification.
My '10 with a highly modified ARB:
This pic is from before the hidden winch mount:
2010 Grand Cherokee S-Limited 5.7L SL 6" - 305/70/17 - ARB bull bar - 4XGuard armor - Quadratec Q11000S - ARB on board air
1998 Cherokee Classic 4.0L
2014 Grand Cherokee SRT 6.4L
Borla-S
USN_BlackWK is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 11:03 PM   #10
USN_BlackWK
FLY NAVY
2010 WK
belay my last. You'll need to modify either your grill or the bumper where the grill contacts it. The '08-10 grill extends farther from the vehicle than the 05-07 and thus you'll need to trim to fit.
Borla-S
Unread 10-02-2014, 01:47 AM   #11
ggrassmid
USN_BlackWK: with yours tucked closer, and I see a hidden winch now; how much room between the radiator and the winch & mount is there (if you can tell)?
Unread 10-02-2014, 03:02 AM   #12
USN_BlackWK
FLY NAVY
2010 WK
None... But I put the winch behind the ARB mounting bracket with some modification to hide the bolts for a clean install. You could easily put it on the bumper like its supposed to be and cut the bracket to accommodate with plenty of room.
Borla-S
Unread 10-02-2014, 06:57 AM   #13
TangoTango
2008 WK
Thanks !
Nice build!
Unread 10-14-2014, 06:30 PM   #14
TangoTango
2008 WK
Did you swap out the 2008 grill for a 2007 grill ? and if so did it fit?
Unread 10-14-2014, 10:01 PM   #15
dan1488
yes put a 2007 grill on it. The bumper fit and looks good. Will try to post pictures this weekend.
