2008 CRD vs 5.7 - advantages? - Page 2 - JeepForum.com
post #16 of 49 Old 12-20-2013, 10:29 PM
816jared
2005 WK
longevity really a benefit? there are gasoline powered WK's w/ 350k miles on them...
2005 WK // 4.7L // OME HD // lots more
816jared is offline
post #17 of 49 Old 12-21-2013, 01:29 AM
Joeyicu
Joeyicu's Avatar
People have this thought in there minds that modern diesels will last longer then modern gasoline motors, and I just don't believe it. A CRD and a hemi will both last about the same amount of time and mileage, the CRD is not going to offer any advantage in base engine longevity vs a hemi.
Someone would actually have to break down the maintenance costs of both the hemi and the CRD. I have been running the champion copper plugs in my hemi, witch means she requires 16 brand new spark plugs every 30k, at about 2 dollars a pop. I cant see that benz diesel costing a whole ton more then the hemi. Maybe a little pricey every oil change, maybe more frequent fuel filter changes, negligible in my mind. So the point I am trying to get at is, just buy witch ever one you like better, I think in the long run the cost of these two stays about the same.
p.s. I dont think driving style matters either, all around town, all highway, they both work out ok, I dont know how anyone could justify one motor as being better suited to either situation then the other.
all state above is IMO, I hope not to offended anyone.
(2011 BMW X5 V8TT) {2005 WK Hemi } -1995 Ford Tbird- [1984 F250 6.9]
Joeyicu is offline
post #18 of 49 Old 12-21-2013, 08:13 AM
LouC
2007 WK
Just one of the repairs mentioned on here, for the Diesel is going to put it over what you'd spend on the Hemi. Its the nature of the beast, same thing if you wanted a Ram with the Cummins, they are commercial rated engines and they are built for heavier use than most gas motors. BUT with that, comes very expensive parts prices and more complex designs in general. If you like the Diesel you should have one but you have to keep that in mind just like if you owned any higher end German car. Cheap to fix they ain't.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #19 of 49 Old 12-22-2013, 10:47 AM
Summitset
2007 WK
http://www.dieselforum.org/files/dmf...ort_dd2017.pdf
A little article I found, might be worth reading.
Summitset is offline
post #20 of 49 Old 12-22-2013, 12:58 PM
816jared
2005 WK
biggest problem I see with this report vs this discussion is that the vehicles used were new. I think it might be a little tough to track down a new WK crd at this point...
816jared is offline
post #21 of 49 Old 12-23-2013, 02:01 PM
Red_liner740
Originally Posted by 816jared View Post
what recession? not pay attention to the stock market at all? housing market?
I'm not going to get into a huge debate about this, other than to say that yes, i keep track of the economy a lot closer than most people, and no, the stock market nor the housing market are any indication of the ending of the recession.
Dig deeper and you will realize that most of the housing market rise is not from family first purchases but from refinancing and large corporation purchases.
Dont get me started on the stock market. Its acting exactly the same as it did in 2007, right before plunging to nearly half its worth.
If the Fed wasnt pumping 85 BILLION of dollars into the system EVERY MONTH, we'd be in a lot bigger pile than we are now.
Red_liner740 is offline
post #22 of 49 Old 12-23-2013, 02:47 PM
caddydaddy
2007 WK
I'm currently looking for a CRD GC as well. I'd like the ability to tow a lot, but still get good fuel mileage when not. The CRD seems to fit that perfectly.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is online now
post #23 of 49 Old 12-23-2013, 05:21 PM
Joeyicu
Joeyicu's Avatar
Most of the cummins B series parts are probably parallel price wise with the hemi. The common rail motors can tend to get a little pricey, but those would be the only ones that would have some parts more expensive then the hemi.
Joeyicu is offline
post #24 of 49 Old 12-25-2013, 12:23 PM
10Xk
2014 WK
Towing, it's a mid size unibody SUV.
Call a jeep local dealer and ask if they have a mechanic to work on a MB 3.0 CRD. While your doing that ask about part availability.
CRD is a limited option on a few years. There is a reason. The 5.7l is tried and true, to the point of it has been and still is used in HD Rams.
If the cost of fuel is a issue then maybe you need to look at a different vehicle.
Hemi has the Chrysler Maxcare lifetime warranty available.
10Xk is offline
post #25 of 49 Old 12-25-2013, 01:58 PM
caddydaddy
2007 WK
It has the same tow rating as my full framed Escalade with a 6.0 gas engine. Not too shabby for an engine half the size!
I'd think of taking it to a MB dealership if it was something that I couldn't fix myself.
Reason is they are more expensive and most Americans aren't fond of diesels and the reputation they used to have.
2" RC lift
194,000+ miles!
post #26 of 49 Old 12-25-2013, 02:13 PM
10Xk
2014 WK
Originally Posted by caddydaddy
It has the same tow rating as my full framed Escalade with a 6.0 gas engine. Not too shabby for an engine half the size! I'd think of taking it to a MB dealership if it was something that I couldn't fix myself. Reason is they are more expensive and most Americans aren't fond of diesels and the reputation they used to have.
See, some think that a smaller vehicle rated to tow the same or more than larger vehicle is better or a sign of strength. Frame on body (caddy)= trucks, unibody (jeep)= cars, minivans. Engine is only part of towing capacity, frame, suspension, brakes have key rolls in the equation. You may notice that the manufactures jointly developed a standard for calculating towing capacity, SAE J2807. Toyota has adopted it and others should soon follow. If it was all about the engine, the 5.7l hemi is in HD rams with 12-13k towing capacity (thats doesn't include the curb weight of the truck 7-8k) and it has been doing this for years!
One reason for limited availability is they couldn't be sold in all 50 states due to emissions.
10Xk is offline
post #27 of 49 Old 12-25-2013, 04:00 PM
caddydaddy
2007 WK
Wouldn't the limits of the suspension, brakes, etc be factored in by the manufacturer when they post the towing limits?
I'm sure that's why even though my Escalade has the same engine as a Silverado or Sierra, cannot tow as much. The suspension on it is not built for it.
2" RC lift
194,000+ miles!
post #28 of 49 Old 12-26-2013, 09:51 AM
Radcrd
2007 WK
Finding parts is not an issue for the CRD as this engine is used on the Sprinter vans and several MB products. Finding a Jeep dealer to work on it may be an issue but if you stick close to this forum and have some mechanical inclination you will be fine.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #29 of 49 Old 12-26-2013, 07:05 PM
Red_liner740
..what reason are you hinting at? It had nothing to do with reliability or longetivity but everything to do with politics, corporate ownership and EPA.
Only reason Jeep got a hold of the CRD was because of the Merc partnership/ownership. Only reason it wasnt continued past the two years was due to EPA ever moving goal line for diesels.
Mercedes decided it was worth keeping the horse in the race and developed the bluetec Adblue technology, while Jeep, just like with the Liberty, gave up the diesels. So the engine continues to live in other platforms just like your beloved 5.7.
The OM642 is in hundreds of thousands of fleet utility vehicles throughout the world from used and abused Sprinters to E320 Taxi cabs all over Europe, so lets not even try to hint at reliability issues.
post #30 of 49 Old 12-26-2013, 08:09 PM
jaje
2007 WK
CRD was only limited to 2 years b/c of the EPA Tier II bin 5 requirements and it was the beginning of the end of the Daimler Benz relationship. If Jeep wanted to get rid of diesels for "other reasons" they would never had offered the EcoDiesel.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
