2008 CRD Starter change info needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2008 CRD Starter change info needed
FS: Wranger BRIGHT License Plate LED! Just $3! Great valuePoison Spyder JK Body Mounted Tire Carrier2014 Spartan Locker Special - While Supplies Last! Dana 3
Unread 05-06-2013, 04:22 PM   #1
Kona4Jeep
2008 WK
Hello, I think the starter may be failing on my 2008 CRD Jeep. Anyone have the thread link for changing it out?
Thanks, Bernie
Kona4Jeep is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 07:44 PM   #2
suzieque
2008 WK
Here you go, you may have to join the aussie website to view the pictures. The instructions are for a right hand drive jeep, so the bad news is that you have go deal with the steering column which will make it much more difficult to remove.
http://www.ausjeepoffroad.com/forum/...hlight=Starter
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline   Reply With Quote Quick reply to this message
Unread 05-08-2013, 10:59 PM   #3
Drewd
Kona,
If you can see it, try this first: A couple good whacks with a hammer. You'd be surprised how often this fixes starters or alternators that have stuck brushes.
Drewd is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 08:12 AM   #4
chrali
2006 XK Commander
You don't say why you think the starter is failing, as in noises etc, so are you sure its the starter and not the wiring harness to the starter, they can corrode....
Encourage alternative fuels - Use as much petrol as you can!
chrali is offline   Reply With Quote Quick reply to this message
Unread 05-10-2013, 01:57 PM   #5
Kona4Jeep
2008 WK
Starter
Turning the key I get a distinctive click from the starter area. Lights dim as if the starter is getting current. It was a Canadian Jeep and def had some rust that I did my best to prevent from spreading. Looks like I can only get to it from the side thru the wheel well opening.
