2008 CRD Leaking Oil - Page 2 - JeepForum.com
post #16 of 19 Old 09-04-2013, 07:51 AM
Zlartibartfast
2007 WK
Wow - I think I read about that happening to r_unda a while back...
@Kolt-46: you said you were going to install a catch can - did you do that, and if so, what are the diameters of the in & out fittings?
Zlartibartfast is offline
post #17 of 19 Old 09-04-2013, 07:58 PM
suzieque
2008 WK
Your ccv is likely broken or the hose from the ccv to the air intake is plugged. Just check both by unplugging the hose at the air intake tube and you should feel air blowing out at idle.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #18 of 19 Old 09-04-2013, 08:31 PM Thread Starter
Kolt-46
2008 WK
http://www.summitracing.com/parts/mio-mmocc-rb
This is what I was going to install but everything blew up before I had the chance.
I had it flat-bedded back to my house and I installed the new CCV (came with a new tube and heater, $33 from Jeep dealership). Everything seems good at the moment. It lost a LOT of oil so I don't want to drive it until tomorrow when I can top it off. It's not even registering on the dipstick at the moment.
Kolt-46 is offline
post #19 of 19 Old 09-05-2013, 08:04 PM Thread Starter
Kolt-46
2008 WK
New CCV installed and the issue appears to be resolved.
Kolt-46 is offline
