2008 CRD Leaking Oil - JeepForum.com
post #1 of 19 Old 09-02-2013, 10:32 AM Thread Starter
Kolt-46
2008 WK
2008 CRD Leaking Oil, Three Sources
My CRD has about 118k on it and has just presented me with the first set of problems ever. My wife noticed small amounts of oil on the driveway so I removed the skid plate and when I looked under the vehicle I found some oil drip paths around the transmission and down the oil pan (appear to be from turbo intake tube seal), and on my alternator. So far I have found three sources of oil leaks.
1. Oil Filler Cap
-Replaced seal, all is good.
2. Turbo Intake
-I have the orange seal and need the part number for the black seal if anybody has it handy.
3. Base of Dipstick Tube
-Has anybody else experienced this? Seems like it should be an easy fix just looking for some advice if anybody has ever dealt with this on their CRD.
I was wondering if the blow-through on the oil cap is due to increased pressure from a faulty CCV. I have no evidence of this (check lights) but I've never seen oil blow through a filler cap. The new seal appears to have resolved this. The CCV is $30 at Advance; should I just replace it?
Any advice is much appreciated.
Kolt-46 is offline
post #2 of 19 Old 09-02-2013, 11:38 AM
westnewton
2007 WK
I had only 70k on mine with similar issue.
I replaced the oil This can also be backwards. Make sure the pic or writing is facing you as you "read" while standing in front of the truck.
I routed the ccv to the bottom of my air box.
I also replaced the air inlet pipe with the "black" version. 53013672AE is the mopar number for the black seal version.
07 WK CRD. GDE-Eco. DPF "Flow Improvement" MIA Resonator. CCV routed to airbox pre-filter. Black turbo inlet tube.
westnewton is offline
post #3 of 19 Old 09-02-2013, 11:40 AM
SSF556
2008 WK
On the alternator may indicate oil being dripped during an oil change....did you change the oil or did the dealer?
Black seal air intake....
http://www.factorymoparparts.com/53013672ae.html
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #4 of 19 Old 09-02-2013, 12:06 PM Thread Starter
Kolt-46
2008 WK
Thank you for the responses!
The cap is properly oriented but the dealership is doing my oil changes (I bought a plan that covers it since it was so much cheaper than the oil alone!). It looks like they just try to squirt oil in the filler hole from across the dealership.
@westnewton
Did you have a similar issue with the grommet at the bottom of the dipstick tube?
Also, I'm going to Summit tomorrow to buy an oil catch can and install it in-line with the vent tube from the CCV.
Kolt-46 is offline
post #5 of 19 Old 09-02-2013, 02:55 PM
Drewd
Side note: Do you really think the dealership is doing your oil change correctly? Do you think a flat rate mechanic has the time to actually pour 1/2 the oil via your oil filter assembly per TSB and then wait a while before starting engine? I suggest you start saving your money for major engine work if you continue relying on a dealership to service your engine oil. BTW, are you 100% sure they are using MB 229.51 oil?
Drewd is offline
post #6 of 19 Old 09-02-2013, 03:17 PM Thread Starter
Kolt-46
2008 WK
I know that they're using the right oil but I don't know about the procedure. I honestly didn't know that there was anything special about the oil changes. Could you send me a link to the procedure? I've actually lost all faith in the dealership out here due to their lack of attention to detail.
Kolt-46 is offline
post #7 of 19 Old 09-02-2013, 06:26 PM
SSF556
2008 WK
I do the 1/2 in oil filter housing and 1/2 in oil fill also....I have heard from various sources (major fleets that run Sprinter vans that they do not do this procedure).
It is vital either way to not spill oil on the alternator.....
2008 CRD QT2
SSF556 is offline
post #8 of 19 Old 09-03-2013, 05:46 AM Thread Starter
Kolt-46
2008 WK
That's a fact! I'm going to hit it with some engine degreaser and try to clean it up.
Kolt-46 is offline
post #9 of 19 Old 09-03-2013, 08:47 AM
jamie1131
2003 WJ
Has anyone ever actually seen a jeep or more importantly a mercedes instruction for the oil change procedure?
I cant find it (maybe I'm not looking in the right place) anywhere except in forums.
There must be hundreds of thousands of these engines and I cant believe the majority of them that are not serviced by enthusiasts are falling apart due to bearing failures?
jamie1131 is offline
post #10 of 19 Old 09-03-2013, 11:42 AM
westnewton
2007 WK
@westnewton
What I did stopped my oil leaking (Probably a combo of bad oil fill cap and CCV pressure) so I did not look at or do anything with the dipstick tube.
post #11 of 19 Old 09-03-2013, 11:47 AM
westnewton
2007 WK
I have not seen the official service doc for the oil change, but have seen many write-ups explaining why we need to fill half through the oil filter housing.
Also, anyone planning on doing their own oil changes should get a Fumoto Oil Drain Valve (F-111). it allows you to connect a 1/8 hose and "route" the oil into a container. This works better than trying to coral/control 10 Liters of oil racing out of the drain plug hole.
post #12 of 19 Old 09-03-2013, 12:11 PM
Zlartibartfast
2007 WK
YES to the Fumoto valve but I think the model for the CRD is the F106 (I bought an F106N that I plan to install in a couple of weeks)
http://www.fumotousa.com/
Jeep: V8 4.7L('99 & 0n), V6 3.7L & 3.8L, 2.0L, 2.4L('07 & on), 3.0L Diesel('07 & 0n),3.6L, V8-5.7L & 6.1L('06 & on) engines F-106
Zlartibartfast is offline
post #13 of 19 Old 09-03-2013, 01:16 PM
westnewton
2007 WK
Correct on the F-106N. The other one I stated is for my motorcycle...
post #14 of 19 Old 09-03-2013, 03:20 PM Thread Starter
Kolt-46
2008 WK
Quarts upon quarts of oil just blew out the dipstick tube all over my engine compartment. I'm guessing that my CCV just went bad...real bad. Any other speculation on probable cause?
Kolt-46 is offline
post #15 of 19 Old 09-04-2013, 03:12 AM
westnewton
2007 WK
I would say you are right on the money.
Or, thinking worst case scenario, your piston(s) are toast. I don't know how much blow-by it would take to push the dipstick out??
