2008 CRD - Fuel (DIESEL) Tank Leaking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2008 CRD - Fuel (DIESEL) Tank Leaking
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" lTERAFLEX 1.5" Leveling kit for JK!!
Unread 04-12-2014, 10:17 AM   #1
ryann04
2008 WK
Just noticed yesterday that there was a puddle under my jeep. The fuel tank seems to be leaking heavily. I did some research and found that because it is a steel gas tank and the "skid plate" is so close to the tank, it traps water and other contaminates that eventually RUST right through the gas tank. Poor design flaw by Jeep.
Now I priced out a new tank.... $1500-$2000 CAD after tax and everything... And then I have to put it in myself. I will also have another poor set-up tank/skid to close together, will rust out again. (6 years and it rusted... WTF!!)
So naturally I am looking for another solution.. aftermarket..
I called up a local racing shop/custom work... I am getting a quote on a custom aluminum fuel tank to replace the factory one. I am looking at ~$1000 for it installed. That's a rough estimate of course until he looks at it.
Now... before I start this **** show... is there any advise of what I can look forward to before tackling this job? Any walls I am going to run into during this?
And to all the other diesel owners, have you ran into this problem yet? If not, maybe take some preventative measures! (take off the skid plate and undercoat the crap out of it!!!)
Thanks!
-Ryan
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 12:07 PM   #2
joeazzj
I would check local wrecking yards I'm shure all the tanks are the same . I'd also check car_part.com you can find one cheaper then that for sure .
97' zj stock till I buy up all my goodies ! 318 242 waiting to go in .
joeazzj is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 12:14 PM   #3
caddydaddy
2007 WK
The CRD has a different tank capacity listed than the gas engines do, so it might be a unique tank.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
171,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 12:18 PM   #4
joeazzj
Well I guess that thing is different all around we did a gear change from 3.73 to 3.07 the front diff is it's own shops look at it and scratch there head lol .
Unread 04-14-2014, 09:41 AM   #5
koj
2010 WK
A few weeks after I sold my CRD-05 the tank started leaking. The guy that bought it had the tank welded. Didnīt cost very much.
If you by a used tank it might start to leak anytime.
WH 2010 CRD. Bilstein shocks, Rustys 2" BB front, OME HD springs rear. 265/70x17
koj is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 10:03 AM   #6
ryann04
2008 WK
I am pricing out a custom aluminum replacement tank. Dealer will want $2000+ for the replacement. This custom one will be $800 roughly. Still waiting for a concrete quote from the guy.
Sent from AutoGuide.com Free App
Unread 04-14-2014, 10:36 AM   #7
willyok
2008 WK
Thats no too bad. Are you gonna increase capacity?
willyok is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 12:04 PM   #8
ryann04
2008 WK
I would like to. We shall see, first off what we can fit in there comfortably and practicality money wise. I'll keep ya posted.
Unread 04-14-2014, 01:26 PM   #9
BAH101
2008 WK
You might be surprised in the extra capacity if you get rid of the rounded corners.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 02:58 PM   #10
ryann04
2008 WK
So I found out a few things today.
1. It is illegal to modify your main fuel tank. This is because of crash ratings, liability, etc...
2. If I put in a "off-road" fuel tank it would cost me $2500~$3000 because of the mis-shaped tank design.
3. part # 68033748AA (fuel tank) is $2110.50 CAD from the Stealership. They want $550.00 for labor.
4. I bought it from the USA for $1200 CAD shipped to my door. I hate getting ripped off in Canada for the extra inflation of car parts!!!! I will put it in myself. I will coat it with rock guard too!!! I will also be adding some sort of spacers to the skid plate to keep a bit more gap there to drain and not rust again!!
I still feel that $1200 for a damn fuel tank is costly. Jeep **** the bed on a poor design, they should bite the bullet!
Unread 04-14-2014, 03:11 PM   #11
joeazzj
Yep I send Cummins injectors to my friend I know the prices lol.
Unread 04-14-2014, 03:38 PM   #12
suzieque
2008 WK
More than 1 jeep crd owner in this forum has had a fuel tank leak. it seems the space between the metal fuel tank and the metal fuel tank skid plate fills with sand/dirt/gravel/water until it eventually rusts and springs a leak. I asked my dealer to remove my skid plate for me so that I could clean up the surface rust on the fuel tank but they said the fuel tank and skid plate are "one unit", in other words the skid plate is holding up the fuel tank.
All I could do was try to power wash between the metal fuel tank and the metal fuel tank skid plate and then let it dry and then spray in some rust inhibitor. I'm hoping that holds the rust, but the best procedure would be a full removal to get access to the area and properly clean/seal it.
I almost wonder if there should be a recall on this issue. I've never heard of a vehicle fuel rusting through after <5 years.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 04:04 PM   #13
ryann04
2008 WK
I contacted Chrysler Canada and put a claim in regarding this issue. I hope they help absorb some of the cost.
Unread 04-14-2014, 07:04 PM   #14
TurboDiesel
2008 WK
damn man thats ****ty...im wonding if i should get the steel skid plate for the fuel tank or not...i dont have any steel ones ATM
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 04-14-2014, 08:14 PM   #15
SSF556
SSF556's Avatar
2008 WK
I thought the tank was plastic????
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
