2008 CRD Check Engine Light P0670 - JeepForum.com
post #1 of 34 Old 01-02-2012, 02:22 PM Thread Starter
johnniebravo
2008 WK
Happy New Year everyone!
Great way to start the new year, hit the remote start button on the Jeep last night and it wouldn't start. It started fine when I used the key. Shortly after starting I got a CEL, got the code checked today and it was P0670. The code says the Glow Plug Control Module is bad. I've seen several people post about the glow plugs specifically by codes but never the GPCM by CEL. Thing is, the CEL went off today when I went out to get the code scanned and pick up parts. I am trying to figure out why the CEL came on and then went off. My guesses are a bad ground at the module on the fuel/water filter, bad/low battery (tested fine today with VM with good fluid level), or the actual module is bad.
As I understand it, there is a glow plug relay and a glow plug control module. If I am wrong someone please correct me. I THINK the GPCM is located at the front passenger side of the engine (USDM cars).
Is this part the glow plug control module? The part number I pulled from mine is A6421532079 /000
http://store.europarts-sd.com/glowplugcontrolunit2007-2009.aspx
Can anyone who has had the GPCM with a CEL P0670 confirm that the part in the link above is the actual module?
Also, part prices are much much cheaper at my local Benz dealer versus the Jeep dealer. I've seen the Jeep part number as 05175759-AB from HERE (or 08-035-027, MB number, but doesn't make sense). What I need is the whole MB part number. Does anyone have the box from the GPCM they got from the dealer?
Thanks for the help and for reference this on a 2008 CRD purchased Sept 2007, 64k ish miles, no other CELs ever.
2008 CRD GC
johnniebravo is offline
post #2 of 34 Old 01-02-2012, 02:49 PM
lunaslide
Junior Member
2008 WK
I had this go out on me awhile back. When I get home, I'll check the paperwork from the dealership to see what part number it was.
I have an extended service contract that covers the module but not the glow plugs themselves (they are considered consumable the same as spark plugs). They changed out the glow plug, that didn't solve it, changed the module, but still tried to charge me for the glow plug. Had to put the kibosh on that and just ended up paying the $150 deductible for the service contract work.
[ 2008 Grand Cherokee Laredo CRD ]
[ GDE ECOtune ][ Airflow Snorkel ][ MBRP T304 Diesel Exhaust ]
[ Superlift 4" ][ Jeep Commander front coils ]
[ AEV Pintler Argent Wheels ][ 285/70R17 BFG Mud-Terrain T/A KM2 ][ 4XGuard FG, BG, RR, Antennae mount ]
lunaslide is offline
post #3 of 34 Old 01-03-2012, 05:48 PM Thread Starter
johnniebravo
2008 WK
Quick update, the CEL came up again this morning after sitting cold all night. Pulled the code and was the same P0670.
I ordered a new Glow Plug Control Module from local Merc dealer for 189. Just to test the water, I checked in with the Jeep dealer next door to the Merc dealer and Jeep wanted $1,000 for the same part!
The original part included with the Jeep has been replaced by a newer part.
The new part number from both Merc and Jeep's parts systems is A6429002800. I will install the new unit tomorrow afternoon and report back.
2008 CRD GC
post #4 of 34 Old 01-03-2012, 07:12 PM
tdoster
2007 WK
You know it's bad when Jeep has a 500% markup over Merc retail.
tdoster is offline
post #5 of 34 Old 01-04-2012, 03:04 PM Thread Starter
johnniebravo
2008 WK
Got the new module installed this afternoon, the new part is about 40% smaller than the old one with a different shape. After two starts, the CEL turned off. The drive to work tomorrow will be the true test.
2008 CRD GC
post #6 of 34 Old 01-12-2012, 09:26 PM
ktmkris
2008 WK
i had the exact same issue with my 08. i had three glowplugs burnt out. stealership told me they guaranteed my module was not bad change the plugs. they said they had changed 4 gp modules to have the problems come back. mine would only set s cel if it was under 50 degrees and a cold start.
you can check the glow plugs without removing them from the vehicle very easily. run a tiny wire from your positive source on your battery, just tap it or scrape it very fast across the top of the glow plug. if there is a spark it good, no spark then replace it. just a simple circuit.
all in all i had 3 plug bad. but you might as well replace all 6. by the way i paid 20 a glow plug, they can still make money at that price. dont think twice about telling the jeep parts department there prices are to high.
ktmkris is offline
post #7 of 34 Old 01-13-2012, 04:41 PM Thread Starter
johnniebravo
2008 WK
I forgot to follow up, the new module fixed the problem. So far all the plugs are fine, I do have a spare on hand.
2008 CRD GC
post #8 of 34 Old 06-19-2012, 12:55 PM
marcram
2008 WK
Glow Plu
Great news that you solved the problem. I have the same code a few weeks after swapping 3 of the 6 glow plugs. Do you by chance have a link to the installation of the module? Also, anywhere to buy it online?
Thanks,
Marc
marcram is offline
post #9 of 34 Old 06-19-2012, 03:51 PM
marcram
2008 WK
Ok, so pretty sure I located the glow plug module located near the front center of the engine. I was able to pry the power connector from the module, but not the connector that leads to the glowplugs. Any suggestions here? Can this be done with the module in the standard location or do you need to remove it from the rest of the assembly. Anyone have instructions for this?
I'm hoping that the this error may be the result of mangled glow plug connectors (especially from trying to grasp the very hard to reach one in the engine rear near driver's seat). All resistance values seem to be correct for the glowplugs, but voltages have not been tested.
Any tips or insight are appreciated.
marcram is offline
post #10 of 34 Old 06-25-2012, 08:06 PM
marcram
2008 WK
Anyone?
I can't get the light to turn off. Would you all recommend taking this in to the Mercedes or Jeep dealer? I figure the Mercedes techs have seen this engine a lot more than the Jeep techs.
marcram is offline
post #11 of 34 Old 06-25-2012, 09:12 PM Thread Starter
johnniebravo
2008 WK
I would recommend replacing the module, its VERY easy to swap out. Get the part from benz not jeep. Once I changed it out, light went off.
I do recall one plug being tougher than the other. I think I used a small screw driver to depress a tab or something, can't remember exactly...its been a while.
if that doesnt do it then you can try the dealer.
2008 CRD GC
post #12 of 34 Old 06-27-2012, 01:16 PM
marcram
2008 WK
Ok, then that is what I'll do. Will post the outcome.
marcram is offline
post #13 of 34 Old 06-27-2012, 03:46 PM
marcram
2008 WK
Ok, glow plug control module is removed and put back, so replacing it should be easy. Local Benz dealer will charge $210 for the module. Not too bad.
Before I order the part, I test the resistance of the harness wiring to the glow plugs. Here is a picture.
On the harness, pins 9, 10, and 11 are removed.
For future reference, the glow plug wiring harness connector is numbered like this
12 NC NC NC 8 7
GND 5 4 3 2 1
Considering looking at the engine from the front with drivers side on the right, and cylindars labeled
F C
E B
D A
Connections are:
? NC NC NC C B
GND ? A F E D.
If anyone can fill in the ?s, it would be appreciated. I bet one of them is the positive battery supply.
marcram is offline
post #14 of 34 Old 06-27-2012, 06:41 PM
suzieque
2008 WK
maybe this is of use, its the glow plug wiring by color, the pictures are from the 2007 sprinter service CD, should be the same wiring for the jeep.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #15 of 34 Old 06-28-2012, 05:27 PM
marcram
2008 WK
Thanks for the diagram.
Has anyone ordered parts from sprinterparts.com? I see the 3.0L control module for $137. Seems like a great deal.
http://www.sprinterparts.com/item.ww...NUINE&sup=OEC&
Marc
marcram is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Help! Check engine light on, crazy engine sounds! vtavarez ZJ Grand Cherokee Forum 3 08-26-2011 04:14 AM
Check engine light and ways to check codes cody11ca ZJ Grand Cherokee Forum 12 01-11-2011 08:04 PM
Long Crank,Engine Light,Throttle Light on 2008 WK CRD CanDieselJeep WK Grand Cherokee & XK Commander Forum 1 05-04-2010 09:18 PM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
