-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   2008 CRD Check Engine Light P0670 (http://www.jeepforum.com/forum/f67/2008-crd-check-engine-light-p0670-1308823/)
johnniebravo 01-02-2012 02:22 PM
Happy New Year everyone!
Great way to start the new year, hit the remote start button on the Jeep last night and it wouldn't start. It started fine when I used the key. Shortly after starting I got a CEL, got the code checked today and it was P0670. The code says the Glow Plug Control Module is bad. I've seen several people post about the glow plugs specifically by codes but never the GPCM by CEL. Thing is, the CEL went off today when I went out to get the code scanned and pick up parts. I am trying to figure out why the CEL came on and then went off. My guesses are a bad ground at the module on the fuel/water filter, bad/low battery (tested fine today with VM with good fluid level), or the actual module is bad.
As I understand it, there is a glow plug relay and a glow plug control module. If I am wrong someone please correct me. I THINK the GPCM is located at the front passenger side of the engine (USDM cars).
Is this part the glow plug control module? The part number I pulled from mine is A6421532079 /000
http://store.europarts-sd.com/glowplugcontrolunit2007-2009.aspx
Can anyone who has had the GPCM with a CEL P0670 confirm that the part in the link above is the actual module?
Also, part prices are much much cheaper at my local Benz dealer versus the Jeep dealer. I've seen the Jeep part number as 05175759-AB from HERE (or 08-035-027, MB number, but doesn't make sense). What I need is the whole MB part number. Does anyone have the box from the GPCM they got from the dealer?
Thanks for the help and for reference this on a 2008 CRD purchased Sept 2007, 64k ish miles, no other CELs ever.
lunaslide 01-02-2012 02:49 PM
I had this go out on me awhile back. When I get home, I'll check the paperwork from the dealership to see what part number it was.
I have an extended service contract that covers the module but not the glow plugs themselves (they are considered consumable the same as spark plugs). They changed out the glow plug, that didn't solve it, changed the module, but still tried to charge me for the glow plug. Had to put the kibosh on that and just ended up paying the $150 deductible for the service contract work.
johnniebravo 01-03-2012 05:48 PM
Quick update, the CEL came up again this morning after sitting cold all night. Pulled the code and was the same P0670.
I ordered a new Glow Plug Control Module from local Merc dealer for 189. Just to test the water, I checked in with the Jeep dealer next door to the Merc dealer and Jeep wanted $1,000 for the same part!
The original part included with the Jeep has been replaced by a newer part.
The new part number from both Merc and Jeep's parts systems is A6429002800. I will install the new unit tomorrow afternoon and report back.
tdoster 01-03-2012 07:12 PM
You know it's bad when Jeep has a 500% markup over Merc retail.
johnniebravo 01-04-2012 03:04 PM
Got the new module installed this afternoon, the new part is about 40% smaller than the old one with a different shape. After two starts, the CEL turned off. The drive to work tomorrow will be the true test.
ktmkris 01-12-2012 09:26 PM
i had the exact same issue with my 08. i had three glowplugs burnt out. stealership told me they guaranteed my module was not bad change the plugs. they said they had changed 4 gp modules to have the problems come back. mine would only set s cel if it was under 50 degrees and a cold start.
you can check the glow plugs without removing them from the vehicle very easily. run a tiny wire from your positive source on your battery, just tap it or scrape it very fast across the top of the glow plug. if there is a spark it good, no spark then replace it. just a simple circuit.
all in all i had 3 plug bad. but you might as well replace all 6. by the way i paid 20 a glow plug, they can still make money at that price. dont think twice about telling the jeep parts department there prices are to high.
johnniebravo 01-13-2012 04:41 PM
I forgot to follow up, the new module fixed the problem. So far all the plugs are fine, I do have a spare on hand.
marcram 06-19-2012 12:55 PM
Glow Plu
Great news that you solved the problem. I have the same code a few weeks after swapping 3 of the 6 glow plugs. Do you by chance have a link to the installation of the module? Also, anywhere to buy it online?
Thanks,
Marc
marcram 06-19-2012 03:51 PM
Ok, so pretty sure I located the glow plug module located near the front center of the engine. I was able to pry the power connector from the module, but not the connector that leads to the glowplugs. Any suggestions here? Can this be done with the module in the standard location or do you need to remove it from the rest of the assembly. Anyone have instructions for this?
I'm hoping that the this error may be the result of mangled glow plug connectors (especially from trying to grasp the very hard to reach one in the engine rear near driver's seat). All resistance values seem to be correct for the glowplugs, but voltages have not been tested.
Any tips or insight are appreciated.
marcram 06-25-2012 08:06 PM
Anyone?
I can't get the light to turn off. Would you all recommend taking this in to the Mercedes or Jeep dealer? I figure the Mercedes techs have seen this engine a lot more than the Jeep techs.
johnniebravo 06-25-2012 09:12 PM
I would recommend replacing the module, its VERY easy to swap out. Get the part from benz not jeep. Once I changed it out, light went off.
I do recall one plug being tougher than the other. I think I used a small screw driver to depress a tab or something, can't remember exactly...its been a while.
if that doesnt do it then you can try the dealer.
marcram 06-27-2012 01:16 PM
Ok, then that is what I'll do. Will post the outcome.
marcram 06-27-2012 03:46 PM
Ok, glow plug control module is removed and put back, so replacing it should be easy. Local Benz dealer will charge $210 for the module. Not too bad.
Before I order the part, I test the resistance of the harness wiring to the glow plugs. Here is a picture.
http://farm9.staticflickr.com/8027/7...253c61e3_o.gif
On the harness, pins 9, 10, and 11 are removed.
For future reference, the glow plug wiring harness connector is numbered like this
12 NC NC NC 8 7
GND 5 4 3 2 1
Considering looking at the engine from the front with drivers side on the right, and cylindars labeled
F C
E B
D A
Connections are:
? NC NC NC C B
GND ? A F E D.
If anyone can fill in the ?s, it would be appreciated. I bet one of them is the positive battery supply.
suzieque 06-27-2012 06:41 PM
4 Attachment(s)
maybe this is of use, its the glow plug wiring by color, the pictures are from the 2007 sprinter service CD, should be the same wiring for the jeep.
marcram 06-28-2012 05:27 PM
Thanks for the diagram.
Has anyone ordered parts from sprinterparts.com? I see the 3.0L control module for $137. Seems like a great deal.
http://www.sprinterparts.com/item.ww...NUINE&sup=OEC&
Marc
The time now is 03:11 AM.
