2008 4.7 Superchips 3870 Basic Review - JeepForum.com
post #1 of 9 Old 10-19-2013, 01:15 PM Thread Starter
redshift88
2008 WK
Hi all,
I recently bought a Superchips 3870 from Kolak (great price, fast delivery, and responsive guy).
For reference: http://www.superchips.com/Store/JeepFlashpaq.aspx
Since there are so few 08 4.7's out there, I thought it'd might be helpful to folks on the fence.
It has a myriad of options that I haven't yet played with. For example, out of the box, I can control up shift/down shift, load shift RPMS, tire size/speedometer adjustment, fan-on RPMs, idle speed, CEL codes, ect.
What I have tried is below:
93-Performance (tried)
91-Performance (not tried)
87-Performance (tried)
Towing (not tried)
Mileage XS (tried)
Crawl/OffRoad (not tried)
On all of these, the effect I noticed was that when I just lean on the throttle, the engine comes alive instantly. I think/guess this is a result of me giving the throttle 5%, and the ETB actually opening the throttle a lot more. Also, the shifts happen at much more reasonable times. The vehicle isn't always trying to get to 5th and do everything it can to stay there (stock).
87-Octane-Performance:
WOT performance is marginally better than stock. Everything below WOT is much better. It's extremely responsive and well rounded and, as I mentioned before, the shift points are in the ballpark of where they should have been from the begining. It almost has the acceleration of the 93-Octane tune, but is not too aggressive with ignition timing and makes it easy to maintain a constant speed. For example, I'd have to put the throttle past 75% while stock to get the thing to downshift while going 30 mph. Now, it does it at almost half of that. However, when I am going 30 mph, and give the gas a few percent throttle, it stays at 30 mph. It has pretty even acceleration at all speeds and loads. This one is my favorite. It's fast, easy to drive, and fun. I'd recommend this tune for city driving.
93-Octane-Performance:
WOT performance is a little better than the 87-Octane tune. Everything below WOT feels like the jeep is trying to get to the top speed. It turns your accelerator into an ON/OFF switch. Holding a constant speed in the city is actually pretty tricky. I attribute this to the ignition timing advance. Just putting pressure on the accelerator, the front end lifts up and it tries to accelerate. As you can imagine, this invites speeding tickets, but it's fun. I took the jeep into the woods with this tune (not intentionally) and it makes driving in 4-Low very hard. Everytime I run over a rock or log, my foot would bounce, hit the gas, and all 300-350 hp would come out at once and launch the jeep forward. This tune makes trail-foot dangerous.
Mileage-XS:
Feels like stock with the exception of faster throttle response. Worse WOT performance. I had to merge onto the highway on the way to Buffalo and actually started to get a bit worried. The on-ramps in Upstate New York are made for sports cars.
There was a mileage increase on all tunes. However, I have to make the disclaimer, that I was discovering the advantage of the front air-dam at the same time. So my experiences have two variables. The front air-dam makes a huge difference in mileage (no skid plate).
According the the mileage computer cruising Upstate NY hills at 55 to 65 mph for about 3 hours each....
Stock: 18-21 mpg w/air dam
87 Octane: Didn't pay attention
Mileage XS: 20-22 mpg w/o air dam
93 Octane: 18-20 mpg w/o air dam, 20-23 mpg w/air dam (I don't undersand why it's so high, better atomization of 93 octane?)
These numbers are based on me babying the gas to get the best mileage. Real world numbers will be less.
Summary: Buy one, it will pay for itself eventually. The major improvement over stock is the instant throttle response, but not neccesarily faster quarter mile times. It makes driving this heavy beast more reasonable. Also, it's great to reprogram your spedo with bigger tires/gears and read and clear CEL codes. The claims for my engine is something on the order of 50 HP increase. I believe it, but it's not a 50HP increase over peak power. It's probably 50HP over your weakest point in the map (hence the even acceleration).
If you have multiple jeeps, you have to flash one back to stock to flash the other.
redshift88 is offline
post #2 of 9 Old 10-19-2013, 03:36 PM
Kolak
Vendor
Kolak's Avatar
Wow! The overview you wrote is very impressive and thorough. Thanks for that and thanks for your business.
To everyone thinking about getting a Superchips, check out my special over in the Vendor Forum:
http://www.jeepforum.com/forum/f43/s...-sale-1646121/
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #3 of 9 Old 10-19-2013, 09:30 PM
modernblueWK
I need one.....
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #4 of 9 Old 10-20-2013, 07:22 AM
Kman09JGC
Im running 3875 with the 91 perf. tune w/trans app on my 09 4.7 and it really makes the 4.7 come alive. Whats the main difference between the 3875 and 3870 for 08-09 4.7's.
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline
post #5 of 9 Old 10-20-2013, 12:40 PM
Kolak
Vendor
Kolak's Avatar
That 3870 has a new, faster processor, more memory and better menus.
or
Kolak is online now
post #6 of 9 Old 10-20-2013, 03:54 PM
yzjwk
2005 WK
If it has more memory , does that mean superchips may be getting ready to enable it for multiple vin programming? since that was the reason it couldn't be done with the 3875 ..
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 9 Old 02-10-2014, 07:07 PM
jwb998
I just installed the 3870 on my 08 5.7. Have only used the 87 tune, look forward to playing with the others. I love the improved response. I have always thought there was a bad delay when you pushed the gas, it is improved now. The transmission is much quicker to down shift. Had to play a little with the tire size though.
jwb998 is offline
post #8 of 9 Old 02-10-2014, 09:10 PM
CactusPillow
2005 WK
I like the 87 tune as well. Tried the 91 performance tune w/ 91 octane gas for awhile and it ran pretty rough at startup.
05 WK 5.7L Hemi, QDII, 2" RC Spacer Lift, K & N CAI, Billet Catch Can, ARB on board air, Gibson 3" Catback, Superchips 3870 Tuner, Uniden CB w/ 4' Firestik, LED interiors, HIR Lows-Highs-Fogs, Spyder Tail Lights, Tail Light Guards, Debadged, Lowrance Elite-5m Baja Chartplotter
CactusPillow is offline
post #9 of 9 Old 02-11-2014, 11:16 AM
Jaashua
2005 WK
Wow, thanks for this write up. I plan to get one shortly.
Jaashua is offline
