2007 WK Loud Hum and Vibration - JeepForum.com
post #1 of 8 Old 08-17-2017, 09:17 AM Thread Starter
8valve
2007 WK
I just got a smoking deal on a 2007 WK, its like new in all aspects with 78K miles.
I have a loud hum from the front and slight vibration can be felt in the steering wheel. Its speed dependent, does not start till I go over 20 MPH. If I make a quick steering wheel turn to the right, the sound immediatelly stops. Bring wheel back straight, hum and vibration is back. Tire pressure is 33 psi, tires are almost new.
Does this description sound like front wheel bearings ? or What ?
If wheel bearings, what is a typical dealer cost to replace. Thank You
8Valve
Build Super Kill Strong, Play Hard, Drive It Home
Toy Box; http://imageevent.com/moosecreekmaple
8valve is offline
post #2 of 8 Old 08-17-2017, 10:16 AM
HawthorneOffRD
Does the humming get louder when you steer to the left or right?
Sent from my XT1585 using Tapatalk
HawthorneOffRD is offline
post #3 of 8 Old 08-17-2017, 11:51 AM
jeepstercanada
Bad wheeling. Lift all 4 tires off ground and drive it while someone listens to see which bearing is bad
jeepstercanada is offline
post #4 of 8 Old 08-17-2017, 02:10 PM Thread Starter
8valve
2007 WK
I live on a back country black top road, with lots of sharp turns. Running 35-40 mpg, going around a right corner, the hum and vibration stops till I come out of the corner, then without the corner load on the front, the loud hum and vibration start immediatelly. Left corners do not seem to effect the hum/vibration.
8Valve
8valve is offline
post #5 of 8 Old 08-17-2017, 10:02 PM
jeepstercanada
Wheel bearing for sure
post #6 of 8 Old 08-18-2017, 08:43 AM Thread Starter
8valve
2007 WK
What kind of money are Jeep dealers charging to replace both front wheel bearings. No sense in doing just the bad one with the other to follow soon.
8Valve
8valve is offline
post #7 of 8 Old 08-18-2017, 09:28 AM
08CanuckCRD
2008 WK
8Valve
Here in Canada a Moog bearing runs $300CAD. Easily that much for labour, making one bearing a $600 job. Ridiculous for the 5 bolts you need to remove to swap them out (2 brake caliper bolts, 3 bearing bolts). It's an easy driveway DIY job. Did mine for the first time in an hour. I went with Moog bearings. I paid local retail due to time constraints but Rock Auto has them for $150CAD. Less if you're in the States.
Truly, this is not a job that requires a trip to the stealership. If you can pull on a wrench, you can change your wheel bearings. Check out this DIY video:
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline
post #8 of 8 Old 08-18-2017, 07:52 PM Thread Starter
8valve
2007 WK
Truly, this is not a job that requires a trip to the stealership. If you can pull on a wrench, you can change your wheel bearings. Check out this DIY video: https://www.youtube.com/watch?v=xPl9CadAdsk
Thanks to all for the help. I will check out the U Tube on bearing change. The WK has a set of quite worn down Goodyear Fortera tires. I have read on the web that when these tires wear down, they get real noisy. I, today, bought a new set of Cooper Discover A/T-3 tires. I will have them on tuesday morning, next week. This will prove without question tires or bearings. Many thanks
8Valve
8valve is offline
