2007 overland won't heat up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2007 overland won't heat up
Unread 11-26-2013, 01:23 PM   #1
biggysized
Since it started getting cold I've noticed that my heat doesn't seem to be working. I will let my jeep warm up try the heat and nothing but cold air. Sometimes it works and sometimes it doesn't. I am leaning towards the thermostat.
I have been looking for any writeups on how to replace it in the diy section but can't find anything is it hard to do ? Any advice would be greatly appreciated on what you guys think it might be. I also thought it might be the heater core but I haven't had the slightest smell of coolant or any signs of it going. Thanks for reading .
biggysized is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 02:20 PM   #2
yzjwk
2005 WK
If the temperature guage is moving shortly after startup and the engine reaches normal operating temperature , then your thermostat is most likely working and i would look at a blend door issue of some sort .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 02:22 PM   #3
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Sounds like the tstat is sticking.
Edit - I agree with yzjwk, though, if it's just your heat and the Jeep is running up to operating temp then I'd look at your heater core.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 06:29 PM   #4
biggysized
I will drive it tonight and update you all about the temp gage in the dash.
Unread 11-26-2013, 06:39 PM   #5
Blue_Sassley
2008 WK
Also check coolant levels, no coolant in the engine equals bad.
2008 Grand Cherokee Laredo CRD - QDII - GDE Tune Oct 2013 - DPF delete by tnadanzig
2002 Grand Cherokee Laredo 4.7L - ST - Stock (Wreaked)
1999 Grand Cherokee Laredo 4.0L - QTII - Stock
1997 Grand Cherokee Laredo 4.0L - ST - Stock (Wreaked)
Blue_Sassley is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 08:32 PM   #6
biggysized
Okay guys so I drove it and Temp gauge seems to be normal on gauge only thing I noticed was the gauge was getting a little over than normal but when i stopped I heard the fan cut on and temp gauge went back to normal now another thing I noticed was I had heat on full blast and it was working normal but when I turned it to defrost and then turned it back to top vents as normal it was really cold and then a few seconds later it heated up again as normal.
I am very hesitant to switch it between defrost and top vents because I am starting to think it is a blend door issue hopefully not because im sure its pricey.
I am going to check coolant levels it has been a while since ive done that. Thanks for all the help guys.
Unread 11-29-2013, 08:07 PM   #7
biggysized
Topped off my coolant levels and problem solved thanks for the help guys
Unread 11-29-2013, 09:13 PM   #8
flexyxj
2009 XK Commander
Check your waterpump and radiator. It would be wise to figure out where the coolant is going.....
flexyxj is offline   Reply With Quote Quick reply to this message
Unread 11-30-2013, 09:24 AM   #9
biggysized
Good idea yea when I topped it off it has basically solves all my problems and it's been a while since I checked coolant levels probably in 15k miles I know bad on me I don't have vehicle a lot my wife drives it ima do a flush here soon check for any leaks while I'm at it
