2007 overland won't heat up - JeepForum.com
post #1 of 9 Old 11-26-2013, 12:23 PM Thread Starter
biggysized
Since it started getting cold I've noticed that my heat doesn't seem to be working. I will let my jeep warm up try the heat and nothing but cold air. Sometimes it works and sometimes it doesn't. I am leaning towards the thermostat.
I have been looking for any writeups on how to replace it in the diy section but can't find anything is it hard to do ? Any advice would be greatly appreciated on what you guys think it might be. I also thought it might be the heater core but I haven't had the slightest smell of coolant or any signs of it going. Thanks for reading .
biggysized is offline
post #2 of 9 Old 11-26-2013, 01:20 PM
yzjwk
2005 WK
If the temperature guage is moving shortly after startup and the engine reaches normal operating temperature , then your thermostat is most likely working and i would look at a blend door issue of some sort .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 9 Old 11-26-2013, 01:22 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Sounds like the tstat is sticking.
Edit - I agree with yzjwk, though, if it's just your heat and the Jeep is running up to operating temp then I'd look at your heater core.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 9 Old 11-26-2013, 05:29 PM Thread Starter
biggysized
I will drive it tonight and update you all about the temp gage in the dash.
post #5 of 9 Old 11-26-2013, 05:39 PM
Blue_Sassley
2008 WK
Also check coolant levels, no coolant in the engine equals bad.
2008 Grand Cherokee Laredo CRD - QDII - GDE Tune Oct 2013 - DPF delete by tnadanzig
2002 Grand Cherokee Laredo 4.7L - ST - Stock (Wreaked)
1999 Grand Cherokee Laredo 4.0L - QTII - Stock
1997 Grand Cherokee Laredo 4.0L - ST - Stock (Wreaked)
Blue_Sassley is offline
post #6 of 9 Old 11-26-2013, 07:32 PM Thread Starter
biggysized
Okay guys so I drove it and Temp gauge seems to be normal on gauge only thing I noticed was the gauge was getting a little over than normal but when i stopped I heard the fan cut on and temp gauge went back to normal now another thing I noticed was I had heat on full blast and it was working normal but when I turned it to defrost and then turned it back to top vents as normal it was really cold and then a few seconds later it heated up again as normal.
I am very hesitant to switch it between defrost and top vents because I am starting to think it is a blend door issue hopefully not because im sure its pricey.
I am going to check coolant levels it has been a while since ive done that. Thanks for all the help guys.
post #7 of 9 Old 11-29-2013, 07:07 PM Thread Starter
biggysized
Topped off my coolant levels and problem solved thanks for the help guys
post #8 of 9 Old 11-29-2013, 08:13 PM
flexyxj
2009 XK Commander
Check your waterpump and radiator. It would be wise to figure out where the coolant is going.....
flexyxj is offline
post #9 of 9 Old 11-30-2013, 08:24 AM Thread Starter
biggysized
Good idea yea when I topped it off it has basically solves all my problems and it's been a while since I checked coolant levels probably in 15k miles I know bad on me I don't have vehicle a lot my wife drives it ima do a flush here soon check for any leaks while I'm at it
