2007 JGK 3.0 CRD dead A/C - Page 2 - JeepForum.com
post #16 of 23 Old 07-03-2013, 09:36 AM Thread Starter
b52rule
2007 WK
Originally Posted by WieSeL View Post
Check power to the compressor while commanded on. If you have power and clutch does not engage you need a compressor as there is an open in the clutch circuit at the comp.
Thanks. I think it an electrical issue as there is plenty of freon, all the fuses and relays work, all the switches on the dash work. There is just no power to the compressor.
b52rule is offline
post #17 of 23 Old 07-05-2013, 12:10 AM
terrasmak
2007 WK
Guess I need to start playing with this in the morning
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #18 of 23 Old 07-05-2013, 07:43 PM
terrasmak
2007 WK
AC condenser is cracked on the drivers side upper mounting bracket. The condenser was replaced last year, defiantly not from debris damage
post #19 of 23 Old 07-10-2013, 12:51 PM
torqrise
2007 WK
Just out of interest how much is a new AC condenser? Are there any aftermarket options? Mine is dead also - and was also replaced last year while still under extended warranty.
torqrise is offline
post #20 of 23 Old 07-10-2013, 10:36 PM
WieSeL
What do you mean the condenser is dead? Is it leaking for some reason, accident or front end damage? They usually don't leak except at the line input or ouput. Probably looking around $150 minimum and yes they have aftermarket options
WieSeL is offline
post #21 of 23 Old 07-10-2013, 10:37 PM Thread Starter
b52rule
2007 WK
$285 at the dealer who replaced it in April 2012.
b52rule is offline
post #22 of 23 Old 07-11-2013, 12:28 AM Thread Starter
b52rule
2007 WK
No front end damage, no accident, same dealer who replaced it last year.
"AC condenser is cracked on the drivers side upper mounting bracket. The condenser was replaced last year, defiantly not from debris damage"
b52rule is offline
post #23 of 23 Old 07-11-2013, 11:05 AM
torqrise
2007 WK
Meant to say AC system is dead.
I'm not sure if it is charged. How do you check the 'reset' valve mentioned above?
torqrise is offline
