2007 JGK 3.0 CRD dead A/C - JeepForum.com
post #1 of 23 Old 06-24-2013, 12:45 PM Thread Starter
b52rule
2007 WK
The A/c just quit, dead, nothing. There is plenty of R134A in the system. I can't seem to get the compressor to kick in regardless if I use manual or auto settings. It will respond to heat settings but any A/c requests just brings in outside air.
I have checked the fuses and relays. One of the relays does get warm but that is about all.
Suggestions?
b52rule is offline
post #2 of 23 Old 06-24-2013, 02:06 PM
JRLT
2010 WK
Maybe it's overfilled.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 23 Old 06-24-2013, 02:22 PM Thread Starter
b52rule
2007 WK
Thanks for the reply. Dead center in the blue right where is should be.
b52rule is offline
post #4 of 23 Old 06-24-2013, 11:47 PM
terrasmak
2007 WK
Looks like I know what I'll be fixing when I'm home over the 4th. At least we will have a full selection of parts to swap off mine for troubleshooting.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #5 of 23 Old 06-25-2013, 01:19 AM
jamie1131
2003 WJ
I had the same issue with my CRD. The shop told me i needed a new compressor.
I took the AC clutch relay out and checked it by putting it into the front fog lamp circuit. It worked just fine. I was lazy so i left it in that circuit and put the fog lamp relay back into the AC circuit and the compressor kicked straight into life.
I'm wondering if the relay was sticking and there wasn't enough power in the AC control circuit to drive it open.
jamie1131 is offline
post #6 of 23 Old 06-25-2013, 06:37 PM Thread Starter
b52rule
2007 WK
I'll give it a try and report back.
Thanks!
b52rule is offline
post #7 of 23 Old 06-25-2013, 10:41 PM
Drewd
Would have never had this problem if you had a gasser
Drewd is offline
post #8 of 23 Old 06-25-2013, 11:07 PM
terrasmak
2007 WK
LoL , something else would have just broke.
post #9 of 23 Old 06-27-2013, 11:17 AM Thread Starter
b52rule
2007 WK
I tried that last night, no go............and no A/C
I'm open for more suggestions.
I have to take it into the dealer for a Safety Recall N23/NHTSA 13V-175. That is the last place I'd like to get it fixed however.
b52rule is offline
post #10 of 23 Old 06-30-2013, 04:58 PM Thread Starter
b52rule
2007 WK
Pulled and reset the high pressure connector below the receiver/dryer.............no go.
b52rule is offline
post #11 of 23 Old 07-02-2013, 11:55 AM
jediknight
2008 WK
... any codes ? Check engine ... ??
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #12 of 23 Old 07-02-2013, 11:56 AM
jamie1131
2003 WJ
Is there power going to the relay? If yes, is there power going to the compressor clutch?
post #13 of 23 Old 07-02-2013, 11:32 PM Thread Starter
b52rule
2007 WK
No check engine lights, no codes. Our son will be here tomorrow, has the same vehicle so we will troubleshoot it together.
b52rule is offline
post #14 of 23 Old 07-02-2013, 11:33 PM Thread Starter
b52rule
2007 WK
I'll check power in both locations tomorrow. Our son will be here tomorrow, has the same vehicle so we will troubleshoot it together.
b52rule is offline
post #15 of 23 Old 07-03-2013, 08:10 AM
WieSeL
Check power to the compressor while commanded on. If you have power and clutch does not engage you need a compressor as there is an open in the clutch circuit at the comp.
WieSeL is offline
