2007 Jeep Grand Transmission Leaking - JeepForum.com
post #1 of 28 Old 12-31-2009, 09:01 AM Thread Starter
Loc
MY wifes 2007 Grand is leaking tranny fluid. Is there a recall on this vehicle or is this a normal problem these have. I only have 24000 miles, but I think my warranty is out.
Loc is offline
post #2 of 28 Old 12-31-2009, 09:11 AM
robpp
no recll, but could be a tsb.....
Jeep Grand Cherokee WK - Technical Service Bulletins
also the lines from the rad are common issue with trans leaks....
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #3 of 28 Old 12-31-2009, 11:31 AM
Fizzle1979
2010 JK Wrangler
Why would you warranty be out if you only have 24K miles?
| 2010 JK Unlimited Mountain | Rescue Green | Rugged Ridge Front Bumper | Rugged Ridge Winch Spacer | Rugged Ridge Rear Bumper | Rugged Ridge Tire Carrier | Warn Powerplant HD | Mopar Rock Sliders | Synergy Suspension Front & Rear Grab Handles | AEV 2.5" Lift | AEV Savegre Black Wheels | BFGR 35x12.50x17 KM2s | Rigid Dually LED | Boom Mat
Fizzle1979 is offline
post #4 of 28 Old 12-31-2009, 02:33 PM
Dr. Internet
Could be bad O-ring seal
Just got mine back from the dealer. It has 25,500 miles and started leaking transmission fluid a couple of days ago. According to the mech, there is a plug/socket in the housing that has crummy O-ring seals. He put in a new one, with new O-rings under warranty. BTW, at 24k you should still be covered.
Good Luck!
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #5 of 28 Old 12-31-2009, 03:00 PM Thread Starter
Loc
NO warranty it ran out 15 days ago. I am so pissed off right now. I bought it used and the dealer said that it would be covered threw 2010 and now I have a problem and they say the inservice date was Dec 17, 2006 so now its out of warranty. Any idea where the plug was. Was yours leeking from the front or the back? Also what did they say it would have cost?
Loc is offline
post #6 of 28 Old 01-01-2010, 02:06 AM Thread Starter
Loc
Checked it out tonight and more bad news. The three bolts on the passenger side of the tranny pan are stripped out. Not the bolts, but the holes the bolts go into. So now I am at a loss for words. What did they sell me.
Loc is offline
post #7 of 28 Old 01-01-2010, 09:13 AM
johnniebravo
2008 WK
You can prob fix the stripped holes, pick up a tap and die set and if you have room, you can up the hole to the next size bolt. It is easy to do and isn't expensive. If its a metric bolt you can up it 1 or 2 mm or switch it to standard if the size jump is minimal. Drill and tap the new size in, pick up a new bolt of the same dimensions from home depot...fixed. It shouldn't take much as those bolts aren't designed to be torqued that high.
Also, call chrysler about the warranty, they may help you out on this one considering you were in service not long ago.
2008 CRD GC
johnniebravo is offline
post #8 of 28 Old 01-01-2010, 01:47 PM
merlinTec
merlinTec's Avatar
probably only the adapter plug/ electrical plug on the box cost of the part is very cheap (change the adapter not the seals, new adapter comes with seals). and it's only 1 bolt for the heat shield and 1 bolt in the plug to change. Very common fault on the merc box. Takes longer getting the oil level correct then changing the part.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #9 of 28 Old 01-18-2010, 03:45 PM
fishinbama
2007 WK
My wifes 07 crd also leaking transmission fluid!. At the shop now. How did yours go?
fishinbama is offline
post #10 of 28 Old 01-18-2010, 05:32 PM
Dr. Internet
No more problems, since they replaced the socket and seal.
Steve
post #11 of 28 Old 03-03-2010, 05:08 AM
ltningjace
how much did it cost? Mine is out of warranty.
ltningjace is offline
post #12 of 28 Old 03-17-2010, 01:20 PM
ianrmz250
2007 WK
Hi could someone tell me where the adapter plug is situated on the autobox.I have just removed the plastic covers under the engine and gearbox of my WK to carry out an oil change and found lots of ATF fluid on them, i have not had time to investigate the leak yet but will try to get under the jeep at the weekend.
ianrmz250 is offline
post #13 of 28 Old 03-18-2010, 05:40 PM
merlinTec
merlinTec's Avatar
next to the bell housing you will see a silver shield covering the adapter plug, can't miss it.
post #14 of 28 Old 03-19-2010, 09:10 AM
ianrmz250
2007 WK
Thanks for the info Merlin.I did an oil change today using your write up so have been under the car and found the 13 pin adapter plug. I have not investigated the plug any further than this but will do so next week.By looking at my Jeep service CD there is a bayonet lock that has to be released to remove the plug and reading your earlier post there is a bolt holding the socket in place. Is it best to drain the oil first and then replace through the dipstick hole and then get level checked at dealer.
post #15 of 28 Old 03-19-2010, 09:14 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
You can buy it here 10 Bucks, cheap!
Here's one on a sprinter. It's the same NAG1 on the crd WK
[IMG][/IMG]
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
Can not find Grand Cherokke 2007 Transmission Dip Stick ekam WK Grand Cherokee & XK Commander Forum 13 02-24-2010 09:03 AM
2007 Jeep Grand Cherokee laredo....to buy or not to buy? superarmen WK Grand Cherokee & XK Commander Forum 1 11-06-2008 08:10 AM
2007 Jeep grand cherokee REC navigation chemdog71 WK Grand Cherokee & XK Commander Forum 5 08-09-2008 07:41 PM
2007 Jeep Grand Cherokee SRT8 Hennessey SRT600 T! 01JeepXJ WK Grand Cherokee & XK Commander Forum 4 10-22-2006 05:24 PM
Leaking transmission on 02 Grand Whybu1 WJ Grand Cherokee Forum 4 07-15-2003 08:38 AM
