2007 Grand Cherokee WK - how to install an electric brake controller from sketch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2007 Grand Cherokee WK - how to install an electric brake controller from sketch
Labor Day Sale at UCF!Gibson WK HEMI 3" Catback - 5 Day Special!Ruffstuff XJ Unirail Channel Reinforcement....
Unread Yesterday, 12:14 AM   #1
kk52736
2007 WK
I just installed an electric brake controller on my 2007 Grand Cherokee Overland WK with tow package BUT without factory brake controller plug.
I just bought a very good price used Tekonsha P2 brake controller to be occasionally use for towing my 26' travel trailer.
I am putting the controller in the hole beside the left steering wheel. Put away in glove box when not in use.
Items needed
-pigtail wire harness originally comes with the brake controller
-5 feet insulated 14 guage 2 wires inside
-auto reset automotive 30amp circuits breaker
-some clips and end to connect wires
-pliers, cutter, screw driver...etc
Cut a hole to fit the harness end
Different view
Attachment 2350226
Open the kick panel, swing all the way down to take it off, unscrew the 2 screws on the corner of the black panel under the kick panel right above the brake and gas pedals
Find the green wire which is for the trailer brake, it is hidden on the left very high bundle up with a huge wire harness, you can just put your hand right behind the fuse panel near the firewall and there is a wire loop around there, just pull the loop to find the end. Connect that to the blue wire on the controller harness for trailer brake.
Connect the red wire from the controller harness to the jeep's brake light signal, the plug is right above the brake pedal, not the one in the front, there is another flat plug with 6 wires higher on the right more to the back or behind the pedal arm, the 2nd wire on the right (white with tan)
Feed the 12v power and ground through firewall, there is an extra firewall entrance with a rubber cap right behind the engine on the right side; when look from the inside, it is right above the gas pedal.
White to the white on the controller harness for ground.
Black to the black on the controller harness for 12v power.
Attach the white wire to the battery negative. And remove the whole negative terminal to work on the battery now.
Cut the black somewhere between the firewall and battery to put the circuits breaker then attach to the positive battery.
Double check all wires, and reconnect the negative battery.
Reverse all the steps to install panels back, and feed the plug through the hole on the left pocket.
Plug in the brake controller, hola! Nice install, working great.
Better view
2007 Grand Cherokee Overland 5.7L HEMI
kk52736 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:20 PM   #2
terrasmak
2007 WK
Nice write up, I have mine sitting here ready for install
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:12 PM   #3
kk52736
2007 WK
Let me know if you need help, the green wire is little stubborn hidden bundled with other harness, took me 2 hrs to find that, but only took 1 hr to install everything after
Unread Yesterday, 06:38 PM   #4
TangoTango
2008 WK
Nice write up.
One question ... that white wire can just ground to any body part instead of the battery can't it?
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 06:55 PM   #5
kk52736
2007 WK
According to the instruction manual from the brake controller, 12v power must connect directly to the battery positive, and the ground directly to the battery negative, and I WON'T be lazy and risk your life that the trailer has no brake if any connection error, that's why the instruction also said only use a "Auto Reset circuits breaker" and NOT fuse.
And because you already wire the black to the battery anyway, not much more work to tap the white ground wire to the battery negative
Unread Yesterday, 07:27 PM   #6
TangoTango
2008 WK
I have to do mine which is why I was asking.....
What auto reset automotive 30amp circuits breaker did you go with? You have a part # ?
Black WK Club #147
Unread Yesterday, 08:00 PM   #7
kk52736
2007 WK
There is no part number for the breaker, its just a generic automotive circuit breaker 30amp I used
