Quantcast 2007 grand cherokee window condensation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2007 grand cherokee window condensation
Old 03-07-2008, 10:32 PM   #1
ottumwa
Hi, I purchased a new 2007 grand cherokee almost a month ago and the windows have a condensation problem that I can not figure out, I have taken it to the dealer a couple of times and they have checked the temp at the vents and the moisture coming from them and everything is ok, I'm wondering if there is a bad seal somewhere letting in moisture. Any feedback would be helpful at this point.
Thanks.
ottumwa is offline   Reply With Quote
Old 03-07-2008, 10:44 PM   #2
GibsJeep
Try posting that in the WK/XK tech forum.
Link- http://www.jeepforum.com/forum/f67/
My 05 TJ
GibsJeep is offline   Reply With Quote
Old 03-07-2008, 11:37 PM   #3
rsq41
2007 WK
Do you have a Laredo, Limited or Overland? Is it condensing on all windows or just side windows? What is the temperature outside when it happens? What are the heat controls set at? I got a Limited 2 months ago. With the automatic climate control on, cold temps outside and plenty of snow dragged in on my feet, jacket, etc. I’ve noticed condensation on the side windows. I either ignore it and it eventually goes away or I turn the system to defrost.
WKJeeps mentions this at the bottom of the automatic climate control page, so for what ever reason, it must be common. I suspect that in “auto” mode it is re-circulating some portion of cabin air while in "defrost" mode it will pull 100% outside air. But I hope I never have to learn that much about the HVAC system in the Grand...
http://www.wkjeeps.com/wk_climate_faq.htm
rsq41 is offline   Reply With Quote
Old 03-08-2008, 09:33 AM   #4
ottumwa
Link- http://www.jeepforum.com/forum/forumdisplay.php?f=67
Hey thanks
Old 03-08-2008, 09:39 AM   #5
ottumwa
It is a laredo, and the problem seems to be mainley the side windows but the windshield will do it if you don't run the defrost, the temp outside is between 20 to 30 degrees, There just seems to be alot of moisture I have owned several vehicles and never came across this problem before.
Thanks.
Old 03-08-2008, 11:56 AM   #6
garsarno
Depends on the outside humidity, when there is inside condensation, I run the a/c with the temperature up and it clears it. Seems to happen on those cold rainy mornings.
garsarno is offline   Reply With Quote
Old 03-09-2008, 10:27 AM   #7
ottumwa
Thanks I'll give it a try
Old 03-09-2008, 09:12 PM   #8
NDSU_Bison
2008 WK
I was pleasantly surprised by the lack of fogging on my 08. Our old Durango's windows fogged up every winter morning (temps usually in the high 20s to low 40s) and I've only had to turn on the defroster one time when it was raining pretty hard.
NDSU_Bison is offline   Reply With Quote
Old 03-09-2008, 09:53 PM   #9
PropDr
2006 WK
Condensation is a combination of Dew point and available water vapor.
Dew point is obvious, low temp outside, high temp inside. The window glass is cold and water vapor will condensate.
Normal amounts of moisture will be handled by the ventilation system.
So that leaves excessive moisture or inhibited ventilation.
Check all the carpeting for dampness.
Make sure that you don’t have your heating system set on recirculation.
06 WK 5.7, No Badges,Gibson CatBack, BWoody CAI, Eibach Springs & upper Ball Joints; F/R ADDCO Bars w/BWoody links; SRT8 Bilsteins; SRT8 Wheels w/ F: 275/50/20, R: 305/20/45 Tires; Passport SRX; 6 Bosch HID's; SRT8 Engine Covers w/ 5.7L badge: Kicker Sys.
PropDr is offline   Reply With Quote
Glock Forum
