2007 Grand Cherokee headlight problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2007 Grand Cherokee headlight problem
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 08-28-2014, 11:38 AM   #1
meatlord
Animals taste good
meatlord's Avatar
on my 2007 jeep grand cherokee I have a constant problem where my auto high beam switches between off and on repeatedly. has anyone here had this issue?
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline   Reply With Quote Quick reply to this message
Unread 08-28-2014, 11:42 AM   #2
murderedoutGC
2007 WK
is it only when there are cars passing or a light shinning at the jeep?(sounds like you have the auto high beam turned on).
Black Wk Club MEMBER #144
murderedoutGC is offline   Reply With Quote Quick reply to this message
Unread 08-28-2014, 12:01 PM   #3
meatlord
Animals taste good
meatlord's Avatar
yes I have the auto high beam function on. no traffic no lights but the auto hi beam goes off to on off to on repeatedly, even does it during the day while the lights are on.
Unread 08-29-2014, 07:16 AM   #4
cobra259
2006 WK
The camera is behide your inside rear view mirror. try cleaning the glass...
2006 GC Limited 5.7 Hemi Stone White BT C/can Mopar cold air
1995 Cobra Mustang Procharged
cobra259 is offline   Reply With Quote Quick reply to this message
Unread 09-01-2014, 08:27 PM   #5
meatlord
Animals taste good
meatlord's Avatar
Cleaned the camera sensor, still the same issue. On my EVIC, it constantly says automatic headlights on....off.on.off...on........off......on.off.on.of f....
Well you get the gist of it. It is definitely on the control side of things, maybe a bad switch on the stalk? Anyone know exactly how this system works?
Unread 09-02-2014, 06:47 AM   #6
caddydaddy
2007 WK
I've had this same issue on an old Cadillac I had, and it was a bad light sensor. The light sensor detects the brightness of another cars high beams and dims your headlights.
I thought you could turn off the auto high beams through the EVIC settings? Then you could rule out your stalk, and then get the light sensor tested or replaced.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 09-02-2014, 08:41 PM   #7
meatlord
Animals taste good
meatlord's Avatar
I believe the issue to be that it is intermittently turning itself off and on in the settings somehow, or that possibly another part of the system is faulting and shutting it off. My EVIC constantly flashes the settings off to on, even when I bring up the temp it is only momentarily, then back to "off"......" On"...... This is present even when there is no trigger source to dim the lights. I believe its an issue keeping the system switched on. Just a theory tho.
Unread 09-03-2014, 04:11 AM   #8
caulk04
2008 WK
Just don't leave the high beam switch on (pull it back to low beam). The high beams will stay off regardless of the Auto Beam system that way.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 09-03-2014, 04:11 PM   #9
meatlord
Animals taste good
meatlord's Avatar
Yes they work that way, low beam only, but wanted to try and troubleshoot it myself and repair it. What separates the low beam from the high beam systems, or what exactly is the switching mechanism for power, and or operation?
Unread 09-13-2014, 11:48 AM   #10
meatlord
Animals taste good
meatlord's Avatar
Bump......
Unread 09-13-2014, 12:07 PM   #11
colinzj
2006 WK
The guts of the SmartBeam system are in the mirror itself. If you haven't already tried it, start with the stupid simple stuff: Disconnect the harness from the mirror, give both ends a good hose down with some canned air, and reconnect it.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is online now   Reply With Quote Quick reply to this message
