2007 Grand Cherokee Courtesy lights & Radio won't turn off when key off, door opened. - JeepForum.com
post #1 of 18 Old 07-01-2014, 09:06 AM Thread Starter
maverickma
Long time lurker here. Thanks for all the great info, but this latest issue has me stumped. My interior lights will not go out when I turn the key off and lock the doors via the key fob. And now my radio will only turn off after about 10 minutes when I take the key out and open the door. Typically the radio and the time display turn off immediately after closing the door. I replaced the rear liftgate latch with a new Mopar one, checked/lubed all the door latches, checked the wires between driver door and body (none broken), and load tested the battery. Everything appears fine.
Guys I'm stumped. There are no relays for dimming the lights from what I can tell. Goes to the dealer on Thursday and they're talking about a new dash. Really? Any thoughts? Am I missing something?
maverickma is offline
post #2 of 18 Old 07-01-2014, 11:54 AM
ZWilson07
2008 WK
So is it only turning off once you turn the wk off and open the door?
Or is it staying on for 10 minutes even after you turn the wk off, pull the key, and open the door and get out?
2008 WK Overland 5.7 Hemi 4x4 QD2
Everything I need, plus a lot more I don't.
Black WK Club Member #154 || Hemi Club Member #89
ZWilson07 is offline
post #3 of 18 Old 07-01-2014, 12:24 PM Thread Starter
maverickma
The courtesy lights I can't get to turn off at all....Jeep started, not started, locked, not locked so I had to pull the fuse for the interior lights. The radio and clock readout will eventually turn off after I take key out open and close door and lock up. For now I just turn off the radio manually and the clock stays on for like 10 minutes and then turns off. That must be a power saving feature. Too bad the courtesy lights don't do that.
post #4 of 18 Old 07-02-2014, 12:59 AM
masterofallbass
2007 WK
im having the same problem with my 07. my driver door doesn't register when open or closed on the dash. the windown switch for the front windows and power lock switch doesn't work on the driver side ever since the door doesn't register with the dash. #12 fuse is good and theres power to the door and I can roll down the windows to the rear windows with the driver switch. but with that being said if the door doesn't register its open all the courtesy lights & Radio won't turn off
masterofallbass is offline
post #5 of 18 Old 07-02-2014, 06:45 AM Thread Starter
maverickma
If I had to guess, I would guess that both of our issues have something to do with that wire bundle running from the driver door to the chassis even though a visual inspection showed nothing. I didn't check inside the door and inside the chassis wherever they connect to.
post #6 of 18 Old 07-03-2014, 12:12 AM
masterofallbass
2007 WK
if u find something let me know and ill do the same
post #7 of 18 Old 07-03-2014, 03:45 AM
chrali
2006 XK Commander
You sure you haven't turned the light stalk to have the courtesy light on?
Sent from my C6833 using JeepForum
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #8 of 18 Old 07-03-2014, 05:06 AM Thread Starter
maverickma
Light stalk is not turned on.
Mbass yep, it goes to the dealer today so I'll keep you posted. I'm leaving in 30 minutes. Doug
post #9 of 18 Old 07-03-2014, 09:22 AM Thread Starter
maverickma
Ok just back from the dealer. All the wiring and connections checked out from the door to the body. They are pretty sure its the driver side door latch so we had to order the part since it was not in stock. Just in case, I'm going to let the Jeep dealer install that part, but I'm not going back there until the 14th. I'll post a status on the 14th. Doug
post #10 of 18 Old 07-17-2014, 12:41 AM
masterofallbass
2007 WK
so was it the door latch? thats my guess. if so how much did it cost?
post #11 of 18 Old 07-17-2014, 06:34 AM Thread Starter
maverickma
Was not the door latch. Goes in again to the dealer on Monday. With labor the part was $225, yes I'm pissed and I will make sure that amount is credited to my bill. I bet the rear latch is bad, the one I just bought, but I have no patience to figure it out. Jeep service has been disappointing, at least from the two dealers I've been to.
post #12 of 18 Old 07-17-2014, 07:06 AM
murderedoutGC
2016 WK
if the latch was bad it should pop up in the notifications center notifying you that the rear latch is open wouldn't it?!
2016 GC Overland High Altitude White on black
murderedoutGC is offline
post #13 of 18 Old 07-17-2014, 02:27 PM Thread Starter
maverickma
Not sure. It didn't last year when I had the issue. The only thing that would happen is the courtesy lights would stay on, no door ajar light on the dash etc. I lubed up that rear latch and it solved the issue for a year.
post #14 of 18 Old 08-25-2014, 10:36 AM Thread Starter
maverickma
Issue resolved.
Sorry for the late update, but the issue has been resolved. It ended up being the console (where the odometer is contained). I'm told the dimming is controlled by the console, not by relays in the 2007 GC. The part alone was $525 and then add the labor. It was expensive, but it's now fixed. They said it's not common. Lucky me.
post #15 of 18 Old 09-01-2014, 07:54 PM
masterofallbass
2007 WK
Nice im sure thats my problem too. What is the part number or name? Is it like a module?
