2007 gc p0743 - JeepForum.com
post #1 of 4 Old 04-23-2017, 03:53 PM Thread Starter
Stimmel
2007 gc p0743
My moms 2007 Laredo 3.7 111k threw the P0743 torque converter solenoid code, trans fluid was pretty dark, but full clunks bad shifting gears....
Trans toast?
P.S. Thanks in advance
Stimmel is offline
post #2 of 4 Old 04-23-2017, 04:13 PM Thread Starter
Stimmel
Will not shift out of 1st gear and manual mode doesn't work either!
Stimmel is offline
post #3 of 4 Old 04-28-2017, 05:44 PM Thread Starter
Stimmel
I've been told the valve body ( with all the sensors) need replaced, my cost at the dealer is around $400 so, the valve body and obviously pan gasket filter and fluid and I hope I'm good.
Please advise if this is a bad idea
Stimmel is offline
post #4 of 4 Old 05-02-2017, 06:42 PM Thread Starter
Stimmel
Hard reset on the ecu and it drove like new light came back on same code went into limp mode took the pan off fluid was dirty and found these in the pan any insight?
Stimmel is offline
