2007 CRD - OBD code P0471 - JeepForum.com
 2Likes
post #1 of 40 Old 11-05-2010, 09:40 AM Thread Starter
Jscheier
2007 WK
Any ideas?
Generic code searching returns:
1. Supply tube blocked or damaged
2. Faulty EP sensor
3. Faulty ECM
4. Exhaust Pressure Sensor
Looked in my smancy JEEP manuals and didn't find anything.
Symptoms: None, really. Light came on coming home from dinner. Car was driving fine. For one cycle it did seem like it had zero boost, but since then, no issues. MPG might be down just a little
Pulled engine cover and don't see any loose or disconnected cables. Turbo inlet and EGR tube are firmly attached. There is more oil in the area (damn) and noticeable oil around the plastic skid pan near the drain plug, but no leaks from the plug itself.
My guesses:
1. EGR
2. Swirl motor
3. some faulty sensor and a bogus generic OBD code
Thoughts?
2007 Jeep GC QD2 CRD (GDE equipped Toy Hauler)
2012 Boss 302 (Track Toy)
Jscheier is offline
post #2 of 40 Old 11-05-2010, 11:10 AM
suzieque
2008 WK
google seems to suggest a dpf sensor. if thats the case, looks like you will need to take it to the dealer.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 40 Old 11-05-2010, 01:14 PM
SSF556
2008 WK
These could be interesting...maybe a plugged DPF????...How many miles???
Sent the code to a guy I know on the Sprinter Forum...I will pass along what he says.
SSF556 is offline
post #4 of 40 Old 11-05-2010, 01:16 PM Thread Starter
Jscheier
2007 WK
2007 CRD.
Just turned 26,000 miles
Always used the correct oil (I do all the changes)
Jeep is running fine today... but light is still on.
Goes to the dealer Monday afternoon
Jscheier is offline
post #5 of 40 Old 11-05-2010, 02:02 PM
suzieque
2008 WK
can you remove the inmotion tune before you drop it off? I'm not saying the tune caused the problem, I'm just wondering if the dealer will do something and erase the tune.
suzieque is offline
post #6 of 40 Old 11-05-2010, 02:40 PM
justa4banger
2007 WK
There is no way to remove the inmotion tune... unless you have the OBD tool that was used to load the tune...
Besides Inmotion claims there is no way to detect the tune as it is a adjustment to the factory tune....
Now if they reflash the ECm or replace it, well then he is kind of screwed... Inmotion might work with him though to get it reloaded...
Be sure to update us on the status of this issue.
According to the code list P0471
DTC P0471 Exhaust Pressure Sensor Range/Performance
Could be the DPF
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #7 of 40 Old 11-05-2010, 08:23 PM
SSF556
2008 WK
Hi Scott,
Generically P0471 means, "Exhaust Pressure Sensor "A" Circuit
Range/Performance"
Unfortunately, Daimler's technology doesn't use the same codes as other
vehicles, so generic code readers provide potentially misleading codes like
P0471.
If you do a search for that on techauthority for P0471 you get nothing
back... it's as if the service documentation is saying, "no such thing."
This is the price we pay for owning DaimlerChrysler technology: only their
diagnostic equipment can make sense of the situation. In this case it's
StarSCAN, StarMOBILE or WiTECH.
It needs to be scanned a dealership scan tool for the truth.
I suspect it's either the EGR valve, the EGR temperature sensor or the EGR
cooler that is the culprit... it might be the DPF if there are a lot of
miles on it and the DPF's "getting full," but only a dealership scan tool is
going to tell the truth (like how much soot is in the DPF - if it's not
full, than the problem's probably the cooler or the EGR valve).
-Jon
SSF556 is offline
post #8 of 40 Old 11-08-2010, 07:18 AM
TonyVideo
TonyVideo's Avatar
2008 WK
Since it is a 2007 with only 26,000 miles it seems it does not have a lot of highway miles. Are most of your trips short. If so, the DPF probably does not have an opportunity to fully regenerate as it is shut off too soon. My guess. Do you tow anything? I have found if I tow something the engine always runs better afterward. It likes to work.
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #9 of 40 Old 11-08-2010, 08:15 AM Thread Starter
Jscheier
2007 WK
While I do use it for short trips, it is mainly used for towing my track car, and that is where most of the miles come from. 5000 lbs and usually with the cruise set around 80 mph. I work it
For daily use, there is about a 5 mi. round-trip commute (park-n-ride), but the weekends we are all over the place.... and I run the heck out of it when I am in it
The DPF did a regen on Saturday, and since then, the light has gone out although I'm not sure it is related. Probably won't get it in to the dealer for a couple of weeks... which is when I originally planned to get it in for some other small stuff. I'll update when they scan it.
Jscheier is offline
post #10 of 40 Old 11-17-2010, 01:23 PM Thread Starter
Jscheier
2007 WK
Tuesday morning, 1/2 way into my morning commute, power drops and the Electronic Throttle Control (red brackets and lightning bolt) illuminate on the dash. I get to my destination, run through 6 on/off cycles with the motor and the light goes out.
Tuesday afternoon, hop in to go home and the MIL comes on instantly and I'm in limp mode. FWIW, it did run a regen on the way home.
Dropped it off at the dealer this morning (MIL still on, but no limp mode). They called and said it had several stored codes and it would take a day to go through them all.
Will update with results.
Jscheier is offline
post #11 of 40 Old 11-17-2010, 03:55 PM
Sportskid1
2007 WK
Can you let us know if they can spot the InMotion tune in their work? I know they are not suppose to but I am a little uneasy with an extended warrenty.
Sportskid1 is offline
post #12 of 40 Old 11-19-2010, 06:37 AM Thread Starter
Jscheier
2007 WK
Dealer called last night and said that, in fact, it was a sensor identified as an Exhaust Pressure Sensor. They kept it over night and will re-run codes this morning and test drive to make sure that this resolves the issue.
Service advisor stated that he had the jeep pretty torn down... where exactly is this sensor? I would have thought it would have been between the turbo and the DPF?
Jscheier is offline
post #13 of 40 Old 11-19-2010, 02:00 PM
suzieque
2008 WK
yup, though a bit tough to get to, if it really is DPF related.
suzieque is offline
post #14 of 40 Old 11-19-2010, 02:36 PM
CRD Dawg
2008 WK
x2. I also have the InMotion Tune and have worried that it may be detected next time the CRD's in for service. Still have about 1 1/2 years of factory warranty remaining and hate to have it voided.
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
CRD Dawg is offline
post #15 of 40 Old 11-19-2010, 04:25 PM Thread Starter
Jscheier
2007 WK
Official results:
Code stored was P0471, CK, F858, K35, K934. Circuits for shorts no voltage, open and grounds, all circuits test good. Replaced exhaust gas pressure sensor and cleared codes and verified proper operation.
Part # 68013186-AB at a cost of $84.24
Jscheier is offline
2007 WK CRD - Code U0106 Lost Communication with Glow Plug Module tdibadger WK Grand Cherokee & XK Commander Forum 32 08-03-2013 06:55 AM
What does code check engine code 14 mean?? tawa1075 ZJ Grand Cherokee Forum 1 10-19-2010 02:54 PM
Engine Code help- Code 11 athomas08 ZJ Grand Cherokee Forum 3 05-06-2009 11:56 PM
OBD II code on GC 2007 ltd diesel menoche WK Grand Cherokee & XK Commander Forum 8 01-04-2009 03:19 PM
2007 WK Code Crookster777 WK Grand Cherokee & XK Commander Forum 0 02-09-2007 06:02 PM
