2007 Commander popping noise - Page 2 - JeepForum.com
 1Likes
post #16 of 21 Old 09-23-2016, 06:54 PM Thread Starter
traut811
Sorry everyone for a delayed reply! The issue was coming from the upper front differential being shot. Hopefully we will be able to get it on the lift and get the isolator bushings replaced soon. I went ahead and am going to do all three.
traut811 is offline
post #17 of 21 Old 03-15-2017, 08:31 PM Thread Starter
traut811
The upper differential bushing seemed to be the fix, and I highly recommend looking into them if anyone has a similar issue and ball joints, tie rod end, wheel bearings etc can all be ruled out.
traut811 is offline
post #18 of 21 Old 03-17-2017, 10:11 PM
Hemicuda61
Did you go with OEM or poly bushings?
Sent from my iPad using Tapatalk
Hemicuda61 is offline
post #19 of 21 Old 03-19-2017, 12:30 PM Thread Starter
traut811
I did OEM type.
traut811 is offline
post #20 of 21 Old 03-20-2017, 12:03 PM
mb81
2006 WK
How much did this set you back in parts/labor? (I assume you had a shop do it). After researching this I came across an article and it looks a bit intensive... http://www.fourwheeler.com/how-to/tr...ial-mount-fix/
If this is talking about the same bushings, did you do all 3?
mb81 is offline
post #21 of 21 Old 03-23-2017, 01:38 PM Thread Starter
traut811
Originally Posted by mb81 View Post
How much did this set you back in parts/labor? (I assume you had a shop do it). After researching this I came across an article and it looks a bit intensive... www.fourwheeler.com/how-to/transmission-drivetrain/1406-2005-jeep-grand-cherokee-front-differential-mount-fix/
Those are it! I don't know exactly what it cost me to do them, as there were a few other things done at the same time, but I think I got billed for 2.5hrs of labor or so which was not worth me doing it. Everything I've seen said it's much much easier if you have a lift, but I've read on here that a few guys have done it laying on their backs in the driveway.
traut811 is offline
