2007 Commander popping noise - JeepForum.com
 1Likes
post #1 of 21 Old 07-26-2016, 02:40 PM Thread Starter
traut811
Hey guys. I'm having an issue (well, a couple... "check gas cap" followed by CEL, popping noise, got the clogged sunroof tubes sorted out, rear AC lines corroded through) and was wondering if anyone could offer advice.
2007 Commander 4.7L with 76k miles. It is popping pretty badly when turning, hit off camber bumps, and I have even noticed it even when just hitting the brakes. I tried to find it by myself on the shop floor. When you jack it up from the center, as the tires scoot together and suspension raises, you can hear a pop. Same as when you let it down, as the suspension settles, it usually pops. This is with the wheels straight forward and tires not rotating.
From what I've read, it sounds like a lot of people point to front joints being bad. Could this be with the above situation though? I'm pulling my hair out. It is a semi-violent pop, so I'd like to not just let it go.
Thank you in advance!
Nick
traut811 is offline
post #2 of 21 Old 07-26-2016, 03:01 PM
08rubie1
So i think you and i have the same poping noise issue. Mine happens when braking hard or accelrating hard. i also get it over wash board and when really cranking the wheels hard to the left. The pooping noise sounds like something is under tension and then letting loose? I took my jeep to a local dealer and he told me it could be my lower control arm bushings/ swarbar links/ struts.... however i do not think any of those are making the poping noise
08rubie1 is offline
post #3 of 21 Old 07-26-2016, 05:32 PM
Mp5ben
2005 WK
I would say ball joints but I'm not too familiar with IFS set ups yet. What ever is the equivalent for the IFS set up is where I would be looking.
My friend with a dodge pickup gets the same popping when he makes a sharp turn going a little too fast, it puts alot of stress on them. Not the only way for them to pop though
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #4 of 21 Old 07-26-2016, 05:53 PM
Hendrix9
2007 WK
I'd replace the front sway bar bushing first. Cheapest and easiest and you'd be surprised how noisy they can be. Made mine sound like a POS beater and afterwards like a brand new quiet suv.
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is online now
post #5 of 21 Old 07-26-2016, 08:25 PM
Jtav2012
2005 WK
Check your control arms, I had that when my lower arms were sliding slightly out of position because they weren't torqued down all the way.
luckyse7ens likes this.
Not-stock 2005 5.7L WK
Jtav2012 is offline
post #6 of 21 Old 07-27-2016, 07:14 AM Thread Starter
traut811
Thank you for all of the replies.
I tried putting my hand on different components when jacking it up/down to see what would "jar" the most, but didn't have great results. I unbolted the sway bar end links and still yielded the same results.
I put my hands at 12 and 6 on the tire to check wheel bearings, 3 and 9 to check tie rods with no play felt. What's the best way to check ball joints and control arm bushings?
Thanks in advance.
traut811 is offline
post #7 of 21 Old 07-27-2016, 09:12 AM
08rubie1
U have to get a big pry bar and put it in there and see how much movment there is.. just looking at mine i can see they are cracked and nasty
08rubie1 is offline
post #8 of 21 Old 07-27-2016, 01:19 PM
luckyse7ens
2010 XK Commander
My LCA's were not torqued properly or tightly enough when I got an alignment done. You could feel the pop in your feet.
This sounds like it could be your issue.
Black WK Club #152
luckyse7ens is offline
post #9 of 21 Old 07-28-2016, 01:15 PM
08rubie1
i am installing my new sway bar end links today and will check my lca bolts and let you know if that helps at all.
08rubie1 is offline
post #10 of 21 Old 07-29-2016, 11:23 AM Thread Starter
traut811
Sounds great, thank you. I haven't gotten a chance to pull mine in and mess with it any more but hopefully this weekend.
I'm going to look at this tomorrow for my girl friend. Any thoughts?
https://stlouis.craigslist.org/cto/5704112284.html
traut811 is offline
post #11 of 21 Old 07-30-2016, 10:42 AM
nvrdone1
2007 WK
are you using wheel spacers on the front ? my 07 front end started popping when turning after having the wheels rotated. turns out that the shop over torqued the lug nuts & broke 3 studs on the left front spacer. I was real lucky I found that one. took the spacers out & no more popping.
nvrdone1 is offline
post #12 of 21 Old 08-01-2016, 01:47 PM
luckyse7ens
2010 XK Commander
I'd start a new thread.
Black WK Club #152
post #13 of 21 Old 08-01-2016, 03:37 PM
08rubie1
No bingo on the sway bar links still pops...
08rubie1 is offline
post #14 of 21 Old 08-10-2016, 08:56 AM Thread Starter
traut811
After looking at it some more, still no luck on finding it yet. Tie rods, ball joints, wheel bearings, end links, sway bar bushings, all feel tight. You can also hear the noise when just sitting in park and turning back and forth. It is going up on the lift on Monday. I'll report back what I come up with.
Thank you for the words of advice and suggestions so far!
traut811 is offline
post #15 of 21 Old 08-10-2016, 02:47 PM
08rubie1
Can you take a video of the noise? i have a feeling ours is the same....
08rubie1 is offline
