2006 WK Stereo Upgrade Plans - JeepForum.com
post #1 of 16 Old 08-28-2012, 01:28 PM Thread Starter
shudog
2012 WK
I'm in the midst of planning my stereo upgrade. Currently has the base non-navigation Boston setup. I hate the deck and the speakers. Aiming for a midgrade setup, nothing high end.
Planning to have the door speakers run off the new deck and was thinking of disconnecting the front dash speakers and just going to 3-way full range speakers in the doors to keep things balanced. I had this setup in my '98 ZJ and was very happy. With an aftermarket deck, I'm not sure how I'd run the fronts otherwise. Either way, I definitely want the front door speakers to be full range, because right now I hate the muffled sound they put out.
Also definitely doing sound deadening in the doors at the same time. Can't stand how much road noise comes through on this vehicle.
For the front door speakers, any thoughts on replacing them with a 6x9 size or something more like a 6.5" round? Or is the quality of the speaker more important than the size?
Previously owned jeeps:
'06 Grand Cherokee Limited w/4.7L V8 & QD2
'98 Grand Cherokee Limited w/5.2L V8 & Quadra Trac - sold at 230k miles
shudog is offline
post #2 of 16 Old 08-28-2012, 01:38 PM
BillyZim
2006 WK
Not sure if you knew it or not. You can get a double din bezel to upgrade your single. Here's one on ebay.
BTW... I may be looking to sell my REC radio from mine. It's in perfect shape. (it has the backup cam pinout).
Will work great with mygig. Good luck man.
http://www.ebay.com/itm/Jeep-Grand-C...sories&vxp=mtr
2006 WK 3.7 4x4 - OME HD lift - 265/70/17 Duratac's on ProComp wheels
BillyZim is offline
post #3 of 16 Old 08-28-2012, 01:54 PM Thread Starter
shudog
2012 WK
Yes I'm definitely going to upgrade to the double din size, thanks for the ebay link to the new dash surround piece.
Any thoughts on front speaker sizes?
How about tips on retaining steering wheel stereo controls? Just buy the adaptor from Crutchfield along with everything else?
shudog is offline
post #4 of 16 Old 08-28-2012, 08:48 PM
BillyZim
2006 WK
I'm still researching a new stereo. I did read that you can keep the steering wheel controls with this...
Not sure about the speakers.
BillyZim is offline
post #5 of 16 Old 08-28-2012, 09:24 PM Thread Starter
shudog
2012 WK
so I checked in the back cargo area and found the amp back there, guess I do have the Boston Acoustic system after all. Kinda disappointed by this actually. Was really hoping to power the 4 door speakers directly from a high output aftermarket head unit
shudog is offline
post #6 of 16 Old 08-28-2012, 11:05 PM
dsjr2006
2006 WK
There is no such thing as a high output headunit. Even an Alpine with the power pak added has less power than the Boston stock amp.
'06 Limited Hemi QDII - Icon Coilovers - OME Lift w/Bilsteins - 32" 265/65R18 Goodyear Duratracs on JK Sahara 18s - Smittybilt XRC10 Comp X20 Winch
05-08 WK Service Manual PDF:
dsjr2006 is offline
post #7 of 16 Old 08-29-2012, 07:01 AM Thread Starter
shudog
2012 WK
^I get that. Sorry if my post was confusing.
Let me rephrase, if I ditch the stock deck and go to an aftermarket head unit, will that allow the front door speakers to become full range? Or is the crossover which keeps those speakers lower frequency woofers built into the factory amp somehow?
shudog is offline
post #8 of 16 Old 08-29-2012, 09:11 AM
JRLT
2010 WK
You can get passive crossovers that you splice inline with your speaker wires but they wouldn't be adjustable, they would have a set frequency and crossover slope. They do that all of the time in the 1-50 watt class at car audio competitions. run 5-7 speakers(including sub) off of one amp and the whole thing is ran off of passive crossovers.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #9 of 16 Old 08-29-2012, 09:20 AM Thread Starter
shudog
2012 WK
well this thread isn't really getting what I was looking for I guess. Seems like the best route to go after replacing all the speakers with upgraded aftermarket ones is to run RCA cables back to the factory amp location, replace that with a decent 4 channel setup to run all four door speakers and probably run the dash speakers off the head unit. May not deliver the highest quality, but I'm sure it'll sound a heck of a lot better than now and I'll get much more sound out of the aftermarket speakers with an aftermarket amp.
One question with going this route, if I ran RCA cables from a new head unit back to the factory amp location, then switched out the amp, could I still get away with using the factory speaker wires?
shudog is offline
post #10 of 16 Old 08-29-2012, 10:01 AM
dsjr2006
2006 WK
The front door speakers are all ready being provided more range than they can handle from the factory. Just upgrading the speakers to a two-way or 3 would be a major improvement.
dsjr2006 is offline
post #11 of 16 Old 08-29-2012, 10:03 AM
dsjr2006
2006 WK
That's actually exactly what I did. I tapped the new amp into the existing wiring because it didn't want to deal with the grommets on the doors. They aren't like anything I've worked on before and you can't just run wire through since its a plug.
I have no issues so far.
dsjr2006 is offline
post #12 of 16 Old 08-29-2012, 10:14 AM Thread Starter
shudog
2012 WK
Did you have to run a new switchable power wire to the new amp? What head unit are you using? Where did you run your RCA cables?
shudog is offline
post #13 of 16 Old 08-29-2012, 10:18 AM
dsjr2006
2006 WK
Power wire is required just like any other aftermarket amp, and amp remote is run from headunit which is a Pioneer AppRadio2, I ran 6 channel RCA cables to the rear down the driver side (should've been passenger). I chose to run 6ch because I also plan on switching to a Alpine headunit with 6ch preout instead of 4ch. Power & RCA should be on opposite sides of the car to avoid interference.
dsjr2006 is offline
post #14 of 16 Old 09-19-2012, 01:45 PM Thread Starter
shudog
2012 WK
Looking at this more closely, seems like the Kicker upgrade offers everything I'm looking for at a much lower price and simple installation: upgraded speakers, more powerful amp... I can always upgrade the head unit down the road
shudog is offline
post #15 of 16 Old 09-19-2012, 06:19 PM
dsjr2006
2006 WK
It is certainly much easier. If I were you I would do the speakers first since that will make the biggest difference. My understanding is that the amp has the same output only with the added surround sound feature.
dsjr2006 is offline
HELP! Nav Stereo Bezel won't fit 2006 Grand Cherokee Limited mattpatton WK Grand Cherokee & XK Commander Forum 7 11-26-2011 08:51 PM
2006 WK Stereo Controls GX310 WK Grand Cherokee & XK Commander Forum 4 07-07-2009 09:00 PM
kicker stereo upgrade rcs8104 WK Grand Cherokee & XK Commander Forum 1 03-07-2008 04:04 PM
2006 Overland Brake Upgrade sama WK Grand Cherokee & XK Commander Forum 1 03-15-2007 03:50 PM
Stereo Upgrade bdb978 ZJ Grand Cherokee Forum 4 02-22-2006 12:01 PM
