2006 Jeep Commander Transmission Clunk and Leaks - JeepForum.com
post #1 of 7 Old 07-14-2008, 04:54 PM Thread Starter
csijeep
2006 Jeep Commander 65th Anniversary Edition with the 3.7l V6 engine 4wd with QuadraTrac I.
We just got the Commander two weeks ago and didn't even drive it the first 10 days we owned it as we went out of town and left it home. The first day we actually drove it after we got home, I found an oil leak, tranny leak, the famous Commander whistle/hum noise from windshield or moon roof, and also a transmission clunk. Well, I found out today after calling the dealer, the leaks and windshield issues have been repaired, but the transmission clunk is more serious. Apparently, the input shaft has too much end play and it needs to be replaced. The dealer told me they had to remove the transmission and they were going to do the work at no cost to me. I do have an extended warranty on it, plus it's still on the dealer 30 day 100% dealer parts and labor warranty.
Now to my question, has anyone else had the oil/transmission leaks or the transmission clunk? Can I expect to have any future problems related to this tranmission problem?
Thanks
csijeep is offline
post #2 of 7 Old 07-14-2008, 05:19 PM
merlinTec
merlinTec's Avatar
Hi
The leak is the only common fault with this box.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 7 Old 07-14-2008, 08:37 PM
sabre364
2007 WK
Originally Posted by merlinTec View Post
Hi
Regards,
Merlin
Isn't it simply the o ring or something that needs to be replaced? I've seen the TSB for the 05 models, but others on here have said that was the same issue when their 06+ were showing a tiny leak near the drain plug.
sabre364 is offline
post #4 of 7 Old 09-16-2010, 12:59 PM
MacDuBz
I have also encountered all of these problem, transmission clunk and oil leak just started 2 days ago. The dealership already fixed the tran leak about a year ago. I
Taking my 06 commander in tomorrow for the oil leak and trans clunk. Only other problems I've had are clogged drains in the sunroof that allowed water to get into the interior. Oh and windshield whistle was fixed at the time of the trans leak. No other problems so far.
MacDuBz is offline
post #5 of 7 Old 09-16-2010, 02:58 PM
JeepWranglerNation
Can't Say Our Issue Is The Same
Post Delete
JeepWranglerNation is offline
post #6 of 7 Old 09-19-2010, 10:07 AM
amberhobo
clunk and Trans leak
I purchased my Commander new in 07 with an extended warranty; currently at 99,000 miles. The trans has leaked only once after taking it for the trans fan coming on and being checked by a dealer. Someone later had to reseal the pan because it wasn't put back correctly. The clunk appeared recently and was caused by the front differential - thankfully the warranty company covered this. Also had a shudder appear about the same time. This turned out to be the rear differential - also replaced by the warranty company. I'd like to know if anyone has had problems with other parts of the transmission, like the transfer case or need for rebuilt transmission after 100,000 miles?
amberhobo is offline
post #7 of 7 Old 12-10-2013, 01:50 PM
vif2343
my 2006 commander has a new battery and alternator and after about 3 hours of driving it died and the battery was completely dead...any ideas?
vif2343 is offline
Commander Door/Windshield Water Leaks chriswcarson WK Grand Cherokee & XK Commander Forum 1 08-09-2009 06:39 PM
2006 Jeep Commander 2nd Row Cupholder sean0965 WK Grand Cherokee & XK Commander Forum 3 07-10-2009 12:54 PM
2006 Commander FSM bfr WK Grand Cherokee & XK Commander Forum 0 03-01-2007 07:47 AM
2006 Jeep Commander Earns Top Government Safety Rating from NHTSA Chipster009 WK Grand Cherokee & XK Commander Forum 0 04-13-2006 05:33 PM
2006 commander jeepramnauth ZJ Grand Cherokee Forum 9 12-15-2004 04:30 PM
