Quantcast 2006 Grand Cherokee HID conversion issues - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2006 Grand Cherokee HID conversion issues
Truck-Lite's New LED Headlamp SeriesCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Old 10-28-2009, 03:41 PM   #1
Wiggs12485
2006 WK
Trying to convert my stock halogen headlights to HIDs and having major issues. Installed kit and lights turned on the first try. Turned car off and re-started, no headlights at all. Bulbs would flicker when plugging them in, lit at first contact but only for a few seconds. Tried the relay to fix the computer/voltage problems that everyone talks about, still did not work. Any suggestions? I've even taken it to an installation guy and he couldn't figure it out. Currently have HID fogs and yellow headlights Need help!
Wiggs12485 is offline   Reply With Quote
Old 10-28-2009, 03:48 PM   #2
robpp
you MUST use a realy harness.
ask the seller for one. almosst all of them know Jeeps GC need them......
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline   Reply With Quote
Old 10-28-2009, 04:03 PM   #3
Wiggs12485
2006 WK
hmm that relay/diagram is very different from the relay i purchased (from a shop that does HID conversions, car audio, etc.). they gave me a pair of relays that go between the original headlight plugs and ballast on each side.
Old 10-28-2009, 05:02 PM   #4
fred99x
2008 WK
In theory both setups would work. With one relay, the contacts have to be rated for the full load of both lights and if the one relay fails, both lights are out. I personally like the idea of one relay for each light, a little more wiring but you should not have both lights out at the same time due to a relay failure.
fred99x is offline   Reply With Quote
Old 10-28-2009, 05:42 PM   #5
fred99x
2008 WK
This thread may help you on the issue of lights not coming on: http://www.jeepforum.com/forum/f67/problem-strobe-light-hids-521881/ Also some common issues are identified here: http://reviews.ebay.com/HID-XENON-CONVERSION-KIT-TROUBLE-SHOOTING_W0QQugidZ10000000001215090 Sounds like the usual problem is voltage related?
Old 11-20-2009, 10:08 AM   #6
omarl956
2005 WK
so did you get it fixed? im in the process of putting some on myself. i just ordered the relay harness for dual ballast
omarl956 is offline   Reply With Quote
Old 11-23-2009, 03:21 PM   #7
Wiggs12485
2006 WK
i haven't been able to get these fixed yet... i took it back to the shop where i purchased the relay and they couldn't figure it out either. its something with the car- they also tried a set of their own HIDs and it still wouldn't work. i have another person looking into it too. let me know if your relay harness works, and if so where you got it. thanks!
Old 11-23-2009, 09:17 PM   #8
Spider-One
2008 WK
The relay should connect to the ballast, original light plugs and the battery. They are designed to provide power to the HID's directly from the battery when power is switched on to the original headlight plug.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator
Spider-One is offline   Reply With Quote
Old 12-07-2009, 03:02 PM   #9
omarl956
2005 WK
well i got the hids connected and working good....get the relay harness for sure though. Maybe your kit is defective...
Glock Forum
