2006 grand cherokee airbag light is on - JeepForum.com
post #1 of 20 Old 12-09-2009, 07:35 PM Thread Starter
HVACguy1
My left tail light was out and traced it to a blown fuse due to my trailer wiring being all jacked up. I didnt know what fuse it was so I pulled em all out until I found a blown one. I replaced the fuse and the next time I drove my airbag light came on. I finally found the fuse diagram and looked at the fuse for the airbag and it was ok. Anybody have this problem? Is the only fuse for the airbag system that red 10amp? Some ideas would be greatly appreciated as I am driving 2300 miles to california in 3 days and an airbag sure would be nice if I crash I would like to check some things on my own before I send it to the shop and have somebody that knows what there doing look at it. Thanks
HVACguy1 is offline
post #2 of 20 Old 12-09-2009, 08:36 PM
JMorash
2005 WK
Could be the wieght sensor needs calibration. Mine had the same problem after some electrical fart.
Had a big guy sit in the front seat 250lb and the warning light went away. I also did wiggle and snugg all the elctronics underneath the seat.
Try that.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #3 of 20 Old 12-09-2009, 10:12 PM Thread Starter
HVACguy1
ok I looked for anything obvious under the seats and everything seems in good order. If it will help, I noticed that when i put a little pressure on the passenger seat the pass. airbag light will go on and then off when I sit on it so im assuming thats ok on that part of the system. Anything else? When the light is on in the cluster does that mean the airbags will not deploy?
HVACguy1 is offline
post #4 of 20 Old 12-10-2009, 05:51 AM
JMorash
2005 WK
i believe so. your talking about the little red person with the airbag. As well as the Airbag on/off light that is located on the dash.
Basically the seat thinks there is a small child or bag of groceries in the front seat, therefore disabling the airbag. I think you may know this already.
Dealers have like a weight system to recalibrate it. But that costs money. lol
2005 WK 5.7L Hemi
JMorash is offline
post #5 of 20 Old 12-10-2009, 08:19 AM Thread Starter
HVACguy1
Right my problem is the little red guy with an airbag light. The other light on the information center goes on and off normally with not enough weight and whatnot.
HVACguy1 is offline
post #6 of 20 Old 12-11-2009, 11:58 AM
Acidcold
2005 WK
I have had the same light on the dash for a very long time now, haven't gone to the stealer due to tight wallet.
sure would like to fix that myself aswell, maybe ill have this guy i know that weights 450lbs sit on it
Acidcold is offline
post #7 of 20 Old 12-12-2009, 07:33 AM
Nejeep
Maybe a big guy in a red suit and bag full of toys
Merry X-mas
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #8 of 20 Old 12-12-2009, 08:00 AM
DarrylFlynn
2006 WK
Did you by any chance either start the car or turn the ignition on whilst you had the AIRBAG FUSE out ?
If you did, then i am pretty certain that you will need to have the airbag light reset at the dealers.
I did this by accident a while ago on another make of car and had exactly the same problem.
I HAD to get it reset. Regards Darryl
DarrylFlynn is offline
post #9 of 20 Old 05-13-2011, 06:48 AM
Pdunnie
How did you end up fixing the problem? Im having the exact problem as far as blown tail light fuse and once i replaced that my air bag light is on. Please help!
Pdunnie is offline
post #10 of 20 Old 02-14-2012, 11:41 AM
czar97
Same problem over here. Exact same situation...trailer lights, blown fuse...the whole deal. How'd this ever get fixed? Any updates?
Thanks,
-matt
2003 TJ Sport
4L, 5 spd. manual
3.73 gears four wheel disc
32 x 11.50 Cooper Discoverer STT
2" RE Budget Boost, Spidertrax Wheel Spacers
czar97 is offline
post #11 of 20 Old 02-14-2012, 01:31 PM
WKFusion
2006 WK
I know it sounds dumb but check on the left side of your passenger seat. I looked under neath mine and everything looked normal! turned out there was an empty water bottle shoved to the left of the seat causing the sensor to freak out!
hope this help!
ALSO TRY RESETTING THE COMPUTER (TAKE POSITIVE OFF FOR 20 MINUTES)
2006 Cherokee Laredo 3.7L Current Mods:
Tinted windows/sun visor / HID KIT / Custom CAI / Pinch weld mod / 1.5'' Spacers / 265/70/17 -- Wrangler Authority / Hypertech / 2'' RC
WKFusion is offline
post #12 of 20 Old 02-15-2012, 03:17 PM
JaredG05WK
2005 WK
i'm having the same problem as well. started after the battery died due to leaving the interior lights on all night. jumped my truck and since then the light comes on intermittently. has anyone tried the "disconnect the battery for an hour" trick?
JaredG05WK is offline
post #13 of 20 Old 10-21-2013, 03:27 PM
kapi1
Solved
I also had blown a 10amp fuse for my trailer lights.
I used one of the two spare 10amp fuses to fix the trailer lights. A few days later I noticed the airbag warning light was on.
I checked it out on the web and decided my only solution was to go to the dealer.
Just by chance I bought and replaced the spare 10Amp fuse I used before I went to the dealer. To my surprise it turned off the airbag warning light!!!!
Although they are marked as Spares they obviously are not!!!!
kapi1 is offline
post #14 of 20 Old 03-20-2014, 04:11 AM
kapatterson83
How I fixed the airbag warning light problem
A few days after purchasing my 2006 Jeep Grand Cherokee Laredo, I was driving home from work. I had placed a bunch of stuff in the front passenger seat (approximately 20-30 lb.). About a mile or two down the road, the airbag warning light came on. I pulled over to the side of the road, and read the manual. All it said was to take the vehicle to the Stealer (Dealer) and have them run diagnostics. When I got home, I started to do some digging around the internet; I concluded that the problem had to do with the weight sensor in the seat. The sensor attempts to determine if a child is sitting in the front seat based upon weight; if the sensor thinks a child is sitting there, the airbags are disabled! After reading this information online, I went out to my Jeep and started it with NOTHING in the front seat - and the airbag warning light was no longer on! Since that day, I've found that the airbag warning light only displays if there are objects of a certain weight in the seat. So, before you get too fancy in your troubleshooting, try to determine if your situation is similar to mine!
kapatterson83 is offline
post #15 of 20 Old 09-08-2015, 05:57 PM
metalcore_mike
Sometimes when i start the 06 grand cherokee the warning light will be on, and after i adjust my passenger seat it will shut off.. any ideas? This dosnt have anything to do with the gauges dropping/ignition switch recall does it? Having that same issue as well.
metalcore_mike is offline
2006 grand cherokee tail light wiring ajlizard1 WK Grand Cherokee & XK Commander Forum 1 08-12-2010 07:07 PM
2006 Grand Cherokee Replacement fog light lens kiddonick WK Grand Cherokee & XK Commander Forum 8 12-13-2008 12:01 AM
02 grand airbag light on fixmybrokenjeep ZJ Grand Cherokee Forum 2 01-16-2008 04:28 PM
2001 Grand Cherokee Airbag? -Joe- ZJ Grand Cherokee Forum 2 06-13-2005 12:43 PM
2006 Grand Cherokee SRT-8??? crazynut52 ZJ Grand Cherokee Forum 2 11-16-2004 09:20 AM
