2006 Grand Cherokee 3.7L V6 Misfire - JeepForum.com
post #1 of 8 Old 08-23-2014, 12:13 PM Thread Starter
Bigen03
2006 WK
Hello Everyone
I have a 2006 Grand Cherokee 3.7L V6 with 88K miles on it. The wife was driving it yesterday and the MIL came on solid while at the bank. She started to get a vibration from a misfire on the motor. I went up to the bank and realized I needed to get it home if I had any chance of fixing it myself.
On the way home the MIL started flashing and beeping at me. My Jeep went into Limp Home Mode and engine would only go up to 2000RPM. Called a buddy with a code reader and it showed #5 injector was malfunctioning. We shut off #5 with the scanner and it had no change. We shut off #3 and the motor almost died. Today I got the injector, tore it all apart and replaced #5.
Well, still has the same issues. Still has a rough idle with misfire as well as the MIL still illuminated and in limp home mode.
I have no idea where to go from here and hopefully the dealership will be the last resort. Any help would be great and I am no mechanic lol
Bigen03 is offline
post #2 of 8 Old 08-25-2014, 06:39 AM
Nejeep
First make sure you dont have any vacuum leaks or loose wires after your recent work.
How old are the plugs? If more than 30k miles, they should be changed. The coil on the plug(s) could also be bad causing the misfire. It should throw a code and show which cylinder is the problem or if its a random misfire.
You may want to run a compression test to see if there is a mechanical problem with any of the cylinders.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #3 of 8 Old 08-25-2014, 09:19 AM
tom19511
2014 WK
X2 on plugs
Tom
tom19511 is offline
post #4 of 8 Old 08-25-2014, 12:41 PM
JRLT
2010 WK
I had a misfire after I changed my plugs. Seems I didn't get the plug sealed properly from the top and said plug had moisture and rust on it. Changed the plug with a fresh one and haven't had a problem since.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #5 of 8 Old 08-25-2014, 02:03 PM
RCS1300
2005 WK
The problem may not be with cylinder #5 only. The vehicle may be misfiring on all or multiple cylinders but #5 triggered the DTC. If it was a P0205 code it could be a very simple thing such as a shorted wire to one or more injectors.
Unless you or your friend have skills and experience testing electrical circuits you may want to pay a dealer $125 to diagnose the problem which may be far less expensive than randomly throwing parts at the vehicle - like $70 fuel injectors.
If you want to go further, obtain access to a Service Manual for your vehicle. The manual will give you step by step instructions to diagnose the trouble code. If it is in fact a P0205 code it will require testing electrical circuits to the injector(s) and from the PCM (vehicles computer).
https://www.alldatadiy.com/buy/
RCS1300 is online now
post #6 of 8 Old 08-27-2014, 02:23 PM Thread Starter
Bigen03
2006 WK
Well, I changed the plugs and coils as they were still the originals. I figured if that was the problem or not, it needed to be done. After it did not fix my problems, I broke down and took it to the dealership to have them diagnose the problem.
Come to find out it was the PCM. Had it replaced, and the jeep is running like brand new.
Thanks everyone for the input, I really appreciate it!
Bigen03 is offline
post #7 of 8 Old 08-29-2014, 02:20 PM
luckyse7ens
2010 XK Commander
Glad to hear its fixed.
Its always odd to me to hear that a PCM failed. Its not really a part if would think of as 'wearing out.' Particularly so @ only 88k miles.
What was the bill if you dont mind me asking?
Black WK Club #152
luckyse7ens is offline
post #8 of 8 Old 08-30-2014, 09:16 AM
RCS1300
2005 WK
The PCM has resistors whose purpose it is to restrict the flow of electricity to circuits. Resistors heat up when used. These could be part of the explanation for early PCM failure.
