2005 wk total transmission failure - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2005 wk total transmission failure
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 06-12-2015, 12:52 PM   #1
altrocker1
So i'm looking into buying a new vehicle for my wife and i came across an 05 wk 4wd with a 3.7. I'm not super interested, but the price is pretty cheap. The owner says they hit a pothole and the transmission just quit all at once and had to be towed home...no gears whatsoever...
i'm an xj/wj guy so i don't know a lot about these, but is there a possibility this is something simple? i tried digging around a bit but couldnt find a definitive answer. should i just walk away since the tranny may have grenaded itself?
altrocker1 is offline   Reply With Quote Quick reply to this message
Unread 06-12-2015, 07:04 PM   #2
kris06
2006 WK
filter could pop out of the seal and there is no pressure check for codes it would show low pressure code other then that nothing is simple with transmission
kris06 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2015, 11:01 AM   #3
nighowl2000
2014 JK Wrangler
get a 48'" zip tie and stick it down the transmission service tub on the left side next to the firewall to see the color. should be red. but it does sund like the filter fell out. there is a youtube vid on how to service the nag1 tranny. just warning they are very picky on the fluid level. if you decide to droop the pan, capture all the fluid, mesure it and out the same amount of atf4 back in.
mine: 2014 jku sport S
her's: 2010 commander sport 3.7L 4x4
nighowl2000 is offline   Reply With Quote Quick reply to this message
