2005 WK remote key problems - JeepForum.com
post #1 of 11 Old 11-23-2008, 08:14 PM Thread Starter
stingray66
My son has a 2005 grand chreokee with a key problem one of them works good the other one does not so he never used it well snice he just got married he gave his bride the other key and the remote will not work I did install a new battery and found a bad solder jounit but it still would not work so ok I order two new ones on e-bay the new remotes have the same numbers on the back as the old one so I thought it would work I did use the two keys that came with the jeep the first one you put in and turn on the switch for about 3 secounds then remove the first key and do the same with the 2nd key then were the odometer part it says starting program so I take out the 2nd key and puy in the new key and I then get key invalid I then tried this with the other new kew and got the same thing so am I doing some thing worng or are my new keys bad and why does it say key invalid
also I am getting a 50/50 people telling me that the remote can be program with out a scanner
any help you can gave will be a big help I spent all day sunday missing withy this and just gave up
Norm
PS the old key that did not work will start the car no problem it is the remote part that is not working
04 Grand Cherokee Columbia Edition
1966stingray
stingray66 is offline
post #2 of 11 Old 11-23-2008, 08:19 PM
-Joe-
-Joe-'s Avatar
http://www.wjjeeps.com/sentry.htm
Go to the above link.
"2. Self-Programming additional Sentry Keys (requires TWO original keys)
"A" through "G" below is a quick summary of the steps that are required for programming. Following this list, "1" through "6" takes you through the same process in greater detail.
Quick Steps:
A. Purchase a blank key and have it cut
B. Insert original key #1 into ignition and turn to On
C. Wait 5 seconds and turn key to off
D. Immediately insert original key # 2 into ignition and turn to on
E. Wait 10 seconds for SKIS indicator in dash starts to flash
F. Turn ignition off, insert new blank key and turn ignition back on
G. Once SKIS light stops flashing and turns off, your new key is programmed "
Go to the link posted for more details.
But are you trying to program the sentry key or the remote?
Sentry key you can do yourself, the remote needs a scanner/dealer
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 11 Old 11-23-2008, 08:31 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Moved to WK forum
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 11 Old 11-26-2008, 07:13 PM
five
2005 WK
Can it be one key that has the remote built in and one 'valet key'? Or does it need to be two remote keys?
five is offline
post #5 of 11 Old 01-25-2009, 10:56 PM
uptick
2005 Jeep Keys badly manufactured
The welds on the circuit board that hold the battery retaining clip break all the time. Just another piece of crap part curtosey of Jeep.
uptick is offline
post #6 of 11 Old 02-16-2009, 02:38 PM
plyvolare
2005 WK
I have the same problem. When I purchased my 2005 CPO Grand Cherokee in August 2007, the dealer gave me three keys. Two have broken weld problems. The third works for now. I was told to expect to pay north of $200 for a new key and the reprogramming. I was told that the replacement part was not re-engineered. It is a replacement of the same poorly designed cheap part (good for Chrysler, bad for the customer).
When design and workmanship is poor, consumers switch to better products.
Over the last twenty three years, I have owned eight BMW's, a Porsche and a Ford Explorer with remote keys. The only problems that I experienced were dead batteries. I recommend that Chrysler engineers acquire the remote control keys of other manufacturers and study the design.
When we buy the same poorly designed replacement part, we are rewarding failure. In time somebody else will own my Grand Cherokee.
plyvolare is offline
post #7 of 11 Old 03-31-2011, 10:44 AM
ccregg
2005 WK
Well if it is a bad solder issue then you could just rig it up like i ended up doing. I used a small strip of adhesive velcro to wedge between the back of the key and the battery in order to keep it in place. I havent had any problems with mine since i did that.
ccregg is offline
post #8 of 11 Old 03-31-2011, 10:50 AM
CoreyZ
Or re-solder
'12 JK COD:MW3 Edition
'10 WK, Black(sold)
Colorado Jeep Club member #217
CoreyZ is offline
post #9 of 11 Old 03-31-2011, 10:58 AM
CraigWK
2005 WK
FYI the dealership told me that ebay keys = bad idea, because if the electronics in them have ever been programmed to another WK, you cannot reprogram to match yours...
I don't know the validity here, but that's what I was told.
Yes, I have the same problem...I am living with 1, very moody, key at this time.
Sold...-=2005 WK Grand Cherokee 4.7L rocky mountain edition=-
OME HD lift | Saguaro front bumper | JK 17" wheels with 32" BFG KM Mud tires | 4xGuard skid plates (belly, rear) | D-rings | Husky Liners throughout | SuperChip mod | Warn M8000
CraigWK is offline
post #10 of 11 Old 03-31-2011, 12:17 PM
Budasac
2005 WK
I bough a key off E-bay for $9 and it works fine. It was a sentry key though, no buttons. Bought it as a spare in case i lose a key . Where the keys you bought new?
Budasac is offline
post #11 of 11 Old 03-31-2011, 01:32 PM
mjcother
The reason you cannot use a used chip key is they talk encrypted. From the factory, they all speak the same default encryption, and when used, have been programmed to only talk with a certain encryption.. You have to take them back to the factory default to reprogram, but that takes either talking in the unknown encryption, or brute force attempts. Brute force cracking will lower life of key or kill it, and takes too long to be cost-efficient... (days of trying )
I think this guy below has come up with a way to throw a couple attempts at it, then crack the response it gives back... then he narrows down the possibilities to a manageable number... and sets them to default. He has to be banking some serious cash on this business plan, I am jealous!
I had him de-program a couple keys, and I am very happy!
Matt Burkhart @ carkeysfast
I think he sells refurb with blank shell for $70, search for:
05-07 JEEP REMOTE KEYLESS ENTRY KEY FOB UNCUT BLANK I5
Here is the blurb on his website:
http://www.carkeysfast.com/index.html
"I BOUGHT A CHRYSLER KEY ON EBAY THAT CAN NOT BE PROGRAMMED, CAN YOU HELP?
Absolutely, even though these keys have been around for almost a decade, there are still sellers who are unaware that they cannot be reprogrammed. Just Call or send a note from the Contact page, for a small fee, we will gladly make your key usable again."
-mike
mjcother is offline
ABS, ESP Problems 2005 Grand Cherokee cherokee rose ZJ Grand Cherokee Forum 3 07-27-2012 12:42 PM
Problems with 2005 4.7 Limited sf2007 WK Grand Cherokee & XK Commander Forum 13 08-23-2009 07:25 PM
2005 WK remote key problems stingray66 WK Grand Cherokee & XK Commander Forum 2 11-24-2008 06:32 AM
2005 key and remote start ItalianJeeper77 WK Grand Cherokee & XK Commander Forum 3 11-16-2008 03:03 PM
