2005 WK - AC Problem - JeepForum.com
post #1 of 2 Old 09-07-2007, 06:48 PM Thread Starter
mtthoward
I have a 2005 Grand Cherokee and my AC is acting up. The fan only comes on when I turn it to the highest setting, so it's either Off or very high. What could this be? Unfortunately I'm out of my warranty period, so is it something a handy person could fix themselves or should I take it in for service? Thanks in advance for any feedback.
Matt
mtthoward is offline
post #2 of 2 Old 09-08-2007, 07:18 AM
merlinTec
merlinTec's Avatar
Hi
Well it would be nice to know make if it’s auto zone control or manual.
Anyway I put together some info for you that should help both are behind the glove box hope it helps
If it’s auto control 4 pin plug on the blower module
Pin 2 Ground
Pin 3 blower motor control
Pin 4 live (relay out)
Check for lives and earths first ( but this should be ok as for fan does run on fast speed)
With an LED tester (PLEASE NOT A TEST LAMP OR VOLT METER) and module plugged in back probe pin3 (try not to damage the wire) the LED will flash at different speeds based on the how fast you set the dial. This shows that the control unit is ok and that your fault will be the module.
If manual control 4 pin plug on resistor
A blower motor M2 speed
B blower motor M1 speed
C blower motor Low speed
D blower motor high speed
Using an ohmmeter, check for continuity between all of the blower motor resistor terminals. In each case there should be continuity.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
Steering Problem, 2005 Jeep Grand Cherokee BinaryTracks ZJ Grand Cherokee Forum 7 07-30-2006 09:55 PM
2005 Grand Cherokee Problem RoughDobermann ZJ Grand Cherokee Forum 8 07-16-2006 10:49 PM
2005 Gc Ltd enzomn ZJ Grand Cherokee Forum 4 05-02-2006 12:10 PM
2005 problem nhpso224 ZJ Grand Cherokee Forum 1 03-20-2006 08:46 PM
2005 Grand Cherokee Problem RoughDobermann ZJ Grand Cherokee Forum 5 06-03-2005 04:00 PM
