2005 WK 5.& Hemi Exhaust Manifold Torque Specs? - JeepForum.com
post #1 of 9 Old 10-21-2013, 06:16 PM Thread Starter
SnakeEnterprise
Hey there guys, just finished up with a complete, both exhaust manifold/gaskets/studs project on my 2005 WK 5.7L Hemi Limited. Just wondering what the factory torque specs are for the manifold studs. Ive got them to about just passed snug right now, and they definitely leak still.
Thanks!
SnakeEnterprise is offline
post #2 of 9 Old 10-22-2013, 05:43 AM
Snow4Lif3
2005 WK
According to the service manual :
Exhaust Manifold to Cylinder Head : 25 N.M 220 In Lbs
Did you changed your manifold because of a leak/broken bolt ? What was the symptoms ?
2005 WK 5.7L Limited QDII | Superlift | 1" Bora wheel spacers | Moab wheels | BFG A/T 285/70R17E | MDS light | SuperChips FlashPaq | Taylor Shorties wires | BT catch can | Volant CAI | Gibson Catback | S4xC Front Shackles | Anodized blue painted calipers | Stillen Rotors & Pads | 25W Cree LED Backup Reverse | Nokya Hyper Yellow Fog | ....
Snow4Lif3 is offline
post #3 of 9 Old 10-22-2013, 04:54 PM
modette
2005 WK
Yep, my right (passenger) manifold leaks. Sounds like a Diesel. One project I'm not doing looks tight in there but while I was installing the JBA Upper Arms and had the fender liner out a few days ago I saw that a bolt head was snapped off...so at least there is a stud. I drive maybe once a week, maybe 100 miles...so It's on the back burner for me...Call around in Dec and have it fixed in January. What does a shop typically charge for this service? Looks to be a real PITA to get too on the 5.7L.
modette is offline
post #4 of 9 Old 10-23-2013, 07:05 PM Thread Starter
SnakeEnterprise
I changed out the Manifolds/Gaskets because of leaks on both sides. The passenger side had two broken bolts, the top and bottom at the rear of the manifold. The driver side had one broken bolt at the top rear of the manifold. PITA for sure. Pretty pissed that it's still leaking to be honest. Will hopefully have the time to get back in there next week.
Not a good start to owning the vehicle, we'll see I guess.
post #5 of 9 Old 10-23-2013, 07:13 PM Thread Starter
SnakeEnterprise
Thanks for the info btw
post #6 of 9 Old 10-24-2013, 12:11 PM
modette
2005 WK
So you probably have a warped manifold if it still leaks!!!!
So how bad was the right side (passenger) doing it yourself?
modette is offline
post #7 of 9 Old 11-11-2013, 06:00 PM Thread Starter
SnakeEnterprise
I replaced both Manifolds so I don't think that a warped one is the problem.
Passenger side is the easier side. Hardly any room on the Drivers
post #8 of 9 Old 11-11-2013, 08:14 PM
schwagn
2005 WK
What all did you end up having to remove to get the manifolds replaced? Did you have to raise or lower the engine at all? Mine are leaking also and I'd rather do it myself but for this one I'm thinking I'd rather pay someone. I can barely get my hands in between the manifold and frame on the drivers side, and can't see how to get all the studs loose much less maneuver the manifold out of that space. And I'd be SOL if I broke a stud off in the head.
Thanks!
Also sucks that yours still leaks. Did you get it fixed?
schwagn is offline
post #9 of 9 Old 11-11-2013, 09:01 PM
90grandoneer
90grandoneer's Avatar
2006 WK
If I had seen this thread earlier, I would have recommended you buy the LX manifolds. They're more efficient than the stock WK's, but you'd require slight head pipe mods. Probably help the fuel economy and the performance a little. Here's a thread I did on the differences:
http://www.jeepforum.com/forum/f67/b...-7-wk-1174042/
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
