2005 WK 5.7L - P0520 Check Engine Code - Oil Pressure Sensor - JeepForum.com
post #1 of 6 Old 04-23-2013, 09:47 PM Thread Starter
mroho
Hello All,
Just had my my check engine light come on my 2005 GCJ 5.7 HEMI, had it scanned to find out I got the P0520 check engine code. Figuring I need a new oil pressure sensor, I sent to the parts store to buy a new one. When attemping to buy a new one, they asked if I had a oil pressure light or gauge (have a light), then they asked if I had the 1-wire sensor or 3-wire sensor. I attempted to look for the oil pressure sensor but couldnt find it, can someone help me? They gave me a diagram but that didn't help much. Does someone have an actual picture they can post on here?
Thank you.
Mike
mroho is offline
post #2 of 6 Old 04-24-2013, 02:55 AM
w1pf
Who, me?
w1pf's Avatar
2007 WK
5.7 has a 3-wire sensor. Parts guy should have known this from his catalog, so I wonder how competent he is.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #3 of 6 Old 04-24-2013, 09:50 PM Thread Starter
mroho
Thanks w1pf,
That diagram is a little different than the one I got, that will help.
The parts guy said that that his computer showed both the 1 and 3 wire sensors for the 5.7. Guuess he was wrong.
Thanks again.
Mike
mroho is offline
post #4 of 6 Old 12-13-2013, 01:29 PM
Csfishbo
Oil pres sw
Does the oil need to be drained to change the oil pressure sensor?
Csfishbo is offline
post #5 of 6 Old 02-10-2014, 11:06 AM
Jeepforthewin
2010 JK Wrangler
Im curious about this too as i will be swapping my oil pressure sensor out soon. Im assuming it needs to be drained but if it doesnt need to be then hey less work!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #6 of 6 Old 02-11-2014, 08:37 AM Thread Starter
mroho
The oil does not need to be drained. If I can remember correctly (it's been a while), I think maybe a little bit of oil came out when I remove the sensor, but it is fairly high on the engine.
Thanks,
Mike
mroho is offline
hemi , oil , oil pressure , sensor
