2005 WK 4.7 Stalling issue. - JeepForum.com
post #1 of 4 Old 11-03-2013, 12:19 PM Thread Starter
98jgc
2005 WK
Odd situation, My 2005 4.7 seems to stall in the following manner.
1) Must be a cold start , in the AM.
2) Only happens when I come to a stop.
3) Happens within first two minutes of start up.
4) Happens 1/50 th of the time, now around 1/20 of the time.
I only notice it when I hit the gas and nothing happens.
I run a gasoline antifreeze and occasionally a Bosch Injection system cleaner.
Jeep has 78 K, new plugs, air-filter at 73K.
I tried jiggling key while driving to trigger a tired ignition switch but no.
No codes via key dance and runs perfectly, smooth idle etc.
Any Ideas ?
98jgc is offline
post #2 of 4 Old 11-03-2013, 06:09 PM Thread Starter
98jgc
2005 WK
Did Throttle body clean
Did Throttle body clean using Walts suggested way in the Sticky Section Took 1/2 hour , hardest part was wiggling out the clunky air box on top of the engine. Very easy and satisfying straight forward job. I held the butterfly open with one hand used two fingers and rubbing alcohol; along with a clean cotton t-shirt. That was it. Fair amount of sticky gook cam out with two or three wipes on all surfaces, including back of butterfly (clean surface every time going in, I rolled the shirt) . I have smaller fingers so I was able to go deep and wiggle around the plenum. it was kinda hot
Better 1-2 shift, Noticeable improved acceleration -
Hopefully cures the stall problem.
98jgc is offline
post #3 of 4 Old 02-15-2014, 12:02 PM
matt777
2005 WK
Just solved this problem. The tranny was low 1 quart.
matt777 is offline
post #4 of 4 Old 10-03-2014, 09:32 PM Thread Starter
98jgc
2005 WK
Had it to the dealer a month ago, they could not replicate the problem. They said that they reset the "transmission module" at no charge. Has not happened since.
98jgc is offline
