2005 WK 3.7 Won't Start? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2005 WK 3.7 Won't Start?
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 08-26-2013, 12:12 PM   #1
bmrrwolfe
2006 KJ Liberty
Locally I found a 2005 WK 3.7 with a 132k for cheap because it won't start. The owner said it just stopped running, and now will crank over fine, but not start, and he doesn't want to put any money into it. I am not sure how much of this is true, but I thought about taking a gamble with it. I know it could be a worst case scenario of needing a motor (probably $3,000) but at the price it could still be worth getting.
Any ideas, or common issues with these that would keep it from starting?
I have not seen it or heard it yet, but would like to get some knowledge before going to see it.
Thanks!!
DD: 06 Jeep KJ 3.7 4x4 wheels and tires full skids, D-ring reciever hooks, Manik brushguard with Hella 500s
Toy: 99 Jeep XJ 4.5" lift, 33" BFG MTs soft 8s, Olympic front bumper, RCX rock sliders, Bushwacker flares
bmrrwolfe is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 12:22 PM   #2
drewabril
can you hear the fuel pump prime when you turn they key to "on"? does it have spark?
drewabril is offline   Reply With Quote Quick reply to this message
Unread 08-26-2013, 02:15 PM   #3
JRLT
2010 WK
Try a new battery.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 07:44 AM   #4
bmrrwolfe
2006 KJ Liberty
I am going to try to take a look at it after work today.
I will check to hear for the fuel pump, any easy way to test for spark while I am there? I will also be being by scan tool to see if its throwing any codes, and from others posts, I will be sure to check for the red blinking light on the cluster if the key somehow lost its programming.
Just curious if it cranks strong, why would you say the battery?
Thanks for the info so far.
Unread 08-27-2013, 09:59 AM   #5
ca07wk
2007 WK
Pull the plug and watch it spark, or stick a screwdriver in the coilpack
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline   Reply With Quote Quick reply to this message
Unread 08-27-2013, 02:33 PM   #6
JRLT
2010 WK
Just covering all the bases but these motors are touchy when it comes to batteries. Would that be great if all you needed was a new battery?
