2005 Transmission cooler line leak - Page 2 - JeepForum.com
 7Likes
post #16 of 103 Old 02-06-2011, 08:00 PM Thread Starter
wkorbust
Took some pictures of the new part. These might help illustrate what the veterans are talking about when they say cut at the metal part and replace the rubber hose. The part was only $40 bucks, but swapping out just the hose part would save time in routing the hard metal lines, which are not leaking.
wkorbust is offline
post #17 of 103 Old 02-06-2011, 09:21 PM
lagonwagon
2007 WK
Awesome pics! Clears up a lot. Thank you.
2007 WK Limited (white), QDII, Hemi, OME HD lift, JBA UCA's, Treadwright Guard Dogs 32.25's, Fuel wheels, K&N CAI, BT catch can, 4xGuard rails & belly skid, Saguaro 4x front shackle mounts, tow hitch shackle mount (SOLD)
lagonwagon is offline
post #18 of 103 Old 02-06-2011, 10:53 PM
08Titan
I would prefer to go the "cut and clamp" method due to being easier and cheaper but after looking at the pics of the line it doesn't look like there's enough room to get two hose clamps on each end, to double clamp it, before the bends in thehard line.
2007 JK unlimited rubicon, red rock crystal pearlcoat, rc 2.5" spacer lift, 35x12.50 goodyear mtr/k mounted on black 15x8" mb72's. (Mine)
2005 WK Limited 4.7, QTII, Midnight blue pearlcoat. (Hers)
08Titan is offline
post #19 of 103 Old 02-07-2011, 06:34 AM
JMorash
2005 WK
3/8 fuel line you can route it up past the bends if you want. Clamp one down on the straight, and two up top around the pipe bend. A sure way to know you sealed that mofo on there.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #20 of 103 Old 02-07-2011, 08:47 AM Thread Starter
wkorbust
Especially since you need a specialty tool to get that metal line out. Its a 'quick disconnect' design and requires a key to get it out. http://millerspecialtools.spx.com/De...x?id=654&gid=0
Awesome that aamco changed from drop off and pick up same day to drop off and pick up tomorrow. Call me paranoid about leaving my vehicle anywhere overnight. We have had 'issues' in the past with dealers where techs decided to 'borrow' a vehicle and drove home. I'll be doing this myself once I figure out some way to fabricate that tool. Next time I'm clamping.
wkorbust is offline
post #21 of 103 Old 02-07-2011, 10:28 AM
jstand22
Where are they leaking from? Most commonly they leak from the crimp fittings where the rubber line meets the steel line.
jstand22 is offline
post #22 of 103 Old 02-07-2011, 10:32 AM Thread Starter
wkorbust
That is the spot. Well, that is the 'first' spot I see leaking ATF from. I haven't dug deeper to see if there are any leaks at the quick disconnect spots. I never saw any drips on the ground where I park and only noticed the leak because I saw residue underneath when I was re-greasing my bushings.
wkorbust is offline
post #23 of 103 Old 02-07-2011, 02:02 PM
Nejeep
Anybody tried splitting the metal hose crimp and just pulling the old hose off the metal tube so you don't have to cut the tube? It would give you more tube to work with and I think there is a bump in the tube under the crimp to resist the hose from sliding off. Not sure how to split the crimp on the jeep, maybe a dremmel or small angle grinder?
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #24 of 103 Old 02-07-2011, 02:06 PM Thread Starter
wkorbust
I'm taking the shortcut route (no pun intended). All parts from advanced autoparts.
Fuel injected hose line
PI-504/301111
Fuel injected hose clamps x 2 sets, so 4 clamps per hose.
AC52F16V
Anyone see any problem with using these parts? Also, how much ATF fluid should I plan on dripping out when I cut the lines?
wkorbust is offline
post #25 of 103 Old 02-07-2011, 03:04 PM
Dreezy
1990 FSJ Wagoneer
F. This is my next project as well. I noticed some red in the snow sitting on the bracket for my 4xguard forward skid. Ugh. Atleast now I have a suspect.
Dreezy is offline
post #26 of 103 Old 02-07-2011, 04:12 PM Thread Starter
wkorbust
This is going to turn in to a DIY. I used a PVC pipe cutter to slide up in there and snip the two lines at top and bottom. Maybe 2 tablespoons worth of ATF leaked out in to my oil catch pan. Pictures to come for those who follow.
wkorbust is offline
post #27 of 103 Old 02-07-2011, 05:04 PM
JMorash
2005 WK
I used a fein tool to cut the crimp ends off. The tool is also known as a multi ocilating tool.
butwhat likes this.
2005 WK 5.7L Hemi
JMorash is offline
post #28 of 103 Old 02-07-2011, 07:04 PM
Acidcold
2005 WK
I'm cutting the clamps as well, no need to replace perfectly good steel lines.
Acidcold is offline
post #29 of 103 Old 02-07-2011, 07:15 PM
08Titan
I'm gonna be going this route myself because why spend $40 on lines that'll leak again in a year or two when I could spend probably less than ten bucks on something that'll probably last the life of the jeep. And from what I've seen and read it's not a specialty tool to remove the lines, they're just held in with a c-clip looking thing. They said you just push in on the line a little and pop that clip out.
08Titan is offline
post #30 of 103 Old 02-07-2011, 07:15 PM
Acidcold
2005 WK
Something like this might work as well. http://www.bulkpart.com/Merchant2/me...ooler-fittings
Acidcold is offline
Well, I have the famous tranny cooler line leak. 08Titan WK Grand Cherokee & XK Commander Forum 7 03-13-2011 08:45 AM
transmission cooler line leak bigphil76 ZJ Grand Cherokee Forum 1 01-29-2010 11:43 AM
Tranny cooler line leak alivenkickin28 ZJ Grand Cherokee Forum 6 02-02-2009 04:48 PM
Transmission line cooler djdoug99 ZJ Grand Cherokee Forum 2 07-21-2007 09:50 AM
ZJ - transmission cooler line, I think jeep_on ZJ Grand Cherokee Forum 6 05-28-2006 01:37 PM
