2005 Transmission cooler line leak - JeepForum.com
 7Likes
post #1 of 103 Old 02-01-2011, 04:13 PM Thread Starter
wkorbust
I noticed a small residue under my jeep when I was re-greasing my sway bar bushings and traced it to the transmission cooler lines. I've ordered the part from moparpartsamerica.com, but the dealer (stealer?) said they wanted $550 for parts and labor. I didn't tell them I would be have my own part, but given that, they may object to a part bought from another dealer. Their price includes refilling the transmission fluid.
I've seen other members get quotes for $250 at best so my question is...how big of a project is it to change the lines myself? $550 seems a bit unreasonable and I'm not new to being under my jeep.
wkorbust is offline
post #2 of 103 Old 02-01-2011, 04:43 PM
Lifted_up
2009 JK Wrangler
The clips that secure the trans cooler line connections can be taken off with a tool with a pointed tip. I unbolted part of the exhaust just after the cats to make some room and then un did the clips at both ends of the lines. The clips can be reused and you really don't need a special tool to remove them but be careful not to lose the clips if you are using them again. The hardest part is trying to remove the old trans cooler lines by snaking them out and then trying to snake the new ones in. It helps to have an extra pair of hands. Took me a couple of hours with the help of my little brother.
[09 JKU Rubicon][4.5" lift][Synergy draglink flip kit][Bushwacker flat flares][18x9 Black Eagle Alloy 197 Wheels][35" Nitto Trail Grapplers][Warrior Front Stubby Bumper w/Hidden Winch Mount][Smittybilt X20 10 Comp Series Winch][Paramount Restyling Rear Bumper w/Tire Carrier][Adams Front DS][SC Flashpaq][PureJeep C Gussets][Nitro Sleeves]
Lifted_up is offline
post #3 of 103 Old 02-01-2011, 05:02 PM
Acidcold
2005 WK
Would it be better to cut a section of the old line since it's no longer needed? I will be doing this in the spring time on my 4.7.
Acidcold is offline
post #4 of 103 Old 02-01-2011, 06:21 PM
jayl00p
I picked mine up today from having the trans cooler lines replaced. Total bill was $396.50. Here's the breakdown:
Parts:$104.00
Labor: 4.5 hrs @65.00/hr=$292.50
I would have done it myself, but with a busy job and a little one I just couldnt make the time. Personally, I think 4.5 hours for a specialty shop named "Just Jeeps" is way too long. How many labor hours were you qouted?
jayl00p is offline
post #5 of 103 Old 02-01-2011, 06:26 PM
JMorash
2005 WK
Dont unclipp anything. Cut the fittings that connect the rubber to the metal lines, and just buy 3/8 fuel line and double hose clamp it on. Then top of your tranny with atf 4. Cheap reliable fix. ask anyone that DOESNT WORK AT AN AUTOZONE, about leaky trans cooler lines, its not uncommon.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #6 of 103 Old 02-01-2011, 06:49 PM
fitbmxseries1
1987 YJ Wrangler
worked on mine so far.
2005 Jeep grand Cherokee WK 2" rough country lift 1.25 wheel spacers 255/75/17
Blue WK club #5
1987 Jeep Wrangler YJ, random leafspring budget lift ith 33s on 16s and V8 swap.
1999 Jeep Cherokee XJ --SOLD.
fitbmxseries1 is offline
post #7 of 103 Old 02-01-2011, 09:06 PM Thread Starter
wkorbust
I didn't get an hour breakdown quote, but I can imagine roughly an Arm per hour and a leg every half hour. I've installed the sway bars, exhaust, intake and stillen pads/rotors and do the spring/fall maintenance myself so this shouldn't be too bad of a DIY. My next stop is to call Aamco to see what they would charge to install the parts and top off the fluid, because like you, time is scarce with my job.
Because these lines feed the transmission radiator, if I do it myself, would it be best to drain all the fluid out and then refill fresh or would only a certain amount come out when I disconnect the lines? I have an oil extractor with a tube for ATF fluid that I can drain it all out from the fill tube. My jeep is a relative baby at 20K miles so I'm debating if I should have the pan dropped and filter changed while I'm at it.
wkorbust is offline
post #8 of 103 Old 02-01-2011, 10:41 PM
Lifted_up
2009 JK Wrangler
I'm sorry acid...are you talking about what the others above are saying about adapting the lines instead of replacing with new ones? If you are thinking of just cutting the old lines to get them out easier, that would work. The trouble would still come when you have to get the new ones in. I had to kind of bend and twist the new lines when I put them in but was careful not to damage them. It's not very hard, but it just takes some time and patience.
post #9 of 103 Old 02-03-2011, 11:53 AM
jstand22
Easy with the AutoZone employee bashing...I realize that 97% are idiots. But there are the 3% (including myself) who work there and can actually offer some useful advice.
Anyways, back on topic...Cutting portions hard lines off and using rubber hose and clamps is perfectly fine. It is safe, easy to install, and easy to fix later if it weeps again (the best part is it will only cost you about $10). After all the factory lines have sections of rubber line with crimped fittings (which are never as strong as a well placed hose clamp)... As far as the 4.5 hours from the dealer to replace the lines, that is a little excessive...it's really only a 2-3 hour job, and as people said the hardest part is snaking the new ones in...you can cut the old ones to pieces to get them out in about 10 mins.
jstand22 is offline
post #10 of 103 Old 02-03-2011, 02:37 PM
fitbmxseries1
1987 YJ Wrangler
too bad you dont work at the one by my place!
Blue WK club #5
post #11 of 103 Old 02-03-2011, 02:47 PM Thread Starter
wkorbust
I already ordered the part from mopar america and it should arrive today or tomorrow. As far as 'next time' and fitting new hose clamps - pics? Because I'm envisioning something like a tube version of a thanksgiving tur-duck-en...
wkorbust is offline
post #12 of 103 Old 02-05-2011, 03:32 PM
benk71
2005 WK
JMorash - It looks like the fittings on the rubber portion are press fit onto the metal part of the line, do you just cut the metal at the fitting?
benk71 is offline
post #13 of 103 Old 02-05-2011, 08:41 PM
lagonwagon
2007 WK
I have this job coming up......
2007 WK Limited (white), QDII, Hemi, OME HD lift, JBA UCA's, Treadwright Guard Dogs 32.25's, Fuel wheels, K&N CAI, BT catch can, 4xGuard rails & belly skid, Saguaro 4x front shackle mounts, tow hitch shackle mount (SOLD)
lagonwagon is offline
post #14 of 103 Old 02-06-2011, 07:57 AM
jstand22
They are crimped fittings; crimped onto the hard mental lines. You cut the metal lines after the crimped fittings, so you cut out the rubber line all together (including the crimped ends).
jstand22 is offline
post #15 of 103 Old 02-06-2011, 06:35 PM
benk71
2005 WK
Perfect, thank you!
benk71 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Well, I have the famous tranny cooler line leak. 08Titan WK Grand Cherokee & XK Commander Forum 7 03-13-2011 07:45 AM
transmission cooler line leak bigphil76 ZJ Grand Cherokee Forum 1 01-29-2010 10:43 AM
Tranny cooler line leak alivenkickin28 ZJ Grand Cherokee Forum 6 02-02-2009 03:48 PM
Transmission line cooler djdoug99 ZJ Grand Cherokee Forum 2 07-21-2007 08:50 AM
ZJ - transmission cooler line, I think jeep_on ZJ Grand Cherokee Forum 6 05-28-2006 12:37 PM
