2005 Grand Cherokee WILL NOT START! Security System - JeepForum.com
post #1 of 8 Old 01-10-2010, 06:01 PM Thread Starter
alvar309
Hello,
I have a 2005 grand Cherokee with a stock alarm system that will not start. Battery fully charged, lights and radio work. I can arm/ and disarm alarm with keyfob.
When I turn the key to start the car the starter doe NOT crank at all. It seems to be as if the security disabler is active.
this happened to me once before and after having the vehicle towed I left the battery disconnected and the car started the following morning.
Once again this happened today, so I have left the battery disconnected and hope it will start in the morning.
I would like to disable the stock alarm system . Anyone that has any info please help.
Thanks
alvar309 is offline
post #2 of 8 Old 01-10-2010, 06:22 PM
colinzj
2006 WK
The security system doesn't stop the starter from cranking, it stops the fuel pump from running once the vehicle's started.
Your problem is more likely with the starter motor or the ignition switch itself.
If you're thin and flexible, you can shimmy under the front end and wang on the starter motor with a hammer while someone tries to start the Jeep. If that works, you need a new starter.
Does anything at all happen when you turn the key to the start position? If the switch is good, the interior and should go out, all the dash lights should come back on for a check, the usual.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 8 Old 01-10-2010, 06:24 PM
magneticred
2008 WK
If the starter does nothing, then it is likely a problem in the starter (or switches). The security system does not prevent the starter motor from working. From the owners manual:
The system will shut the engine off in two (2) seconds if someone uses an invalid Fob to start the engine.
magneticred is offline
post #4 of 8 Old 01-10-2010, 08:09 PM Thread Starter
alvar309
Colin,
When the key is turned to either the on or start poistion the dash lights turn on and the dashboard goes through all of its normal functions.
From what you stated earlier it sounds like its the starter. I will try to banging on the starter tom.and try and start it. I did notice that last time this happened it was also very cold. i live in NYC
thanks
alvar309 is offline
post #5 of 8 Old 01-10-2010, 08:20 PM
Devilsmed98
I had this problem when I first got the car, same symptoms that you post. I initially thought it was a security problem. My dad (mechanic for 35 years) got under the car, told me to start it. The connection to the starter was loose. We had to bring it to his shop, put it on the lift and tighten some bolts, check some wires and it hasn't had a problem since.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #6 of 8 Old 01-02-2014, 03:36 PM
ChasZone
Originally Posted by alvar309 View Post
Colin,
thanks
alvar309,
Did you ever get this resolved? My wife's 2010 is doing the EXACT same thing you're describing under the EXACT same conditions (cold temp - 27 degrees). If so, what fixed it? It seems like Devilsmed98 had a solution but I wanted to compare his resolution with yours.
Any help would be appreciated.... Jeep is sitting dead in the street and we have a storm coming. Would like to get the thing out of the street and in the driveway for now and ultimately get it fixed. This is the second this happened.
Thanks,
Charlie
ChasZone is offline
post #7 of 8 Old 01-19-2015, 05:01 AM
rockbox
2005 WK
I do have the same issue, as I will wake up my HEMI in the morning with no any issues till it gets wormed up and drive for 30 mints to work, so if I tried starting my jeep after this period of driving I will have the below symptoms:
- ECT gage will fall down.
- Security light will start flashing.
- Engine will not crank.
-Transmission Over temperature message will be displayed.
- Service electronic break system.
-service 4WD system.
If I kept my jeep to cold own for a while for like 45 minute it would start normally back with no issues.
However if I did the below:
Remove the battery and wait for a few minutes or removed the PCM fuse and returned it back I will get the car started ok Or/and I might get it started with the below symptoms:
-Gearbox in limp mode.
- Gearbox will shift pretty harsh as if it is in the overheat shifting schedule.
- Gearbox will shift super softly and lots of clutch slippage.
On the other hand I have searched for this issue every ware you may think about and everything you might think about and found out that the connectors on the PCM are made of plastic and by time it gets expanded and with the excess heat in the engine bay the PCM pins and the connectors will have a separation, to solve this issue I have had to find a solution for something that will keep the connectors pushed in the PCM so I used a tie rap to solve it and it did solve the issue and made the jeep run more responsive, Moreover you need to make sure the gearbox connectors are just fine and cleaned.
I totally agree with you opinion gents that a tie rap is not a solution however I would love to see a creative ideas,
By the way I have done all the stuff people went through thinking it is a security issue or a bad starter.
rockbox is offline
post #8 of 8 Old 01-19-2015, 05:45 AM
davids0865
2005 WK
It will only do that 3 times and then not crank anymore if it is the security system. Is the alarm light showing after the bulb check?
This is exactly where I am with my 2005 WH.
davids0865 is offline
93 Grand Cherokee Limited Security System Disable HalfShaft ZJ Grand Cherokee Forum 73 01-08-2017 10:24 AM
grand cherokee security system wiring kenwildcat99 ZJ Grand Cherokee Forum 0 09-08-2009 12:02 PM
93 Grand Cherokee Limited 4.0 wont start... Electrical? Security? 93volsd ZJ Grand Cherokee Forum 13 02-22-2009 08:17 PM
2005 Jeep Grand Cherokee DEAD - Security System Activated tdturk WK Grand Cherokee & XK Commander Forum 7 02-22-2009 04:48 PM
Grand Cherokee Security System Shardon ZJ Grand Cherokee Forum 5 11-22-2006 11:37 AM
