2005 grand cherokee laredo radio install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > 2005 grand cherokee laredo radio install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 03-25-2012, 05:45 PM   #1
MSniper
2005 WK
Well guys the radio in my jeep finally died it was the stock radio without navigation. I want to put in a double din radio but the console around the stock radio is not big enough. I have found the bezel kit online for $120 but has anyone trimmed theirs to accommodate a double din radio before? Or is there a place to purchase the bezel kit with navigation (bigger hole for radio) at a cheaper price.. The reason why I ask is because the wiring harness is $120 because this keep has the inline amp so the normal $20 harness will not work.
MSniper is offline   Reply With Quote
Unread 03-26-2012, 08:21 PM   #2
MSniper
2005 WK
Also is there an easy way to determine if your jeep has an inline amp without removal of the driver side rear quarter panel to see if the amp is actually there. Can the vin number be ran to determine if it has the inline amp in this model jeep?
Unread 03-26-2012, 08:45 PM   #3
Budasac
Budasac's Avatar
2005 WK
You can request a build sheet from Jeep that lists every option on your WK. Check out this link.
Buda's Build Thread
05 WK - Leather Interior | 2" RC Lift | 265/70/17 Firestone Destination AT's
Teraflex 1.5" Spacers | 4xGuard Matrix w/ Hoop and Front Hitch | Rola Rack
Custom CB Install | Custom Antanna Mount | 4' Firestick "Firefly"
Monroe Load Adjusting rear coil-overs (F-150 model ) | 6000k HID Lows
Yellow Fogs | KC 5" Driving Lights | LED Underlighting | Expanded Metal Grille Mod
LED Cargo Lights | 7w Cree LED Reverse Lamps | Tinted Tail Lights
20% Window Tint | IPOD Integration | HyperTech Max Energy Tuner
JBA Upper Control Arms
68 Mustang Fastback - GT350 Clone | 390 FE Big Block
99 WJ Limited - Traded
97 TJ - Sold
Budasac is online now   Reply With Quote
Unread 03-26-2012, 08:52 PM   #4
TurboDiesel
2008 WK
Do u have BA speakers?
If not u don't have an amp
If u do, then u most likely have an amp...
-]All Blacked Out[-
2008 Jeep Grand Cherokee 3.0 CRD
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
15" kicker solo baric L7 w/ Alpine m1000 amp
aftermarket headlights w/5000k HIDs
Red interior LEDs and Red license plate LED
Tinted tails
5% tint over the rear windows
more to come....
TurboDiesel is offline   Reply With Quote
Unread 03-26-2012, 08:54 PM   #5
colinzj
2006 WK
If you have the Boston system:
1. The front door speakers will not reproduce highs.
2. You'll be able to see the amp's silver cooling fins through the vent in the rear quarter panel.
If that doesn't leave you feeling certain, go here and open up the "Optional Equipment" section. You'll need to create an account (which needs the last 8 digits of your VIN) if you don't already have one. If you have the Boston system, you'll see:
6 Boston Acoustics Speakers
276 Watt Amplifier
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Unread 03-26-2012, 10:36 PM   #6
MSniper
2005 WK
Thanks requested the build sheet from jeep.
Unread 03-26-2012, 10:48 PM   #7
MSniper
2005 WK
Did exactly as you said opened the optional equipment and this is what was listed.
Cloth Low-Back Bucket Seats
Khaki
3.7L Eng (EKG)/5Spd A/T W5A580 (DGJ)
5-Speed Auto W5A580 Transmission
3.7L V6 Engine
Vehicle Information Center
Traveler/Mini Trip Computer
50 State Emissions
Federal Tier 2, Bin 5 Emissions
Standard Duty Engine Cooling
Dk. Khaki Pearl Coat
P245/65R17 OWL All Terrain Tires
Goodyear Brand Tires
All Aluminum Wheels
Manuf Statement of Origin
7.5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TE
Customer Preferred Package 26E
Really don't know what the customer preferred packages are and done a google search but nothing really came up..
i did the standard equipment listing as well and is as follows.
Monotone Paint
160 Amp Alternator
730 Amp Maintenance Free Battery
Four Wheel Traction Control
Anti-Lock 4-Wheel Disc Brakes
Low Back Bucket Seats
Manual Driver & Pass Lumbar Adjust
Rear 60/40 Folding Seat
Child Seat Upper Tether Anchorages
Child Seat Anchor System-LATCH Ready
Advanced Multistage Front Air Bags**
Center Rear 3-Point Seat Belt
Cloth Covered Headliner
Floor Carpet
Cargo Compartment Carpet
Cargo Tie Down Loops
Front & Rear Floor Mats
Cargo Trim Panel w/Storage Net
Reversible/Waterproof Cargo Storage
Passenger Assist Handles
Base Door Trim Panel
Full Length Floor Console
Overhead Console
All 5-Speed Automatic Transmissions
Lock-Up Torque Converter
Quadra-Trac I Full-Time 4WD
200MM Front Axle
3.07 Rear Axle Ratio
213MM Rear Axle
Conventional Differential Frt Axle
Conventional Differential Rear Axle
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Flipper Liftgate Glass
Rear Window Defroster
Rear View Day/Night Mirror
Sun Visors w/Vanity Mirror
Power Mirrors, Fold-Away
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Hood Insulation
Deluxe Insulation Group
Instrument Panel
Instrument Cluster w/Tach
140 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Dual Note Electric Horns
Locking Glove Box
12V Auxiliary Power Outlet
Power Accessory Delay
Power Locks
Power Windows, Driver One-Touch
Power 8-Way Drvr/Manual Pass Seat
Jet Black - Molding - Bodyside
Jet Black - Molding - Sill
Tire Pressure Monitoring Warning LP
Illuminated Entry
Warning Chime
Courtesy Lamps
Glove Box Lamp
Rear Courtesy/Reading Lamps
Cargo Compartment Lamp
Halogen Headlamps
CHMSL Lamp
Enhanced Accident Response System
Front License Plate Bracket
Body Color Grille
Black Windshield Moldings
Body Color Fascias
Black Belt Molding
Accent Color License Plate Brow
Jeep Badge
Side Roof Rails
4X4 Badge
Integrated Liftgate Rear Spoiler
Laredo Badge
20.5 Gallon Fuel Tank
Power Steering Cooler
Speed Control
6 Speakers
Fixed Long Mast Antenna
AM/FM Compact Disc Radio
Power Rack and Pinion Steering
Steering Wheel
Normal Duty Suspension
Tilt Steering Column
Full Size Spare Tire w/Matching Whl
17X7.5 Aluminum Wheels
Non Adjustable Pedals
Occupant Classification System
Protective Coating and Remover
Build To U.S. Mkt. Specifications
GVW Rating - 5900#
U.S. Dealer Retail
Zone 42-Detroit
Four Wheel Drive (4WD)/(4X4)
Left Hand Drive (LHD)
WK/6042 Vehicle Family
Price Class H
Vehicle Order Tracking
U.S. Specifications Label
Indiana Ship to State Code
Indiana Sold to State Code
Unread 03-27-2012, 09:36 AM   #8
MSniper
2005 WK
Okay got the build sheet in my email this morning, and i do not see the amp listed in there but for ease of mind if anyone can take a look at it to make certain i would appreciate it.
Vehicle Description: Jeep Grand Cherokee Laredo 4X4 Sport Utility 4-DR
Model Year: 2005
Body Model: WK J H 74
Build Date: September 3, 2004
In Service Date: February 25, 2005
Sales Code Description
*A7 Cloth Low-Back Bucket Seats
-J3 Khaki
APAS Monotone Paint
A88P 3.7L Eng (EKG)/5Spd A/T W5A580 (DGJ)
BABS 160 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BNRS Four Wheel Traction Control
BRYS Anti-Lock 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CDUS Manual Driver & Pass Lumbar Adjust
CFNS Rear 60/40 Folding Seat
CF4S Child Seat Upper Tether Anchorages
CGUS Child Seat Anchor System-LATCH Ready
CG3S Advanced Multistage Front Air Bags**
CG6S Center Rear 3-Point Seat Belt
CHBS Cloth Covered Headliner
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CLHS Cargo Trim Panel w/Storage Net
CL5S Reversible/Waterproof Cargo Storage
CSRS Passenger Assist Handles
CTLS Base Door Trim Panel
CUFS Full Length Floor Console
CUNS Overhead Console
DGES All 5-Speed Automatic Transmissions
DGJ 5-Speed Auto W5A580 Transmission
DHAS Lock-Up Torque Converter
DHZS Quadra-Trac I Full-Time 4WD
DJAS 200MM Front Axle
DMMS 3.07 Rear Axle Ratio
DRSS 300MM Rear Axle
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
EKG 3.7L V6 Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GEPS Flipper Liftgate Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNVS Sun Visors w/Vanity Mirror
GTNS Power Mirrors, Fold-Away
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGAS Hood Insulation
HGDS Deluxe Insulation Group
JAPS Instrument Panel
JAYS Instrument Cluster w/Tach
JCES 140 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JKAS Locking Glove Box
JKPS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JPRS Power 8-Way Driver Seat
K1XS STRIPE/BADGE/MOLDING/COLOR
K5XS STRIPE/BADGE/MOLDING/COLOR
LABS Tire Pressure Monitoring Warning LP
LACS Illuminated Entry
LAGS Warning Chime
LAZP Vehicle Information Center
LBBS Courtesy Lamps
LBCS Glove Box Lamp
LCES Rear Courtesy/Reading Lamps
LDBS Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LMBS Halogen Headlamps
LPSS CHMSL Lamp
LSES Enhanced Accident Response System
MDAS Front License Plate Bracket
MFNS Body Color Grille
MHAS Black Windshield Moldings
MLAS Body Color Fascias
MMGS Belt Moldings
MNSS Accent Color License Plate Brow
MVCS Jeep Badge
MWES Side Roof Rails
MWTS 4X4 Badge
MXRS Rear Spoiler
MZKS Laredo Badge
NAS 50 State Emissions
NB5P Federal Tier 2, Bin 5 Emissions
NFPS 20.5 Gallon Fuel Tank
NHFS Power Steering Cooler
NHMS Speed Control
NMBP Standard Duty Engine Cooling
PJT Dk. Khaki Pearl Coat
QJTS Dk. Khaki Pearl Coat
RCGS 6 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCAS Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBWS Full Size Spare Tire w/Matching Whl
TCD P245/65R17 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WFJS 17" Aluminum Wheels
WLZC All Aluminum Wheels
XA8S Non Adjustable Pedals
XCAS Occupant Classification System
XPFS Protective Coating and Remover
YAAS Build To U.S. Mkt. Specifications
Unread 03-27-2012, 10:25 AM   #9
JRLT
2010 WK
Have you taken a look here yet?
http://www.wkjeeps.com/interior_trim.htm
http://www.wkjeeps.com/wk_radios.htm
http://www.wkjeeps.com/boston.htm
http://www.wkjeeps.com/wk_audio_pinouts.htm
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/55/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline   Reply With Quote
Unread 03-27-2012, 11:06 AM   #10
MSniper
2005 WK
Yes been reading up on that now the question is the Bezel in general. My bezel is for the factory stock radio not the navi unit. So i am having to locate a Jeep Grand Cherokee Navigation Radio Bezel Kit 2005-2006 Khaki Part Number 5JN311J8AO..
These are expensive puppies and I seriously thought about just trimming mine to fit but not really for sure how that would even look. All custom radio installs places tell me that it looks horrible when you cut and trim the normal bezel.
Unread 03-27-2012, 01:23 PM   #11
Mainsail
2005 WK
Consider just crawling craigslist for another or better stock radio. After 20+ years of being around jets, I can't tell the difference between the jeep stock radio and the fancy radios with the high install drama.
Go on craigslist and search the auto parts section for '2005 cherokee', then '2006 cherokee' and up. I also used 'chrysler radio' and 'dodge radio' as key words.
Poor grammar is something up with which I shall not put.
www.topohiker.com
Mainsail is offline   Reply With Quote
Unread 03-27-2012, 01:33 PM   #12
mattydipps
2006 WK
i got a stock radio laying around... you have to wiggle the aux port to get it to work but other then that it works perfectly not one scratch at all on it... if your interested
[FONT="Comic Sans MS"][/FONT]matt-
[CENTER][B]06' WK, 3.7l, 2 inch Rough Country lift, HyperTech Max Energy 52001, Expanded Metal Grille Mod, Smittybilt rear recovery point, S4XC front recovery shackles with smittybilt 3/4 d-rings, Red Daystar d-ring isolators, Custom shorty antenna, cb radio, S4XC antenna mount, Firestik antenna & coax, 17 inch Moabs w/ 265/70/17 Falken Wild Peaks, Hella 500ff driving lights, Monroe Load Levelers 58643, Rola Roof Rack, Custom painted headlights with Red LEDs, Red LED back lit grille, AirRam power wire, Fastman Throttle Body, Airaid CAI, Flowmaster 40 series
[I]see how it was all made [COLOR="Red"][URL="http://www.jeepforum.com/forum/f67/mattydippss-build-thread-1336318/"]here[/URL][/COLOR] [/B][/CENTER]
[B][COLOR="Red"]RED WK CLUB #8[/COLOR][/B][/I]
mattydipps is offline   Reply With Quote
Unread 03-27-2012, 09:01 PM   #13
MSniper
2005 WK
Thanks for the offer on it but that is the reason i decided to move away from stock radio after this one decided to stop working. I decided to upgrade to an aftermarket radio that has bluetooth options, and HD radio and Sat radio.
Unread 03-28-2012, 12:20 PM   #14
WKFusion
2006 WK
I also want a double din nav radio. Is the harness seriously 120? Their must be another route.
2006 Cherokee Laredo 3.7L Current Mods:
Tinted windows/sun visor / HID KIT / Custom CAI / Pinch weld mod / 1.5'' Spacers / 265/70/17 -- Wrangler Authority / Hypertech / 2'' RC
WKFusion is offline   Reply With Quote
Unread 03-31-2012, 05:28 PM   #15
MSniper
2005 WK
If you have the in line amp yes the harness is $120 but if you purchase the radio at crutchfield website they sell the harness for $65 to you half off but the normal harness is $20 bucks depending on if you have that amp built in
